Importing Artisteer Projects into Themler
Pixie Magic
Pixie Magic posted this 24 August 2015
When clicking this link
Import Artisteer Projects (ARTX)
http://answers.themler.com/Support/Doc/Detail/16223
I get this reply
Access Denied
You do not have sufficient permissions to view this page. Please return to the home page or log in again.
Question:
Can you tell me if ALL projects i have designed in various versions of Artisteer since 2011 will import easily into Themler without layout problems, or is there additional work to be done after importing?
When clicking this link Import Artisteer Projects (ARTX) http://answers.themler.com/Support/Doc/Detail/16223 I get this reply Access Denied You do not have sufficient permissions to view this page. Please return to the home page or log in again. Question: Can you tell me if ALL projects i have designed in various versions of Artisteer since 2011 will import easily into Themler without layout problems, or is there additional work to be done after importing? Thanks
10 Comments
Support Team posted this 24 August 2015
Please try following link:
http://answers.themler.com/articles/16223/importing-artisteer-projects-artx
There should not be any major problems with layout or design.
In any case you may try to see your own.
Tina B.
Hi, Please try following link: http://answers.themler.com/articles/16223/importing-artisteer-projects-artx There should not be any major problems with layout or design. In any case you may try to see your own. Tina B.
BTW, where did you found this broken link?
Themler Team
Hello, BTW, where did you found this broken link? Thanks, Themler Team
Pixie Magic
On the pricing page for Themler
Pixie Magic
Hi Tina,
Can i also import ARTX designs just for use as ordinary websites without CMS?
Plain old ordinary html websites, that i want to see if they will benefit from the advanced layout within Themler?
Hi Tina, Can i also import ARTX designs just for use as ordinary websites without CMS? Plain old ordinary html websites, that i want to see if they will benefit from the advanced layout within Themler? Thanks
Thank you, this link is fixed.
Do you mean HTML Export?
Yes, it should be available soon.
Oleg
Thank you, this link is fixed. Do you mean HTML Export? Yes, it should be available soon. Thanks, Oleg
Pixie Magic
Yes i do. Many thanks
Yes i do. Many thanks :-)
info1392
info1392 posted this 24 August 2015
At the moment only joomla and Wordpress can be exported from artisteer and imported into themeler. HTML should be included soon.
X5tuts
At the moment only joomla and Wordpress can be exported from artisteer and imported into themeler. HTML should be included soon. X5tuts
Pixie Magic
Pixie Magic posted this 25 August 2015
I'll keep an eye on the news.
Thanks :-) I'll keep an eye on the news.
reinhard
reinhard posted this 30 August 2015
Import not possible. I follow the steps:
  1. export from Artisteer latest version (reinstall august 30, 2015) valid serialnumber
  2. start themer (also newest version from today) and select Import from ZIP
  3. Get Error
I check this not only with this template/theme, also with others, standards without editing, online an also local host
Plase help, I have to import lot of themes from artisteerprojects
this is the actual Artisteer version
Export as ZIP for Themler
start Themler and import the zip
Error Message
Import not possible. I follow the steps: 1. export from Artisteer latest version (reinstall august 30, 2015) valid serialnumber 2. start themer (also newest version from today) and select Import from ZIP 3. Get Error I check this not only with this template/theme, also with others, standards without editing, online an also local host Plase help, I have to import lot of themes from artisteerprojects ![this is the actual Artisteer version][1] ![Export as ZIP for Themler][2] ![start Themler and import the zip][3] ![Error Message][4] [1]: http://technic-direct.eu/shots/themler_shot_00.jpg [2]: http://technic-direct.eu/shots/themler_shot_01.jpg [3]: http://technic-direct.eu/shots/themler_shot_02.jpg [4]: http://technic-direct.eu/shots/themler_shot_03.jpg
Support Team posted this 01 September 2015
Hello Reinhard,
please refer to my response in the topic http://answers.themler.com/questions/19108/themler-v1-0-59-desktop-installation-updated-and-joomla-artx-support-added-10-aug-2015
this problem is being discussed there.
Hello Reinhard, please refer to my response in the topic http://answers.themler.com/questions/19108/themler-v1-0-59-desktop-installation-updated-and-joomla-artx-support-added-10-aug-2015 this problem is being discussed there. regards, Aileen
