menu anchors in a blogpage
arawolf
arawolf posted this 2 weeks ago
Is there a way to import anchors in a blogtemplate. So when i click on the menu item ( te the blogpage) i don't see the header but immediately the postsection.
You may try it int eh way described in this article:
http://answers.themler.io/articles/5581/one-page-design-in-wordpress
Hello, You may try it int eh way described in this article: http://answers.themler.io/articles/5581/one-page-design-in-wordpress Sincerely, Nettie
arawolf
it s a joomla site
it s a joomla site
In Joomla it is also possible:
http://answers.themler.io/articles/5582/one-page-design-in-joomla
Hello, In Joomla it is also possible: http://answers.themler.io/articles/5582/one-page-design-in-joomla Sincerely, Nettie
arawolf
arawolf posted this 1 weeks ago
sorry it's a blog menu type
sorry it's a **blog menu** type
Support Team posted this 5 days ago
Kris, we would need clarifications on this.
You are talking about Blog Template, correct?
If you click a menu item on a Blog Template, it should scroll down to the article on the same page, without header being visible?
An example would help.
Themler support
Kris, we would need clarifications on this. You are talking about Blog Template, correct? If you click a menu item on a Blog Template, it should scroll down to the article on the same page, without header being visible? An example would help. Gina Themler support
arawolf
arawolf posted this 5 days ago
hello... domein test-ararin.be/test1 menu items nieuws and klanten. can i maybe import 2 blogs on 1 onepagetemplate .
you will see that on the nieuws item the header is visible and also on the klanten item.
hello... domein test-ararin.be/test1 menu items nieuws and klanten. can i maybe import 2 blogs on 1 onepagetemplate . you will see that on the nieuws item the header is visible and also on the klanten item.
Could you please try making the News menu item go to this URL https://test-ararin.be/test1/index.php/nl/nieuws#ararin ?
Or you can add this CSS code to Home -> Settings -> Additional CSS, though you would need to check afterwards that only these two pages are affected:
.bd-body-5 .bd-slider-2 {
display:none!important;
Could you please try making the News menu item go to this URL https://test-ararin.be/test1/index.php/nl/nieuws#ararin ? Or you can add this CSS code to Home -> Settings -> Additional CSS, though you would need to check afterwards that only these two pages are affected: .bd-body-5 .bd-slider-2 { display:none!important; } Gina Themler Support
