joomla: Head script as very first script?
Pitter
Pitter posted this 2 weeks ago
I have problems using cookie solution cookiebot in automatic mode.
Where can I place a script at very first position in the <head> - before template is called?
When I call the script for cookiebot inside the template, the cookiebot script isn't the first script.
Pitter
I have problems using cookie solution cookiebot in automatic mode. Where can I place a script at very first position in the &lt;head&gt; - before template is called? When I call the script for cookiebot inside the template, the cookiebot script isn&#39;t the first script. Pitter
Hello Pitter,
You may add this code from the Home tab >> Settings>> Additional HEAD Html.
Hello Pitter, You may add this code from the Home tab >> Settings>> Additional HEAD Html. Sincerely, Nettie
Pitter
There I have already placed my script, but so the template with own scripts is called earlier.
Can I place it directly i.e. inside an index.php ?
Hello, There I have already placed my script, but so the template with own scripts is called earlier. Can I place it directly i.e. inside an index.php ?
You can edit index.php directly manually after the template is exported in Joomla -> Templates -> Styles -> open your theme.
You may need to check all files under "templates"subfolder (blog.php, front-page, etc.).
Please, note that in this case the changes will overridden when the theme is updated from Themler.
You can edit index.php directly manually after the template is exported in Joomla -> Templates -> Styles -> open your theme. You may need to check all files under "templates"subfolder (blog.php, front-page, etc.). Please, note that in this case the changes will overridden when the theme is updated from Themler. Gina Themler Support
