Bootstrap Column ordering
Stagger Lee posted this 14 August 2015
http://getbootstrap.com/css/#grid-column-ordering
Can you make options for Bootstrap Columns ordering ? It is already in the code.
It would solve some longstanding (Artisteer) problems.
One of them is making left sidebar go under content on some small devices, resposive behaviour. Bootstrap support this.
https://scotch.io/tutorials/reorder-css-columns-using-bootstrap
[http://getbootstrap.com/css/#grid-column-ordering][1] Can you make options for Bootstrap Columns ordering ? It is already in the code. It would solve some longstanding (Artisteer) problems. One of them is making left sidebar go under content on some small devices, resposive behaviour. Bootstrap support this. [https://scotch.io/tutorials/reorder-css-columns-using-bootstrap][2] [1]: http://getbootstrap.com/css/#grid-column-ordering [2]: https://scotch.io/tutorials/reorder-css-columns-using-bootstrap
10 Comments
Some image. And much more magic is possible with those options.
http://attachments.answers.billiondigital.com/998/3998/2015-08-15-015650.jpg
Some image. And much more magic is possible with those options. ![http://attachments.answers.billiondigital.com/998/3998/2015-08-15-015650.jpg][1] [1]: http://attachments.answers.billiondigital.com/998/3998/2015-08-15-015650.jpg
Stagger Lee posted this 15 August 2015
http://answers.themler.com/questions/18701/feature-requests
[http://answers.themler.com/questions/18701/feature-requests][1] [1]: http://answers.themler.com/questions/18701/feature-requests
shaulhadar
shaulhadar posted this 15 August 2015
This is a really important feature!
I am struggling very much when someone wants left menu.
This problem needs to be addressed urgently and still remains problem of responsive menu showing in Tablet mode. This way I could hide left menu on some devices and show responsive menu (hidden top menu) on some devices.
I am using this code, but behave strange and count windows scroll width inside, so it is not consistent.
<pre class>&lt;script type="text/javascript"&gt;
jQuery(window).resize(function(){
if (jQuery(window).width() &lt;= 580){
jQuery(document).ready(function() {
jQuery('div.some-sidebar1').insertAfter('div.some-content');
&lt;/script&gt;</pre>
I am struggling very much when someone wants left menu. This problem needs to be addressed urgently and still remains problem of responsive menu showing in Tablet mode. This way I could hide left menu on some devices and show responsive menu (hidden top menu) on some devices. I am using this code, but behave strange and count windows scroll width inside, so it is not consistent. &lt;pre class&gt;&amp;lt;script type=&quot;text/javascript&quot;&amp;gt; jQuery(window).resize(function(){ if (jQuery(window).width() &amp;lt;= 580){ jQuery(document).ready(function() { jQuery(&#39;div.some-sidebar1&#39;).insertAfter(&#39;div.some-content&#39;); }); } }); &amp;lt;/script&amp;gt;&lt;/pre&gt;
Support Team posted this 17 August 2015
Hello Stagger Lee,
thank you for your suggestion and related details you provided.
Lets vote for this feature.
Hello Stagger Lee, thank you for your suggestion and related details you provided. Lets vote for this feature. Regards, Aileen
Support Team posted this 25 December 2015
We implemented Columns Ordering feature using FlexBox Order attribute.
For example, look at this Section:
http://templates.themler.com/Themes/Detail/2636029/Design-Six-Columns
By default, Tablet Responsive mode does not look as cool as Desktop mode.
To make it look better we need to re-order two columns/cells.
For this we added Column >> Arrange >> Order property.
Themler Team
Hi, We implemented Columns Ordering feature using FlexBox Order attribute. For example, look at this Section: http://templates.themler.com/Themes/Detail/2636029/Design-Six-Columns By default, Tablet Responsive mode does not look as cool as Desktop mode. To make it look better we need to re-order two columns/cells. For this we added **Column** >> **Arrange** >> **Order** property. !columns-order1.png! !columns-order2.png! !columns-order3.png! Thank you, Themler Team
Stagger Lee posted this 25 December 2015
Thank you. Very needed option.
For other users. You can put left sidebar, content area, right sidebar, in one row with 3 columns. And still have vertical menu inside right sidebar and on the top when viewing in smartphones. Not under content.
Maybe problem are things under vertical menu in right sidebar. But, all is possible with Themler, just use your imagination. Layout is up to you how you will make it.
Thank you. Very needed option. For other users. You can put left sidebar, content area, right sidebar, in one row with 3 columns. And still have vertical menu inside right sidebar and on the top when viewing in smartphones. Not under content. Maybe problem are things under vertical menu in right sidebar. But, all is possible with Themler, just use your imagination. Layout is up to you how you will make it.
shaulhadar
shaulhadar posted this 25 December 2015
Thats great!! Thanks for the explanation, i was wandering what is this option for actually.
jurjen
jurjen posted this 03 January 2016
I have added flex-order to the phone design for the magento-theme to a row. But no order change is occurring.
I see the order: 1, 2,3 in the css apearing when scaling to a phone size.
What am I doing wrong?
Jurjen
Hi, I have added flex-order to the phone design for the magento-theme to a row. But no order change is occurring. I see the order: 1, 2,3 in the css apearing when scaling to a phone size. What am I doing wrong? Regards Jurjen
jurjen
I figured it out. You need to set the row-heigth to flexbox. Only then does it work.
Jurjen
Hi, I figured it out. You need to set the row-heigth to flexbox. Only then does it work. Regards Jurjen
