open by firefox
alex604
alex604 posted this 12 November 2019
Hi, I have problem with importing my themes through Chrome which was composed under Artisteer. But it imported fine through FireFox when I uninstall my Chrome. I don't want to uninstall my Chrome every time when I want to import a theme. How can I force Themler to run through FireFox?
Support Team posted this 12 November 2019
Hello Alex,
1) navigate to:
chrome://appcache-internals
2) navigate to:
This should help making it work.
Unfortunately, it is not possible to force Themler switch to FF. Is FF your default browser?
Hello Alex, If you are using Google Chrome, try this: 1) navigate to: chrome://appcache-internals find your website and click on 'Remove Item' 2) navigate to: chrome://settings/clearBrowserData select 'Cached images and files ' and click on 'Clear Data' (please don't check other check-boxes). 3) Reload your Themler Editor. This should help making it work. Unfortunately, it is not possible to force Themler switch to FF. Is FF your default browser? Gina Themler Support
alex604
alex604 posted this 5 weeks ago
I navigated to chrome://appcache-internals. It shows
Application Cache
Instances in: C:\Users\USER\AppData\Local\Google\Chrome\User Data\Default (0)
There is nothing to be removed.
FF is my default browser now since I had the problem.
What can I do. I need to import an Artisteer file sometimes.
I navigated to chrome://appcache-internals. It shows Application Cache Instances in: C:\Users\USER\AppData\Local\Google\Chrome\User Data\Default (0) There is nothing to be removed. FF is my default browser now since I had the problem. What can I do. I need to import an Artisteer file sometimes.
Support Team posted this 5 weeks ago
I will report this to the developers.
Meanwhile, you can either stick to Firefox or use Themler Desktop for Artisteer files.
I will report this to the developers. Meanwhile, you can either stick to Firefox or use Themler Desktop for Artisteer files. Gina Themler Support
