Please add an option to do Parallax scrolling effects
shaulhadar
shaulhadar posted this 27 September 2014
Hi Themeler Team. I would like to add a wish for adding parallax scrolling effects. I saw you have option to put images fixed when scrolling, maybe add like an option that you can choose the element's slide down speed, and than its automatically parallax....or ofcourse use any solution you think of..
Thanks for your time! Themeler is great!
Shaul.
Hi Themeler Team. I would like to add a wish for adding parallax scrolling effects. I saw you have option to put images fixed when scrolling, maybe add like an option that you can choose the element's slide down speed, and than its automatically parallax....or ofcourse use any solution you think of.. Thanks for your time\! Themeler is great\! Shaul.
23 Comments
Support Team posted this 29 September 2014
Thank you for the suggestion!
I've added it to our wish list.
Hello Thank you for the suggestion! I've added it to our wish list. Thank you, Olivia
RyanGanley
RyanGanley posted this 12 November 2014
I fully concur. This would be a excellent feature. However there are still several bugs to work out.
Support Team posted this 13 November 2014
Our developers are working on it.
Please feel free to report all bugs to us. We'll fix them.
Hello Our developers are working on it. > However there are still several bugs to work out. Please feel free to report all bugs to us. We'll fix them. Thank you, Olivia
In fact, even now you can do a simple "parallax" effect.
Let's take a Header or DIV, Row, etc. Simply add background image to the chosen control and change it's position to "fixed":
That's all. Now you have a nice "parallax" effect on scrolling.
I've found this funny cat in the internet to illustrate what I mean:
http://andrevv.com/
The author used the same technique.
Here is one more example provided by Ryan in one of his topics:
http://forsolutionsllc.com/
It's closer to reality.
BTW, you can do the same with shortcodes in content:
[box css="background-image:url('path-to-image'); background-attachment: fixed;"] any content here [/box]
Hi, In fact, even now you can do a simple "parallax" effect. Let's take a Header or DIV, Row, etc. Simply add background image to the chosen control and change it's position to "fixed": !background-attachment.png! That's all. Now you have a nice "parallax" effect on scrolling. I've found this funny cat in the internet to illustrate what I mean: http://andrevv.com/ The author used the same technique. Here is one more example provided by Ryan in one of his topics: http://forsolutionsllc.com/ It's closer to reality. BTW, you can do the same with shortcodes in content: [box css="background-image:url('path-to-image'); background-attachment: fixed;"] any content here [/box] Thank you, Olivia
shaulhadar
shaulhadar posted this 09 March 2015
Hi Olivia, I have tried your method and it works, but the scrolling of the content makes it look jumpy , and not smooth when scrolling. is this something that can be edited currently?
Also, i would like to know if there is any update on the parallax elements for themler?
Hi Olivia, I have tried your method and it works, but the scrolling of the content makes it look jumpy , and not smooth when scrolling. is this something that can be edited currently? Also, i would like to know if there is any update on the parallax elements for themler? Thanks :)
Support Team posted this 10 March 2015
Hi Shaul,
Themler supports Smooth scrolling feature. It scrolls the page to the anchor smoothly. It works in the same way as on any other non-Themler websites.
Could you please provide an example of what exactly you want to achieve?
It would be easier to answer your question.
Hi Shaul, Themler supports Smooth scrolling feature. It scrolls the page to the anchor smoothly. It works in the same way as on any other non-Themler websites. Could you please provide an example of what exactly you want to achieve? It would be easier to answer your question. Thank you, Olivia
shaulhadar
shaulhadar posted this 11 March 2015
Hi Olivia, what i ment , is that on regular scrolling inside of chrome, when i scroll, it scrolls in little jumps, so when using your technique here, there is no smooth scrolling option, because there is no anchor, only the fixed background..... ofcourse when you do add this option it will work, i was just wandering it there is any workaround for this until you add this feature?
Thanks...
Hi Olivia, what i ment , is that on regular scrolling inside of chrome, when i scroll, it scrolls in little jumps, so when using your technique here, there is no smooth scrolling option, because there is no anchor, only the fixed background..... ofcourse when you do add this option it will work, i was just wandering it there is any workaround for this until you add this feature? Thanks...
Support Team posted this 11 March 2015
Hi Shaul,
Do you mean that you want to simply slow down the page scrolling speed on mouse scroll?
Like here?
http://jsfiddle.net/promatik/NFk2L/
If so you can use this solution in Themler. Add this code to the Theme Settings >> Additional HTML:
<script>
jQuery (function ($) {
place code here
</script>
Hi Shaul, Do you mean that you want to simply slow down the page scrolling speed on mouse scroll? Like here? http://jsfiddle.net/promatik/NFk2L/ If so you can use this solution in Themler. Add this code to the Theme Settings >> Additional HTML: <script> jQuery (function ($) { place code here }); </script> Thank you, Olivia
r.leclercq
r.leclercq posted this 13 August 2015
+1 to add parallax effect ;)
jgarza
jgarza posted this 19 August 2015
Stagger Lee posted this 19 August 2015
And random function please.
I dont know why many people ask about it.
And random function please. I dont know why many people ask about it.
philippe.pphantom
philippe.pphantom posted this 27 October 2015
before new functions it wil be better to correct theb ugs ( a lot of) to the existing ones .....
This software don't work ... always bugs everywhere
> Hello > > Thank you for the suggestion! > I've added it to our wish list. > > Thank you, > Olivia before new functions it wil be better to correct theb ugs ( a lot of) to the existing ones ..... This software don't work ... always bugs everywhere
Support Team posted this 28 October 2015
We are constantly fixing all the bugs reported by our users and found by our testing team. If you find any new problems feel free to create separate tickets with the detailed explanation of the problem.
Hi, We are constantly fixing all the bugs reported by our users and found by our testing team. If you find any new problems feel free to create separate tickets with the detailed explanation of the problem. Sincerely, Hella
mmp
mmp posted this 09 December 2015
Parallax would be fantastic, for example when selecting the "parallax" effect, that it would provide an option that you can chose the % the background scrolls in comparison with the "foreground". eg. background 50% of the content's scrolling speed :-D.
Also there is no point in trying to fix EVERY issue before bringing out new functions, there will always be new bugs.
Parallax would be fantastic, for example when selecting the "parallax" effect, that it would provide an option that you can chose the % the background scrolls in comparison with the "foreground". eg. background 50% of the content's scrolling speed :-D. Also there is no point in trying to fix EVERY issue before bringing out new functions, there will always be new bugs.
Stagger Lee posted this 24 December 2015
This snippet works, but remove data-animation and everything over images because slide function is not executed when other images are there by browser reload/refresh. Use it if you dont have any blocks over images.
<script type='text/javascript'>
jQuery(document).ready(function() {
!function ( $) {
//prevents js conflicts
"use strict";
$.CustomizrSlidesShuffle = function() {
var o = [];
//get original slides nodes and order
$('.item' , '.carousel-inner').each(function() {
$(this).removeClass('active');
o.push($(this));
//randomizes
for(var j, x, i = o.length; i; j = parseInt(Math.random() * i), x = o[--i], o[i] = o[j], o[j] = x);
//displays reordered slides
o[0].addClass('active');
for (var i = 0; i < o.length - 1; i++) {
o[i].after(o[i+1]);
}(window.jQuery);
//calls the function
jQuery.CustomizrSlidesShuffle();
</script>
> And random function please. > I dont know why many people ask about it. This snippet works, but remove data-animation and everything over images because slide function is not executed when other images are there by browser reload/refresh. Use it if you dont have any blocks over images. &lt;script type='text/javascript'&gt; jQuery(document).ready(function() { !function ( $) { //prevents js conflicts "use strict"; $.CustomizrSlidesShuffle = function() { var o = []; //get original slides nodes and order $('.item' , '.carousel-inner').each(function() { $(this).removeClass('active'); o.push($(this)); }); //randomizes for(var j, x, i = o.length; i; j = parseInt(Math.random() * i), x = o[--i], o[i] = o[j], o[j] = x); //displays reordered slides o[0].addClass('active'); for (var i = 0; i &lt; o.length - 1; i++) { o[i].after(o[i+1]); }; }; }(window.jQuery); //calls the function jQuery.CustomizrSlidesShuffle(); }); &lt;/script&gt;
Support Team posted this 24 December 2015
Please check the latest update
shaulhadar
shaulhadar posted this 25 December 2015
Thank you so much much for adding this option!!!
lionvsalex
lionvsalex posted this 28 December 2015
Parallax scrolling not working in ie 11 :(
mmixsetup
mmixsetup posted this 12 July 2016
Can you go sideways like this site?
http://hotdot.pro/#
Can you go sideways like this site? http://hotdot.pro/#
Support Team posted this 12 July 2016
Unfortunately Themler does not support creating of horizontal pages.
But we have such request in our wish list.
Hi, Unfortunately Themler does not support creating of horizontal pages. But we have such request in our wish list. Thank you, Olivia
