Server unavaiable, Server error?!
kostianev
kostianev posted this 20 December 2019
Hello, I got this message when I try to update my template: Server unavaiable, server error.
I need to update, because of beta Joomla update.
Hello, I got this message when I try to update my template: Server unavaiable, server error. I need to update, because of beta Joomla update.
11 Comments
Support Team posted this 20 December 2019
We are working at fixing the issue and will update this topic when it is fixed, really soon.
Hello, We are working at fixing the issue and will update this topic when it is fixed, really soon. Sincerely, Nettie
Could you please check if it works now for you?
If it doesn't. please, close Themler, and rename this folder on your computer C:\Users[user]\AppData\Local\Themler
Hello, Could you please check if it works now for you? If it doesn't. please, close Themler, and rename this folder on your computer C:\Users[user]\AppData\Local\Themler Gina Themler Support
trebuchet
trebuchet posted this 3 weeks ago
This problem is still prevalent. What are the issues?
Hi This problem is still prevalent. What are the issues?
The issue has been fixed. Have you tried the solution from the post above?
Hello, The issue has been fixed. Have you tried the solution from the post above? Sincerely, Nettie
mohammad_khazab
mohammad_khazab posted this 2 weeks ago
Hi, I'm also experiencing the same issue.
Unable to save theme. Server is unavailable.
I'm trying to update my customer's wordpress website but it doesn't Save the changes. please help me. What should I do?
Mo
Hi, I'm also experiencing the same issue. Unable to save theme. Server is unavailable. I'm trying to update my customer's wordpress website but it doesn't Save the changes. please help me. What should I do? Regards, Mo
Hello Mo,
Please try the following:
1) Open this URL in Chrome:
chrome://appcache-internals
2) Open this URL in Chrome:
Hello Mo, Please try the following: 1) Open this URL in Chrome: chrome://appcache-internals find your website and click on 'Remove Item' 2) Open this URL in Chrome: chrome://settings/clearBrowserData select 'Cached images and files ' and click on 'Clear Data' (please don't check other check-boxes). 3) Reload your Themler Editor. Sincerely, Nettie
gianes75
gianes75 posted this 6 days ago
Hello!
Same problem, ad clear cache was useless...
Thanks for your support.
Bruno
Hello! Same problem, ad clear cache was useless... Thanks for your support. Bruno
Hello Bruno,
Please try to temporarily disable third-party plugins for the website, as well as browser add-ons and any programs that may block access to the servers on your computer like antivirus or firewall.
Did you also try the renaming procedure from the second post in this topic?
Hello Bruno, Please try to temporarily disable third-party plugins for the website, as well as browser add-ons and any programs that may block access to the servers on your computer like antivirus or firewall. Did you also try the renaming procedure from the second post in this topic? Sincerely, Nettie
gianes75
gianes75 posted this 5 days ago
Hello Nettie,
nothing to do...i've disabled av too. The problem is the same from browser and from standalone version with non 3rd part add-ons.
Any ideas?
Thanx.
Bruno
Hello Nettie, nothing to do...i've disabled av too. The problem is the same from browser and from standalone version with non 3rd part add-ons. Any ideas? Thanx. Bruno
gianes75
Sorry, i've renamed the folder too...
Support Team posted this 4 days ago
Server issue can happen if there is something blocking the connection to our server: like proxy, firewall, antivirus. All such security programs should be disabled.
If this doesn't help, please follow the steps below:
Server issue can happen if there is something blocking the connection to our server: like proxy, firewall, antivirus. All such security programs should be disabled. If this doesn't help, please follow the steps below: 1. Backup all theme folders somewhere on your computer if there are any. The path is shown in the Theme Management screen after selecting some CMS, for example, C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\wordpress. 2. Uninstall Themler completely and also check the box for "Remove all CMS content". 3. Check if the following folders are still present: C:\Program Files (x86)\Themler C:\ProgramData\Themler 4. If they exist, remove them. 5. Reboot the machine after uninstalling Themler, so that all Themler services are removed for sure. 6. Temporarily disable antivirus and firewall. 7. Download latest version of Themler for Windows from themler.io, install it and try to start with Themler for any CMS and create a theme. Please let us know the result. Gina Themler Support
