Imported themler theme seems to be incomplete
jansen.marcus
jansen.marcus posted this 2 weeks ago
I've built a Themler theme for Wordpress in my development site.
Everything works nice.
I've exported the theme to a zip file (without content) and imported the zip file as a new theme in the production site.
In my theme I'm using a slider with some slides but this part of the theme doesn't show up on the imported theme (production site).
What's happening?
Should I export the theme with content?
(I don't want to modify the content on the production site...)
Mark
I've built a Themler theme for Wordpress in my **development** site. Everything works nice. I've exported the theme to a zip file (***without content***) and imported the zip file as a new theme in the **production** site. In my theme I'm using a slider with some slides but this part of the theme doesn't show up on the imported theme (**production** site). What's happening? Should I export the theme ***with content***? *(I don't want to modify the content on the production site...)* Regards, Mark
Hello Mark,
Seems like the slider is part of the content in your theme.
Could you please attach your theme with content here so we could check?
Hello Mark, Seems like the slider is part of the content in your theme. Could you please attach your theme with content here so we could check? Gina Themler Support
jansen.marcus
Hello Gina,
I've attached the theme with content.
Thanks for your support.
Mark
Hello Gina, I've attached the theme with content. Thanks for your support. Mark
Hello Mark,
The slider is in fact added to content area, you can see that there are two sections on the template: green and blue:
What is added to green area become part of this exact page content. It can be imported to Joomla or Wordpress only via Content Import. What is added to blue area becomes part of the template content. It means it is not editable in CMS but will also repeat of every page that is using this template.
Themler support
Hello Mark, The slider is in fact added to content area, you can see that there are two sections on the template: green and blue: !areas.png! What is added to green area become part of this exact page content. It can be imported to Joomla or Wordpress only via Content Import. What is added to blue area becomes part of the template content. It means it is not editable in CMS but will also repeat of every page that is using this template. Gina Themler support
jansen.marcus
Thanks Gina,
I Understand.
I'm going to redesign to solve this (my) problem.
Mark
Thanks Gina, I Understand. I'm going to redesign to solve this (my) problem. Regards, Mark
