Please add an option to duplicate slides
shaulhadar
shaulhadar posted this 27 September 2014
Hi Themeler Team.
Please add an option to duplicate slider items. This way someone can work on a slide and than duplicate it and change the text and image...
Currently if you do text and shapes in side a slider, when you do a new slider item, it is really hard to make the same slide with same elements placements. the duplicate slider feature would be great for this workflow.
Thanks for your time,
Shaul.
Hi Themeler Team. Please add an option to duplicate slider items. This way someone can work on a slide and than duplicate it and change the text and image... Currently if you do text and shapes in side a slider, when you do a new slider item, it is really hard to make the same slide with same elements placements. the duplicate slider feature would be great for this workflow. Thanks for your time, Shaul.
Support Team posted this 29 September 2014
This option is available now. Right-click on the slide and there will be an option to Duplicate Slide.
Hi, This option is available now. Right-click on the slide and there will be an option to Duplicate Slide. Sincerely, Hella BillionDigital Team
shaulhadar
shaulhadar posted this 30 April 2015
I didn't have the time to say thanks, so thank you, though i know it's an old post :)
Have a great day,
Shaul.
I didn't have the time to say thanks, so thank you, though i know it's an old post :) Have a great day, Shaul.
Support Team posted this 30 April 2015
Thanks for getting back)
Hi, Thanks for getting back) Sincerely, Hella BillionDigital Team
websitefixerupper
websitefixerupper posted this 15 July 2015
I USE A MAC,
I tried right click, used various control combos to right click, etc but the option is not there to duplicate slides. I tried on the slide itself as well as the slide #.
Additionally I am unable to delete images.
It seems right click does not work for me or maybe i am missing something.
I do like that i can now remove a row on the left control tab in themler.
Could some help on the above issues I have.
Thanks in advance
I USE A MAC, I tried right click, used various control combos to right click, etc but the option is not there to duplicate slides. I tried on the slide itself as well as the slide #. Additionally I am unable to delete images. It seems right click does not work for me or maybe i am missing something. I do like that i can now remove a row on the left control tab in themler. Could some help on the above issues I have. Thanks in advance
Support Team posted this 20 July 2015
websitefixerupper,
Sorry for the delay.
We've tested Themler context menu (by right click) on several MACs and it works as it should.
Please make sure that right click option is enabled in the System Preferences:
http://still-scripts.com/mac-os-x/how-to-right-click-with-your-mighty-mouse-on-your-apple-computer/
If the issue continues please create a separate Private topic and provide the information about your Mac OSX.
websitefixerupper, Sorry for the delay. We've tested Themler context menu (by right click) on several MACs and it works as it should. Please make sure that right click option is enabled in the System Preferences: http://still-scripts.com/mac-os-x/how-to-right-click-with-your-mighty-mouse-on-your-apple-computer/ If the issue continues please create a separate Private topic and provide the information about your Mac OSX. Thank you, Olivia
