How to disable linked images (lightbox?)
john.oxlade
john.oxlade posted this 19 August 2015
Probably me doing something simple (and wrong), but in my Joomla articles, clicking on images opens them in a lightbox - which I don't want. I want to be able to link the images, but the lightbox feature seems to take precedence.
How do I turn it off?
(I started with the default them/template and have been modifying it as I go)
Thanks.
Probably me doing something simple (and wrong), but in my Joomla articles, clicking on images opens them in a lightbox - which I don't want. I want to be able to link the images, but the lightbox feature seems to take precedence. How do I turn it off? (I started with the default them/template and have been modifying it as I go) Thanks.
47 Comments
Support Team posted this 18 September 2017
OK, create a private case so we could review the settings. Issue happens on that exact page on your site that is opened in Themler?
Hi, OK, create a private case so we could review the settings. Issue happens on that exact page on your site that is opened in Themler? Sincerely, Hella
john.oxlade
john.oxlade posted this 18 September 2017
Actually, I don't know what is going on but the Post Header styling isn't working either as it used to be white and now it has changed to a pale blue. It is almost as I an old template has been made the default but it is the latest one.
john.oxlade,
You already reported this issue in another topic. We'll check it when you provide active access to the admin panel.
john.oxlade, You already reported this issue in another topic. We'll check it when you provide active access to the admin panel. Thank you, Olivia
Koen
Koen posted this 19 January 2018
I managed to solve this. Hope this helps.
If you have tried the above and found it does not work, try the following:
1. Navigate to a 'Page' (not a post), within Themler,
2. Click on one of the images you are having problems with
3. Finally, choose 'Post Content' from the icons on the left control panel and turn off 'image Lightbox'
I trust you are having the same problem as me, as the previous suggestions did not work for me either, but this does.
I think this is either a bug, a process that is a little confusing in itself. Perhaps there should be a separate Lightbox control under Pages and Posts (assuming the process provided above by Support works for Posts - have not tried this yet as I am not using Posts). It is a bit of a shame that the control is all or nothing. Would be great if we could choose per page, or if a Shortcode could be used to activate this. Perhaps something for the next update maybe?
This worked perfectly! I never enabled this in the first place but somehow it was activated. I pointed blame towards a few extensions at first but after switching the template I saw that it was something caused here.
To clear things up, make sure you select 'Page' from the dropdown as Morpheus0101 mentioned. By default 'Post' under Blog Templates is selected instead of 'Page' under Main Templates.
![enter image description here][1]
From there you can select Posts then Post Content to get to the lightbox option. Mine was set to ON and this was why I was getting the automatic lightbox for EVERY image.
![enter image description here][2]
If you need the lightbox feature, there are tons of free plugins on JED (or you can use JS) that can do this outside of the template.
[1]: http://i.imgur.com/XuPzwN9.png
[2]: http://i.imgur.com/9ksgALW.png
This is working for me, thank you so much!
> > I managed to solve this. Hope this helps. > > > > If you have tried the above and found it does not work, try the following: > > 1. Navigate to a 'Page' (not a post), within Themler, > > 2. Click on one of the images you are having problems with > > 3. Finally, choose 'Post Content' from the icons on the left control panel and turn off 'image Lightbox' > > > > I trust you are having the same problem as me, as the previous suggestions did not work for me either, but this does. > > > > I think this is either a bug, a process that is a little confusing in itself. Perhaps there should be a separate Lightbox control under Pages and Posts (assuming the process provided above by Support works for Posts - have not tried this yet as I am not using Posts). It is a bit of a shame that the control is all or nothing. Would be great if we could choose per page, or if a Shortcode could be used to activate this. Perhaps something for the next update maybe? > > > > > > This worked perfectly! I never enabled this in the first place but somehow it was activated. I pointed blame towards a few extensions at first but after switching the template I saw that it was something caused here. > > To clear things up, make sure you select 'Page' from the dropdown as Morpheus0101 mentioned. By default 'Post' under Blog Templates is selected instead of 'Page' under Main Templates. > > ![enter image description here][1] > > > From there you can select Posts then Post Content to get to the lightbox option. Mine was set to ON and this was why I was getting the automatic lightbox for EVERY image. > > ![enter image description here][2] > > If you need the lightbox feature, there are tons of free plugins on JED (or you can use JS) that can do this outside of the template. > > > [1]: http://i.imgur.com/XuPzwN9.png > [2]: http://i.imgur.com/9ksgALW.png This is working for me, thank you so much!
leora
leora posted this 29 March 2018
Hi, can anyone find this in the latest version of themler?
Support Team posted this 29 March 2018
It's just the same Posts >> Posts Content >> Lightbox. Please provide screen shots showing if this option is not available for you.
Hi, It's just the same Posts >> Posts Content >> Lightbox. Please provide screen shots showing if this option is not available for you. Sincerely, Hella
James85
James85 posted this 23 April 2018
in CSS add
.bd-lightbox { display: none !important; }
Work in wordpress
in CSS add .bd-lightbox { display: none !important; } Work in wordpress
