Mobile resonsive view effecting the layout of desktop view
jay.brown
jay.brown posted this 6 days ago
Every time I edit my template for mobile view, it effects my desktop view and pushes everything out.
Is there a fix for this? Am I doing it wrong, or is this a known issue?
I'm using Themler for Joomla.
Every time I edit my template for mobile view, it effects my desktop view and pushes everything out. Is there a fix for this? Am I doing it wrong, or is this a known issue? I'm using Themler for Joomla. Thanks
Support Team posted this 5 days ago
Hello Jay,
Not all controls are shared between responsive views. Some settings (as margins, padding) can be set separately for different views, some may be single for all views. Unfortunately, I can't give you the list of shared controls though, it depends on specific design you create.
Sometimes when you can't position a block (section, cell, container) for all views as you need, you may want to make different blocks: create one for desktop and hide it for mobile view.
Hello Jay, Not all controls are shared between responsive views. Some settings (as margins, padding) can be set separately for different views, some may be single for all views. Unfortunately, I can't give you the list of shared controls though, it depends on specific design you create. Sometimes when you can't position a block (section, cell, container) for all views as you need, you may want to make different blocks: create one for desktop and hide it for mobile view. Gina Themler Support
