Frontend editing in Joomla conflicting with Captcha
GT-WebDesign
GT-WebDesign posted this 14 January 2020
Hi there,
If Captcha is enabled in Global configuration and the plugin Recaptcha V2 or V3 are properly configured , I found a Captcha conflict that makes it impossible to save the frontend edited article. Message is Empty Captcha code is not allowed.
Modules and menu frontend editing is normal.
Can anyone please help me with this issue?
Regards Ger
Hi there, If Captcha is enabled in Global configuration and the plugin Recaptcha V2 or V3 are properly configured , I found a Captcha conflict that makes it impossible to save the frontend edited article. Message is Empty Captcha code is not allowed. Modules and menu frontend editing is normal. Can anyone please help me with this issue? Regards Ger
Support Team posted this 14 January 2020
Hello Ger,
Does same issue happen if you switch to standard Joomla template?
Hello Ger, Does same issue happen if you switch to standard Joomla template? Gina Themler Support
GT-WebDesign
No with the Joomla template it works fine
GT-WebDesign
GT-WebDesign posted this 16 January 2020
Hallo Gina,
Will you please reply,?
Regards Ger
Hallo Gina, Will you please reply,? Regards Ger
Support Team posted this 16 January 2020
Ger,
I have reported this to the developers but I don't have any answer yet. For now the only option is to disable Captcha for the time the articles are edited via frontend.
Ger, I have reported this to the developers but I don't have any answer yet. For now the only option is to disable Captcha for the time the articles are edited via frontend. Gina Themler Support
GT-WebDesign
Thanks Gina
Thanks Gina
GT-WebDesign
GT-WebDesign posted this 5 weeks ago
Hi Gina,
Do you have an answer yet from the developers about this issue?
Regards Ger
Hi Gina, Do you have an answer yet from the developers about this issue? Regards Ger
GT-WebDesign
GT-WebDesign posted this 4 weeks ago
Will someone from support please reply?
