Themler not working - Drupal 8.8.0
vgonzalezborges
vgonzalezborges posted this 18 December 2019
Hello.
Yesterday I started to take up a project that I'm doing in Drupal 8x. I was able to work with Themler without any problem until I upgraded to version 8.8.0; the Themler module that allows me to edit the template doesn't work.
The problem is that I can not visualize any error, just shows me a blank screen that indicates that the site is not available at the moment.
What do you recommend me to do?
I will be attentive to your comments.
PS: I'm using a translator.
Greetings.
Hello. Yesterday I started to take up a project that I'm doing in **Drupal 8x.** I was able to work with Themler without any problem until I upgraded to **version 8.8.0;** the Themler module that allows me to edit the template doesn't work. The problem is that I can not visualize any error, just shows me a blank screen that indicates that **the site is not available at the moment.** What do you recommend me to do? I will be attentive to your comments. PS: I'm using a translator. Greetings.
Support Team posted this 17 January 2020
Hello Victor,
There is a known error with Drupal 8 and Themler, it is reported to the developers but not fixed yet. It may take some time.
Hello Victor, There is a known error with Drupal 8 and Themler, it is reported to the developers but not fixed yet. It may take some time. Gina Themler Support
Mitch
Mitch posted this 2 weeks ago
Probably will not get resolved at all, don't waste your time waiting, probably will have to move to "Joomla" thats what I had to do :(
NicePAge works great for Joomla
Probably will not get resolved at all, don't waste your time waiting, probably will have to move to "Joomla" thats what I had to do :( NicePAge works great for Joomla
vgonzalezborges
vgonzalezborges posted this 2 weeks ago
I have verified that the error originates when the private file system is activated. My project is an intranet, so I need to make use of the private files.
It has been a long time since I made this query, so I decided to continue my project with Galzed Theme. I had the same problem with this module, but support managed to fix the problem with an upgrade.
I have considered that I will only be able to use Themler for projects that do not require private archives.
Greetings.
I have verified that the error originates when the private file system is activated. My project is an intranet, so I need to make use of the private files. It has been a long time since I made this query, so I decided to continue my project with Galzed Theme. I had the same problem with this module, but support managed to fix the problem with an upgrade. I have considered that I will only be able to use Themler for projects that do not require private archives. Greetings.
