I can't access the template https://agroforestalycinegetica.com/administrator/index.php
elviro.valencia
elviro.valencia posted this 4 weeks ago
Good Morning,
When making changes to the web template https://agroforestalycinegetica.com/administrator/index.php
Admin: AdminAYC
Password: ¿?AyCl(CREAL)20170126Enero?¿
I have the same error that we have treated on the web http://podologomanuelchamorro.es/administrator/index.php
I tried to apply this solution to the template http://answers.themler.io/articles/173620/how-to-fix-the-error-after-updating-to-joomla-3-9 but it has not worked.
I ask you, please, to help me solve the problem.
I have attached the file whit template that we have saved
Receive an cordial greeting. Elviro
Good Morning, When making changes to the web template https://agroforestalycinegetica.com/administrator/index.php Admin: AdminAYC Password: ¿?AyCl(CREAL)20170126Enero?¿ I have the same error that we have treated on the web http://podologomanuelchamorro.es/administrator/index.php I tried to apply this solution to the template http://answers.themler.io/articles/173620/how-to-fix-the-error-after-updating-to-joomla-3-9 but it has not worked. I ask you, please, to help me solve the problem. I have attached the file whit template that we have saved Receive an cordial greeting. Elviro
8 Comments
Your theme version is very old for Joomla version you use now. It is always better to update Themler theme first before updating Joomla version.
You can access your site via ftp, go to "templates" folder, zip the folder of your theme and open it with Themler desktop. Then update the theme to v484 (or later) and re-install to the site.
Hello, Your theme version is very old for Joomla version you use now. It is always better to update Themler theme first before updating Joomla version. You can access your site via ftp, go to "templates" folder, zip the folder of your theme and open it with Themler desktop. Then update the theme to v484 (or later) and re-install to the site. Gina Themler Support
elviro.valencia
Good morning again,
I have done the work that you have indicated to me, but when I open it in Themler I get a message that says: Retry?
When you click OK, it does not progress, and if I cancel it, the following message appears: Sorry, an error has occurred.
Please clear your browser cache.
After cleaning the browser following the same errors.
Receive a cordial greeting. Elviro
Good morning again, I have done the work that you have indicated to me, but when I open it in Themler I get a message that says: Retry? When you click OK, it does not progress, and if I cancel it, the following message appears: Sorry, an error has occurred. Please clear your browser cache. After cleaning the browser following the same errors. Receive a cordial greeting. Elviro
Elviro,
Could you please attach your theme here?
Elviro, Could you please attach your theme here? Gina Themler Support
elviro.valencia
Good Morning,
I Attach the theme agroforestal.zip
Greetings. Elviro
Good Morning, I Attach the theme agroforestal.zip Greetings. Elviro
elviro.valencia
elviro.valencia posted this 3 weeks ago
Good Morning,
Please, you can look at this topic; I can't edit the template, and I need to make some modifications to it.
If you need to access Joomla, in the first post of this topic are the access data.
Thank you very much. Elviro
Good Morning, Please, you can look at this topic; I can't edit the template, and I need to make some modifications to it. If you need to access Joomla, in the first post of this topic are the access data. Thank you very much. Elviro
elviro.valencia
Good Morning,
Please, you can look at this topic; I can't edit the template, and I need to make some urgent modifications to it.
Good Morning, Please, you can look at this topic; I can't edit the template, and I need to make some urgent modifications to it. Thank you very much. Elviro
Ch3vr0n
Ch3vr0n posted this 3 weeks ago
URGENT: THIS IS A PUBLIC TICKET WITH VALID SUPERUSER CREDENTIALS!
I don't speak spanish or italian (whatever language that is) but CHANGE YOUR CREDENTIALS IMMEDIATELY! I was able to login to the backend of your website from belgium succesfully. If i wanted i could have DELETED EVERYTING AND CRIPPLED YOUR SITE. By the looks of it you don't have software like akeeba backup installed, so this would have killed your website!
Backup now and CHANGE THAT LOGIN IMMEDIATELY
@Themler, change this ticket to private, right now
URGENT: THIS IS A PUBLIC TICKET WITH VALID SUPERUSER CREDENTIALS! I don't speak spanish or italian (whatever language that is) but CHANGE YOUR CREDENTIALS IMMEDIATELY! I was able to login to the backend of your website from belgium succesfully. If i wanted i could have DELETED EVERYTING AND CRIPPLED YOUR SITE. By the looks of it you don't have software like akeeba backup installed, so this would have killed your website! Backup now and CHANGE THAT LOGIN IMMEDIATELY @Themler, change this ticket to private, right now
elviro.valencia
elviro.valencia posted this 2 weeks ago
God Morning,
By imposibility of access to the template, i decide made the template of new.
Now, are work fine.
Very Thank you.
God Morning, By imposibility of access to the template, i decide made the template of new. Now, are work fine. Very Thank you.
