Unable to use zip from Artisteer in Themler
ZCompany
ZCompany posted this 4 weeks ago
Hi!
I have a problem when trying to import a zip from Artisteer to Themler. I export it with Themler export option, checkmark on Include content marked.
I import the .zip in Themler, but when I click on "Open with Themler" it opens an error with no text, just saying Retry? - see attached file.
Attached are also the .zip and the Artisteer file.
Hi! I have a problem when trying to import a zip from Artisteer to Themler. I export it with Themler export option, checkmark on Include content marked. I import the .zip in Themler, but when I click on "Open with Themler" it opens an error with no text, just saying Retry? - see attached file. Attached are also the .zip and the Artisteer file.
SH707
SH707 posted this 4 weeks ago
when i download the .artx file i get a 404 error (404 - File or directory not found)
the import of the zip file in themler fails too.
I think it is not possible to import zip files from artisteer in themler?
when i download the .artx file i get a 404 error (404 - File or directory not found) the import of the zip file in themler fails too. I think it is not possible to import zip files from artisteer in themler?
ZCompany,
I have successfully imported your attached theme in Themler and re-exported it. Please try the theme attached.
**ZCompany**, I have successfully imported your attached theme in Themler and re-exported it. Please try the theme attached. Sincerely, Nettie
SH707,
Indeed, this happens with .artx attachments - it is recommended to put them into a folder and zip it, then attach. In any case, it is possible, to export Artisteer themes in Themler format - for this use this Artisteer version and Export >> Themler >> [select your CMS] in Artisteer:
**SH707**, Indeed, this happens with .artx attachments - it is recommended to put them into a folder and zip it, then attach. In any case, it is possible, to export Artisteer themes in Themler format - for this use this Artisteer version and Export >> Themler >> [select your CMS] in Artisteer: www.artisteer.com/media/p4/files/Artisteer.4.3.0.60928.exe Sincerely, Nettie
ZCompany
ZCompany posted this 3 weeks ago
Hi!
Sorry, but I don't understand you. When I export with Artisteer - it exports in .zip. What should I do? Unzip and zip again or what?
Moreover I keep getting the same error even with the .zip you sent me.
I've cleaned my browser's cache, etc., but I keep getting the error.
Hi! Sorry, but I don't understand you. When I export with Artisteer - it exports in .zip. What should I do? Unzip and zip again or what? Moreover I keep getting the same error even with the .zip you sent me. I've cleaned my browser's cache, etc., but I keep getting the error.
I meant .artx attachment. But as far as I understand, the issue is different. Where do you import the attached .zip - on your website, in Themler desktop or on localhost?
Hello, I meant .artx attachment. But as far as I understand, the issue is different. Where do you import the attached .zip - on your website, in Themler desktop or on localhost? Sincerely, Nettie
ZCompany
I import in in Themler desktop. I see it in the list with all templates, but when I click on "Open with themler" - then it gives the error.
Please try the following:
1) close Themler
4) start Themler again
5) try to import the theme.
If it is successful, you may need also to import the previously created themes from the renamed folder.
Hello, Please try the following: 1) close Themler 2) open Windows Explorer and type %LocalAppData% in the address bar 3) find & rename Themler directory 4) start Themler again 5) try to import the theme. If it is successful, you may need also to import the previously created themes from the renamed folder. Sincerely, Nettie
