Joomla add multiple markers in map
webmaster@exnet.gr
webmaster@exnet.gr posted this 6 days ago
How to add two markers in map that created by theme?
You can also guide me to add two address fields in joomla admin themler, to create the map
How can i edit the theme code so that i can add one more field to map creation?
How to add two markers in map that created by theme? You can also guide me to add two address fields in joomla admin themler, to create the map How can i edit the theme code so that i can add one more field to map creation?
Themler is using Google Maps to embed maps. It is possible to add only one address with the current integration of Google Maps in Themler.
You can though create multiple-address map yourself using Google Map service and then add this map manually via HTML control in Themler (Insert -> HTML).
You may find this helpful:
https://www.create.net/support/how-to-pin-point-multiple-locations-on-google-maps
Hello, Themler is using Google Maps to embed maps. It is possible to add only one address with the current integration of Google Maps in Themler. You can though create multiple-address map yourself using Google Map service and then add this map manually via HTML control in Themler (Insert -> HTML). You may find this helpful: https://www.create.net/support/how-to-pin-point-multiple-locations-on-google-maps Gina Themler Support
webmaster@exnet.gr
webmaster@exnet.gr posted this 5 days ago
Yes but where is the address form submitted? with which name? how to create second field in map?
This may be a technical issue though
Yes but where is the address form submitted? with which name? how to create second field in map? This may be a technical issue though
Support Team posted this 5 days ago
The address is added in Themler UI here:
But I can't guide you through code modification since this code is not provided by us, it is provided by Google Maps service. We advise to to use map embed code (which I have suggested earlier).
The address is added in Themler UI here: !map-address.png! But I can't guide you through code modification since this code is not provided by us, it is provided by Google Maps service. We advise to to use map embed code (which I have suggested earlier). Gina Themler Support
