Uploading Artisteer Theme for Joomla to edit in Themler
schencpa
schencpa posted this 21 August 2015
I have a Joomla theme created in Artisteer, that I want to upload to my Joomla Themler and modify for my website, as some controls cannot be edited in Artisteer.
I have Artisteer 4.3, but cannot export theme for Themler. What can I do?
I have a Joomla theme created in Artisteer, that I want to upload to my Joomla Themler and modify for my website, as some controls cannot be edited in Artisteer. I have Artisteer 4.3, but cannot export theme for Themler. What can I do?
14 Comments
Support Team posted this 21 August 2015
Please refer to the following article:
http://answers.themler.com/articles/19107/themler-v1-0-59-desktop-installation-updated-and-joomla-artx-support-added-10-aug-2015
There is the link to the Artisteer update with the possibility to export Artisteer theme in Themler format.
Hi, Please refer to the following article: http://answers.themler.com/articles/19107/themler-v1-0-59-desktop-installation-updated-and-joomla-artx-support-added-10-aug-2015 There is the link to the Artisteer update with the possibility to export Artisteer theme in Themler format. Sincerely, Hella BillionDigital Team
schencpa
Hi Hella,
I did as per article. Now I get the following when trying to import a Theme exported from Artisteer...
JInstaller: :Install: File does not exist
Template Install: Could not copy files from the files source.
Error installing template
That is when in Themler I select "File", then "Import from Zip..." and then select the zip file that was created by Artisteer.
Hi Hella, I did as per article. Now I get the following when trying to import a Theme exported from Artisteer... JInstaller: :Install: File does not exist Template Install: Could not copy files from the files source. Error installing template That is when in Themler I select "File", then "Import from Zip..." and then select the zip file that was created by Artisteer.
Support Team posted this 27 August 2015
Sorry for the delay.
Could you please attach this .zip file.
Hello Sorry for the delay. Could you please attach this .zip file. Thank you, Olivia
Support Team posted this 30 August 2015
as workaround please re-export the Artisteer project with enabled 'Include Content' option.
It should be installed without a problem in this case.
Hello, as workaround please re-export the Artisteer project with enabled 'Include Content' option. It should be installed without a problem in this case. Regards, Aileen
simone_stickles
simone_stickles posted this 22 April 2019
I'm a Artisteer user and trying to import my template into Themler - so I can move programs- but it keeps displaying errors and won't import.
I have followed your artister export to themler instructions for Joomla - and it freezes when importing into Themler
Can you please see what it wrong. Artisteer file attached.
Simone
Hi I'm a Artisteer user and trying to import my template into Themler - so I can move programs- but it keeps displaying errors and won't import. I have followed your artister export to themler instructions for Joomla - and it freezes when importing into Themler Can you please see what it wrong. Artisteer file attached. Thanks Simone
Support Team posted this 22 April 2019
Do you mean that you are trying to import the project in .artx format as it is? This is not possible. But please try to export it in Themler for Joomla format and then import the resulting .zip in Themler. To export, please use this Artisteer version:
Hello, Do you mean that you are trying to import the project in .artx format as it is? This is not possible. But please try to export it in Themler for Joomla format and then import the resulting .zip in Themler. To export, please use this Artisteer version: www.artisteer.com/media/p4/files/Artisteer.4.3.0.60928.exe Sincerely, Nettie
simone_stickles
simone_stickles posted this 23 April 2019
No. I'm exporting it in artisteer as a themler / joomla file. Then importing it into themler. Will try Artisteer Version. Thanks.
Support Team posted this 23 April 2019
Ok, please let us know the result with the newest version. It includes some fixes exactly for Themler for Joomla export.
Hello, Ok, please let us know the result with the newest version. It includes some fixes exactly for Themler for Joomla export. Sincerely, Nettie
simone_stickles
simone_stickles posted this 28 April 2019
Hi, Still not working. Now it stops when trying to update the version of the Artisteer template when importing it into Themler -
In Themler I get an error now of - Themler is updating the template - "server error - server is unavailable - Retry"
Hi, Still not working. Now it stops when trying to update the version of the Artisteer template when importing it into Themler - In Themler I get an error now of - Themler is updating the template - "server error - server is unavailable - Retry"
Support Team posted this 29 April 2019
Do you get this error in Themler desktop or on your hosted website?
Hello, Do you get this error in Themler desktop or on your hosted website? Sincerely, Nettie
simone_stickles
simone_stickles posted this 29 April 2019
On desktop. It isn't uploaded to the site yet.
simone_stickles
As I'm still trying to get Themler to import the template I initially created in Artisteer. (exported themler/joomla zip from artisteer and import into themler)
simone_stickles
simone_stickles posted this 12 May 2019
still waiting for a reply - my artisteer file won't import into themler.
Support Team posted this 13 May 2019
Could you please create a new private topic and attach your .artc project and the exported .zip-theme? Also please let us know what error you get when trying to import this .zip.
Hello, Could you please create a new private topic and attach your .artc project and the exported .zip-theme? Also please let us know what error you get when trying to import this .zip. Sincerely, Nettie
