custom save path
stany.berden
stany.berden posted this 16 August 2015
I really see the need te save the templates to a custom location.
Where can i find the project files ??
What if i wont to backup my source files or reopen them on my laptop ?
I really see the need te save the templates to a custom location. Where can i find the project files ?? What if i wont to backup my source files or reopen them on my laptop ?
21 Comments
Support Team posted this 17 August 2015
You mean the templates that are saved in the desktop version? They are saved in the Downloads folder by the default. To change that path, right click on the Themler top bar, choose the Open browser window option, then in the new window go to Settings >> Show Advanced Settings >> Downloads and choose the new folder or use the Ask where to save option.
Hi, You mean the templates that are saved in the desktop version? They are saved in the Downloads folder by the default. To change that path, right click on the Themler top bar, choose the Open browser window option, then in the new window go to *Settings >> Show Advanced Settings >> Downloads* and choose the new folder or use the Ask where to save option. Sincerely, Hella BillionDigital Team
stany.berden
stany.berden posted this 17 August 2015
That is not what i mean, How can i save a temlplate from my desktop to continue editing it from my laptop ?
For example artisteer has .artx source files. How is this in themler ?
That is not what i mean, How can i save a temlplate from my desktop to continue editing it from my laptop ? For example artisteer has .artx source files. How is this in themler ?
You can download the template as .zip and then import that .zip file in the application on your laptop.
Hi, You can download the template as .zip and then import that .zip file in the application on your laptop. Sincerely, Hella BillionDigital Team
stany.berden
ok thanks
ok thanks
stany.berden
stany.berden posted this 19 August 2015
I have a feeling there is some work ahead before themler is going to be as successful ad artisteer.
The product has allot of potential, and give you more freedom then artisteer, but at the moment, i find it very hard to work with.
I just exported a theme as zip, when i try to import this theme themler message is "only themler themes are supported "
Bump ??
Hi, I have a feeling there is some work ahead before themler is going to be as successful ad artisteer. The product has allot of potential, and give you more freedom then artisteer, but at the moment, i find it very hard to work with. I just exported a theme as zip, when i try to import this theme themler message is "only themler themes are supported " Bump ??
GuPatrolOh3
GuPatrolOh3 posted this 19 August 2015
And where does it save to? The older version I could find it, updated and god knows where the zip is, all i now have is a Themler white screen of death.
I think this program needs some work, beta or alpha still?
And where does it save to? The older version I could find it, updated and god knows where the zip is, all i now have is a Themler white screen of death. I think this program needs some work, beta or alpha still?
Support Team posted this 19 August 2015
@stany.berden
Please attach that .zip file so we could test and let us know what CMS type you have used.
@Jason Keys
Please create a private topic and attach the log file from the Start >> Themler >> Themler Diagnostics Tool. Also describe in more details what the steps were performed before the white screen appeared.
Regarding the saving path, please follow the instructions from my first post in this case.
Hi, @stany.berden Please attach that .zip file so we could test and let us know what CMS type you have used. @Jason Keys Please create a private topic and attach the log file from the Start >> Themler >> Themler Diagnostics Tool. Also describe in more details what the steps were performed before the white screen appeared. Regarding the saving path, please follow the instructions from my first post in this case. Sincerely, Hella BillionDigital Team
stany.berden
Zip file in attachement.
As i already mentioned, Themler has allot potentiol and i really want to use it :)
good luck guys
Zip file in attachement. As i already mentioned, Themler has allot potentiol and i really want to use it :) good luck guys
Support Team posted this 20 August 2015
the theme was saved without option 'Include Themler for customizing this theme' enabled.
Unfortunately this theme cannot be opened in Themler anymore. That's why you get the warning message "only themler themes are supported "
Hello, the theme was saved without option 'Include Themler for customizing this theme' enabled. Unfortunately this theme cannot be opened in Themler anymore. That's why you get the warning message "only themler themes are supported " Regards, Aileen
stany.berden
stany.berden posted this 20 August 2015
When i try to save with option 'Include Themler for customizing this theme' enabled.
I get the following error
see attachement
When i try to save with option 'Include Themler for customizing this theme' enabled. I get the following error see attachement
Support Team posted this 21 August 2015
Have you checked the folder permissions as mentioned in the message you have attached?
Hi, Have you checked the folder permissions as mentioned in the message you have attached? Sincerely, Hella BillionDigital Team
stany.berden
stany.berden posted this 21 August 2015
User and group has all the rights
Support Team posted this 24 August 2015
Hi stany.berden,
Our developers have reported this this issue with be fixed in the upcoming Themler update.
Hi stany.berden, Our developers have reported this this issue with be fixed in the upcoming Themler update. Thank you, Olivia
stany.berden
stany.berden posted this 28 August 2015
I got the update yesterday, but still a permissions issue
Support Team posted this 31 August 2015
Next day we updated Themler again. Does the issue continue?
Hi, Next day we updated Themler again. Does the issue continue? Thank you, Olivia
stany.berden
stany.berden posted this 31 August 2015
Still got the same error message aftre the latest update
Support Team posted this 02 September 2015
Could you please update theme (we have updated Themler today), archive the following folder and attach it to this topic?
c:\ProgramData\Themler\hd_data\themler_[numbers]\drupal\sites\all
Hi, Could you please update theme (we have updated Themler today), archive the following folder and attach it to this topic? <tt>c:\ProgramData\Themler\hd_data\themler_[numbers]\drupal\sites\all</tt> Thank you, Olivia
stany.berden
stany.berden posted this 02 September 2015
see attachement
see attachement
Support Team posted this 03 September 2015
I've assigned a task to our developers.
We'll let know when we receive any news from them.
Hi, Thank you, I've assigned a task to our developers. We'll let know when we receive any news from them. Thank you, Olivia
Support Team posted this 04 September 2015
Please follow the next steps to fox it on your side:
  • Download the latest Themler Desktop from our website.
  • Copy C:\ProgramData\Themler\hd_data\themler_[numbers]\drupal\sites\all\themes\ to your hard drive to make a backup.
  • Install the latest Themler update with "Remove CMS Content" option enabled.
    Please note that this option will remove CMS content too.
  • Launch Themler Desktop and start Drupal
  • Upload backups of the themes to C:\ProgramData\Themler\hd_data\themler_[numbers]\drupal\sites\all\themes\
  • open the following URL in browser and clear cache:
    http://127.0.0.1:12080/themler_[numbers]/drupal/admin/config/development/performance
    Please note that you should replace themler_[numbers] with real directory name.
  • Re-start Themler.
You should now see all your themes. Please let us know if permissions issue continues.
Hello Please follow the next steps to fox it on your side: - Download the latest Themler Desktop from our [website][1]. [1]: http://themler.com - Copy <tt>C:\ProgramData\Themler\hd_data\themler_[numbers]\drupal\sites\all\themes\</tt> to your hard drive to make a backup. - Install the latest Themler update with **"Remove CMS Content"** option enabled. Please note that this option will remove CMS content too. - Launch Themler Desktop and start Drupal - Upload backups of the themes to <tt>C:\ProgramData\Themler\hd_data\themler_[numbers]\drupal\sites\all\themes\</tt> - open the following URL in browser and clear cache: <tt>http://127.0.0.1:12080/themler_[numbers]/drupal/admin/config/development/performance</tt> Please note that you should replace **themler_[numbers]** with real directory name. - Re-start Themler. You should now see all your themes. Please let us know if permissions issue continues. Thank you, Olivia
