How to disable linked images (lightbox?)
john.oxlade
john.oxlade posted this 19 August 2015
Probably me doing something simple (and wrong), but in my Joomla articles, clicking on images opens them in a lightbox - which I don't want. I want to be able to link the images, but the lightbox feature seems to take precedence.
How do I turn it off?
(I started with the default them/template and have been modifying it as I go)
Thanks.
Probably me doing something simple (and wrong), but in my Joomla articles, clicking on images opens them in a lightbox - which I don't want. I want to be able to link the images, but the lightbox feature seems to take precedence. How do I turn it off? (I started with the default them/template and have been modifying it as I go) Thanks.
48 Comments
Darkie
Darkie posted this 19 August 2015
I have the same problem.
It seemed to be working earlier on.
I have the same problem. It seemed to be working earlier on.
pawel.neografix
Is Solution
pawel.neografix posted this 19 August 2015
You can turn this off: Posts / Post Content / Image Lightbox - on/off.
john.oxlade
john.oxlade posted this 20 August 2015
Perfect, thanks.
Perfect, thanks.
Darkie
Darkie posted this 20 August 2015
I've been looking everywhere .... but there ;)
Thanks!
I've been looking everywhere .... but there ;) Thanks!
pixelMEDIAlab
pixelMEDIAlab posted this 25 August 2015
I try this, but it dosn´t work. By clicking on images opens them always in a lightbox.
> You can turn this off: Posts / Post Content / Image Lightbox - on/off. I try this, but it dosn´t work. By clicking on images opens them always in a lightbox.
Support Team posted this 26 August 2015
Hello Mattias,
please try to turn off lightbox here
Hello Mattias, please try to turn off lightbox here !ImgLightbox.png! regards, Aileen
RobR
RobR posted this 31 August 2015
I cant find how to disable it for pages too?
Pierre665
Pierre665 posted this 01 September 2015
I disable lightbox option but I still have the same problem.
After a first normally closed popup on an image, another lightbox displays.
Thanks for your help.
Hello, I disable lightbox option but I still have the same problem. After a first normally closed popup on an image, another lightbox displays. Thanks for your help.
Support Team posted this 03 September 2015
@RobR,
I'm not sure what exactly you mean. To disable lightbox for Images which are output on Posts please follow the solution provided above.
If you mean Image control then no lightbox option is available for it.
Could you describe your question in more details?
@Pierre,
are you using any lightbox plugin on your site? if yes please try to disable it and see if it helps. If it's no a problem then please submit a new private topic and provide access to your Joomla admin back end so we could test your theme. Also note what page demonstrates the issue.
@**RobR,** I'm not sure what exactly you mean. To disable lightbox for Images which are output on Posts please follow the solution provided above. If you mean Image control then no lightbox option is available for it. Could you describe your question in more details? @**Pierre,** are you using any lightbox plugin on your site? if yes please try to disable it and see if it helps. If it's no a problem then please submit a new private topic and provide access to your Joomla admin back end so we could test your theme. Also note what page demonstrates the issue. Regards, Aileen
Nate
Nate posted this 09 September 2015
This still does not work. I'm using Joomla 3.4.1 and every image opens lightbox. When I switch to Protostar built-in template the links work fine. When I switch to the one I created in Themler - the lightbox is back. The Lightbox setting is turned off, and I have saved and reexported the theme and reinstalled several time now. I have also cleared my cache - does not work.
eduard.adrian.stan
eduard.adrian.stan posted this 10 September 2015
Same problem for me also
wuzelina
wuzelina posted this 12 September 2015
I have the same issue even with email icon which is linked to an email. The link doesn't open a new email, it always opens the icon in a lightbox.
This happens with other article images as well.
http://web791.login-4.loginserver.ch/uber-uns/
Is this a template setting, how can I remove that?
thanks a lot for your help. Let me know if you need back end access to the wordpress site.
I have the same issue even with email icon which is linked to an email. The link doesn't open a new email, it always opens the icon in a lightbox. This happens with other article images as well. http://web791.login-4.loginserver.ch/uber-uns/ Is this a template setting, how can I remove that? thanks a lot for your help. Let me know if you need back end access to the wordpress site.
Support Team posted this 15 September 2015
Hello guys,
please submit new separate Private topics http://answers.billiondigital.com/Topic/Create?private=1 and provide access to your CMS admin back ens so we could check your themes.
Your cooperation is greatly appreciated.
Hello guys, please submit new separate Private topics http://answers.billiondigital.com/Topic/Create?private=1 and provide access to your CMS admin back ens so we could check your themes. Your cooperation is greatly appreciated. regards, Aileen
Nate
Nate posted this 21 September 2015
Ok I have submitted a private question - I need to get this resolved ASAP. We have clients waiting on sites because none of their images that are link work.
Nate
I have noticed if I select "open in new tab" the links work.
Chae_Riley
Chae_Riley posted this 09 November 2015
I submitted a Private reply to this thread but can't finds it anywhere :(
Anyway I managed to resolve the problem and the images with a Joomla article now no longer open up in lightbox and work as should be with a link applied.
I submitted a Private reply to this thread but can't finds it anywhere :( Anyway I managed to resolve the problem and the images with a Joomla article now no longer open up in lightbox and work as should be with a link applied.
Morpheus0101
Morpheus0101 posted this 13 November 2015
I managed to solve this. Hope this helps.
If you have tried the above and found it does not work, try the following:
1. Navigate to a 'Page' (not a post), within Themler,
2. Click on one of the images you are having problems with
3. Finally, choose 'Post Content' from the icons on the left control panel and turn off 'image Lightbox'
I trust you are having the same problem as me, as the previous suggestions did not work for me either, but this does.
I think this is either a bug, a process that is a little confusing in itself. Perhaps there should be a separate Lightbox control under Pages and Posts (assuming the process provided above by Support works for Posts - have not tried this yet as I am not using Posts). It is a bit of a shame that the control is all or nothing. Would be great if we could choose per page, or if a Shortcode could be used to activate this. Perhaps something for the next update maybe?
I managed to solve this. Hope this helps. If you have tried the above and found it does not work, try the following: 1. Navigate to a 'Page' (not a post), within Themler, 2. Click on one of the images you are having problems with 3. Finally, choose 'Post Content' from the icons on the left control panel and turn off 'image Lightbox' I trust you are having the same problem as me, as the previous suggestions did not work for me either, but this does. I think this is either a bug, a process that is a little confusing in itself. Perhaps there should be a separate Lightbox control under Pages and Posts (assuming the process provided above by Support works for Posts - have not tried this yet as I am not using Posts). It is a bit of a shame that the control is all or nothing. Would be great if we could choose per page, or if a Shortcode could be used to activate this. Perhaps something for the next update maybe?
contact171
contact171 posted this 16 November 2015
I have the same problem and I need help: in my themler page I haven't the post icon option on the left ! so what can i Do? or if a go to the page option I don't dispaly one of my article so i can't click one image to follow the above procedure.
thks for reply.
pascal
Hello, I have the same problem and I need help: in my themler page I haven't the post icon option on the left ! so what can i Do? or if a go to the page option I don't dispaly one of my article so i can't click one image to follow the above procedure. thks for reply. pascal
Support Team posted this 18 November 2015
@contact171 ,
please submit a new support topic at http://answers.billiondigital.com/Topic/Create?private=1 and provide access to your CMS admin back end. Or attach your theme (if you're working with Themler Desktop).
Also note the page name that demonstrates the issue.
@contact171 , please submit a new support topic at http://answers.billiondigital.com/Topic/Create?private=1 and provide access to your CMS admin back end. Or attach your theme (if you're working with Themler Desktop). Also note the page name that demonstrates the issue. regards, Aileen
Chuck_c1M5xGbOnw
Chuck_c1M5xGbOnw posted this 07 December 2015
This worked perfectly! I never enabled this in the first place but somehow it was activated. I pointed blame towards a few extensions at first but after switching the template I saw that it was something caused here.
To clear things up, make sure you select 'Page' from the dropdown as Morpheus0101 mentioned. By default 'Post' under Blog Templates is selected instead of 'Page' under Main Templates.
enter image description here
From there you can select Posts then Post Content to get to the lightbox option. Mine was set to ON and this was why I was getting the automatic lightbox for EVERY image.
If you need the lightbox feature, there are tons of free plugins on JED (or you can use JS) that can do this outside of the template.
> I managed to solve this. Hope this helps. > > If you have tried the above and found it does not work, try the following: > 1. Navigate to a 'Page' (not a post), within Themler, > 2. Click on one of the images you are having problems with > 3. Finally, choose 'Post Content' from the icons on the left control panel and turn off 'image Lightbox' > > I trust you are having the same problem as me, as the previous suggestions did not work for me either, but this does. > > I think this is either a bug, a process that is a little confusing in itself. Perhaps there should be a separate Lightbox control under Pages and Posts (assuming the process provided above by Support works for Posts - have not tried this yet as I am not using Posts). It is a bit of a shame that the control is all or nothing. Would be great if we could choose per page, or if a Shortcode could be used to activate this. Perhaps something for the next update maybe? > > This worked perfectly! I never enabled this in the first place but somehow it was activated. I pointed blame towards a few extensions at first but after switching the template I saw that it was something caused here. To clear things up, make sure you select 'Page' from the dropdown as Morpheus0101 mentioned. By default 'Post' under Blog Templates is selected instead of 'Page' under Main Templates. ![enter image description here][1] From there you can select Posts then Post Content to get to the lightbox option. Mine was set to ON and this was why I was getting the automatic lightbox for EVERY image. ![enter image description here][2] If you need the lightbox feature, there are tons of free plugins on JED (or you can use JS) that can do this outside of the template. [1]: http://i.imgur.com/XuPzwN9.png [2]: http://i.imgur.com/9ksgALW.png
