Themler already opened in another tab
enyonam
enyonam posted this 3 weeks ago
My theme won't open. I always get the error Themler is already opened in another tab even though it is not. My version is 478.
8 Comments
SH707
SH707 posted this 3 weeks ago
Clear cookies and cache in your browser, always works for me
  1. If you shared access to Themler with anyone, make sure it is no longer used.
  2. Try suggestion above: clear cookies and cache in all your browsers for this site.
  3. You can also try updating password for Themler account.
Hello, 1. If you shared access to Themler with anyone, make sure it is no longer used. 2. Try suggestion above: clear cookies and cache in all your browsers for this site. 3. You can also try updating password for Themler account. Gina Themler Support
enyonam
I have cleared the cache in all my browsers. I have had this problem for 3 months now and I have tried all the suggestions found in Themler forums including disabling browser extensions and clearing opcache. I don't share Themler access with anyone and I only access Themler from my laptop and nowhere else. What else could be wrong?
> Hello, > > 1. If you shared access to Themler with anyone, make sure it is no longer used. > 2. Try suggestion above: clear cookies and cache in all your browsers for this site. > 3. You can also try updating password for Themler account. > > Gina > Themler Support I have cleared the cache in all my browsers. I have had this problem for 3 months now and I have tried all the suggestions found in Themler forums including disabling browser extensions and clearing opcache. I don't share Themler access with anyone and I only access Themler from my laptop and nowhere else. What else could be wrong?
Try changing your password, restart your computer and check if it works then.
Also try opening Themler editor without having live site frontend opened.
Try changing your password, restart your computer and check if it works then. Also try opening Themler editor without having live site frontend opened. Gina
enyonam
Hello, As suggested, I did change my password and it worked for one site. I edited the theme and saved it and quit themler. I then tried to open another site's them and i got the error again. Does it mean I have to change the password each time?
> Try changing your password, restart your computer and check if it works then. > Also try opening Themler editor without having live site frontend opened. > > Gina Hello, As suggested, I did change my password and it worked for one site. I edited the theme and saved it and quit themler. I then tried to open another site's them and i got the error again. Does it mean I have to change the password each time?
Have you please tried to clear AppCache for Themler and then browser cache?
Hello, Have you please tried to clear AppCache for Themler and then browser cache? Sincerely, Nettie
philippe.t
philippe.t posted this 2 weeks ago
I have the same pb, i can not access to the themler
And i applicate the differents solutions clear the cache and appcache and change the password of themler account and password of joomla = no change
message:
You already opened Themler in another tab
As Themler cannot work in multiple tabs at the same time, the current instance will be closed.
Themler will continue working in the last opened tab.
With Devtools of google chrome , in Console we have:
[Deprecation] Application Cache API manifest selection is deprecated and will be removed in M82, around April 2020. See https://www.chromestatus.com/features/6192449487634432 for more details.
index.php?option=com_templates&view=style&layout=edit&id=17&editor=1&theme=themler&ver=496:1 Document was loaded from Application Cache with manifest https://www.domainename/templates/manifests/manifest.php?ver=496
index.php?option=com_templates&view=style&layout=edit&id=17&editor=1&theme=themler&ver=496:1 Application Cache Checking event
index.php?option=com_templates&view=style&layout=edit&id=17&editor=1&theme=themler&ver=496:1 Application Cache NoUpdate event
Refused to execute script from 'https://www.domainname/templates/themler/app/start/auth.php?uid=382&version=7945a8d70994aabe544545d780b375c1' because its MIME type ('text/html') is not executable, and strict MIME type checking is enabled.
and
JQMIGRATE: Migrate is installed, version 1.4.1 is repeated
Have you another solutions please ?
Philippe
Hello, I have the same pb, i can not access to the themler And i applicate the differents solutions clear the cache and appcache and change the password of themler account and password of joomla = no change message: You already opened Themler in another tab Themler is already opened in another tab As Themler cannot work in multiple tabs at the same time, the current instance will be closed. Themler will continue working in the last opened tab. With Devtools of google chrome , in Console we have: [Deprecation] Application Cache API manifest selection is deprecated and will be removed in M82, around April 2020. See https://www.chromestatus.com/features/6192449487634432 for more details. index.php?option=com_templates&view=style&layout=edit&id=17&editor=1&theme=themler&ver=496:1 Document was loaded from Application Cache with manifest https://www.domainename/templates/manifests/manifest.php?ver=496 index.php?option=com_templates&view=style&layout=edit&id=17&editor=1&theme=themler&ver=496:1 Application Cache Checking event index.php?option=com_templates&view=style&layout=edit&id=17&editor=1&theme=themler&ver=496:1 Application Cache NoUpdate event Refused to execute script from 'https://www.domainname/templates/themler/app/start/auth.php?uid=382&version=7945a8d70994aabe544545d780b375c1' because its MIME type ('text/html') is not executable, and strict MIME type checking is enabled. and JQMIGRATE: Migrate is installed, version 1.4.1 is repeated Have you another solutions please ? Regards Philippe
Hello Philippe,
Where does the issue appear in your case - with Themler on your website or with Themler desktop? Does it happen in Chrome and Firefox?
Hello Philippe, Where does the issue appear in your case - with Themler on your website or with Themler desktop? Does it happen in Chrome and Firefox? Sincerely, Nettie
