W3C Validator
Seppe
Seppe posted this 3 weeks ago
Good morning
After checking a lot of my websites, I have a still returning error, especially while using sections:
Warning: Section lacks heading. Consider using h2-h6 elements to add identifying headings to all sections.
< section class id data-section-title>
Any suggestion to fix this?
greetings
Good morning After checking a lot of my websites, I have a still returning error, especially while using sections: > Warning: Section lacks heading. Consider using h2-h6 elements to add identifying headings to all sections. > &lt; section class id data-section-title&gt; Any suggestion to fix this? greetings
Vitaliy WD
Vitaliy WD posted this 3 weeks ago
Hi.
So, try to add H2-H3 headings to you sections. This also will increase your SEO.
Hi. So, try to add H2-H3 headings to you sections. This also will increase your SEO.
Seppe
Hi Vitaly
It seems like a part of my code is removed by default.
this is the code that automatically is generated by themler, and which gives the error:
(I added some blanks and _, so the code will not be stripped)
<section class=" bd-section-4 bd-tagstyles" id="section3" data-section-title="topbanner">
So I think it has something to do with the "bd-section" and "bd-tagsyles".
Hi Vitaly It seems like a part of my code is removed by default. this is the code that automatically is generated by themler, and which gives the error: (I added some blanks and _, so the code will not be stripped) <section class=" bd-section-4 bd-tagstyles" id="section3" data-section-title="topbanner"> So I think it has something to do with the "bd-section" and "bd-tagsyles".
Vitaliy WD
Hello.
This is not error, just a warning. The main reason is that each section on page must have heading (about what this section). Like each Page have heading.
So right after this code (or in module/widget that in this section) add this code (heading):
<h2>Write your heading here</h2>
Do it for all Sections and test again.
<p>Your content</p>
</section>
According to W3C's HTML5 documentation: "A section is a thematic grouping of content, typically with a heading."
For example, a home page could normally be split into sections for introduction, content, and contact information.
About Headings: https://www.w3schools.com/html/html_headings.asp
About Semantic Elements: https://www.w3schools.com/html/html5_semantic_elements.asp
Need to know some basics if you want W3C validation :)
Hello. This is not error, just a warning. The main reason is that each section on page must have heading (about what this section). Like each Page have heading. So right after this code (or in module/widget that in this section) add this code (heading): <h2>Write your heading here</h2> Do it for all Sections and test again. <section class=" bd-section-4 bd-tagstyles" id="section3" data-section-title="topbanner"> <h2>Write your heading here</h2> <p>Your content</p> </section> According to W3C's HTML5 documentation: "A section is a thematic grouping of content, **typically with a heading**." For example, a home page could normally be split into sections for introduction, content, and contact information. About Headings: https://www.w3schools.com/html/html_headings.asp About Semantic Elements: https://www.w3schools.com/html/html5_semantic_elements.asp Need to know some basics if you want W3C validation :)
Seppe
Thanks for the info.
I know aboud headings and stuff, but I didn't know I had to add it also in the sections.
Probably I have a lot of updating to do :)
Thanks for the info. I know aboud headings and stuff, but I didn't know I had to add it also in the sections. Probably I have a lot of updating to do :)
As Vitaliy mentioned, this is a warning, mostly related to SEO purposes.
I will forward this to the developers but this won't be a top priority issue.
Please, consider adding headings manually. We apologize for the inconveniences caused.
Hello, As Vitaliy mentioned, this is a warning, mostly related to SEO purposes. I will forward this to the developers but this won't be a top priority issue. Please, consider adding headings manually. We apologize for the inconveniences caused. Gina Themler Support
