default template
doganayemrah
doganayemrah posted this 2 weeks ago
hi,
how can I fix this problem?
hi, how can I fix this problem? Thank you
The Default Template is used for all components which have no other matching templates (Post, Page, Blog, etc). For example, Joomla Category List Layout, Login page, Contact Page, etc. will use Default Template
Also, the Default Template will be applied to the pages created by external Joomla components, except VirtueMart pages, which have their own Templates.
To turn on the Default Template, simply create a Menu Item of the chosen Type that has no other matching Template.
Note: The menu item should be accessible from the website front-end.
Hello, The Default Template is used for all components which have no other matching templates (Post, Page, Blog, etc). For example, Joomla Category List Layout, Login page, Contact Page, etc. will use Default Template Also, the Default Template will be applied to the pages created by external Joomla components, except VirtueMart pages, which have their own Templates. To turn on the Default Template, simply create a Menu Item of the chosen Type that has no other matching Template. Note: The menu item should be accessible from the website front-end. Sincerely, Nettie
