header animation proposal
benjamin_roehling
benjamin_roehling posted this 2 weeks ago
hi!
I didn't find where to set the header animations to just one time (that is, after the home-page has been loaded).
currently it animates after each and every link has been clicked.
hi! I didn't find where to set the header animations to just one time (that is, after the home-page has been loaded). currently it animates after each and every link has been clicked.
Hello Benjamin,
I assume you have set the animation to launch on load. This indeed would launch it on every page load, not only Home page. I will forward your suggestion to the developers.
Themler does have the option to have some different styles on Home page only (like background, for example), but animation is common for all pages.
Hello Benjamin, I assume you have set the animation to launch on load. This indeed would launch it on every page load, not only Home page. I will forward your suggestion to the developers. Themler does have the option to have some different styles on Home page only (like background, for example), but animation is common for all pages. Gina Themler Support
benjamin_roehling
I like updates 😂
do you have a plan for the next update release (when it occurs)?
I'm not interested in fancy restaurants at this time but in CSS Animation magic. does themler have an interface to enter CSS Animations?
the only connector I see is the. html module. there I can enter css code.
another thing is, modifying outside of themler. you know I don't have anything against hacking, but things get complicated, if I 1) complete a themler template 2) modify code manually outside of themler 3) customer wants to have changes in the template (working again inside themler). then the modifications would be lost.
I like updates 😂 do you have a plan for the next update release (when it occurs)? I'm not interested in fancy restaurants at this time but in CSS Animation magic. does themler have an interface to enter CSS Animations? the only connector I see is the. html module. there I can enter css code. another thing is, modifying outside of themler. you know I don't have anything against hacking, but things get complicated, if I 1) complete a themler template 2) modify code manually outside of themler 3) customer wants to have changes in the template (working again inside themler). then the modifications would be lost.
1) No timeline for the next release yet, unfortunately.
2) You have described two methods I was going to suggest: through HTML control and after the export.
You are right - changes get lost with next theme update, but you can try to find some extension or plugin that would provide the desired effect, instead of editing the code.
1) No timeline for the next release yet, unfortunately. 2) You have described two methods I was going to suggest: through HTML control and after the export. You are right - changes get lost with next theme update, but you can try to find some extension or plugin that would provide the desired effect, instead of editing the code. Gina Themler Support
benjamin_roehling
oki.
I'm making a pause.
have a nice weekend.
oki. I'm making a pause. have a nice weekend.
