Themler Hotfix and Desktop Update (25-August-2015)
Support Team posted this 25 August 2015
Hi everyone,
Hot Fixes:
  • Improved WP 4.3 compatibility (fixed issue with menu and widgets in preview).
  • Fixed Insufficient permissions error in Drupal themes.
  • Various small fixed.
Themler Desktop update
  1. Added Themler Debug mode which includes Chrome console logs into Diagnostics Tool logs.
    If you have issues with using Themler, please run Themler (Debug mode), reproduce the issue and send us logs from Diagnostics Tool.
  2. Fixed conflict with running PHP on computers with existing instance of different PHP version
  3. Fixed issue with running Themler when VBS extension is associated with a different application.
  4. Fixed Download As Zip issue with Drupal
  5. Improved logging.
Read more about this update here.
See Also
Previous updates
Themler Support Team
Hi everyone, ### Hot Fixes: - Improved WP 4.3 compatibility (fixed issue with menu and widgets in preview). - Fixed Insufficient permissions error in Drupal themes. - Various small fixed. ### Themler Desktop update 1. Added [Themler Debug mode](page:13879#debug_mode) which includes Chrome console logs into Diagnostics Tool logs. If you have issues with using Themler, please run Themler (Debug mode), reproduce the issue and send us logs from Diagnostics Tool. 2. Fixed conflict with running PHP on computers with existing instance of different PHP version 3. Fixed issue with running Themler when VBS extension is associated with a different application. 4. Fixed Download As Zip issue with Drupal 5. Improved logging. Read more about this update [here](page:22895). ### See Also <a href="http://answers.billiondigital.com/categories/3916/">Previous updates</a> Thank you, Themler Support Team
8 Comments
DouzanStudio
DouzanStudio posted this 25 August 2015
You mean WP 4.3 , right :D
Thanks for update & waiting for "Section control that allows to add ready to use sections in one click" & edit content in cms through themler update.
You mean WP 4.3 , right :D Thanks for update & waiting for "Section control that allows to add ready to use sections in one click" & edit content in cms through themler update.
DouzanStudio
waiting for "Section control that allows to add ready to use sections in one click" update.
I think it's here now with this update, i just figured out :O
> waiting for "Section control that allows to add ready to use sections in one click" update. I think it's here now with this update, i just figured out :O
Stagger Lee posted this 25 August 2015
Seeker, can you explain what is it about ? I dont know for what this control is used.
DouzanStudio
Hmmm , I'm not sure about it ,but now i can add a button in the header easily , I'm new with themler and maybe we can do this thing before the last update.
They mention it in 18-August update
Hmmm , I'm not sure about it ,but now i can add a button in the header easily , I'm new with themler and maybe we can do this thing before the last update. They mention it in 18-August update !next.png!
You missunderstand something.
I would like explanation what "Section" control is for. We can put some own name on it, but for what use ?
Small window with presets under name is empty. Is it supposed to show our own block presets ? Something reusable from theme to theme ? On same theme, etc..
You missunderstand something. I would like explanation what "Section" control is for. We can put some own name on it, but for what use ? Small window with presets under name is empty. Is it supposed to show our own block presets ? Something reusable from theme to theme ? On same theme, etc..
DouzanStudio
Aha! , I just remembered that from Artisteer , it was in it too , but in terrible way LOL xD
Stagger Lee posted this 26 August 2015
Anyway , have been working last 2-3 days a bit more intense with Themler, due to one deadline.
Amazing what secrets and nice things hide inside this Application.
I know now you can override CSS from most of the WordPress plugins, thanks to standard that CSS rules targeted for one block (say for instance bd-postheader-5) have priority for browsers. Many plugins have filter to disable its CSS, or do it with Plugin Organizer plugin.
Just some examples where you can completely bypass plugins styling and make your own:
- Contact Form 7, other forms
- Events calendars, Events listings
- ALL HTML tables plugins generates
- Custom fields display
- Anything in plugins using H tags
- Weather widgets
- Go to the Posts tab - Post content -(or Widget content) - More styles. Anything listed there that exist in a plugin you can override and style beyond plugin styling.
  • Nex will be to try what I can do about bbPress, buddypress styling. Still black hole for me.
Anyway , have been working last 2-3 days a bit more intense with Themler, due to one deadline. Amazing what secrets and nice things hide inside this Application. I know now you can override CSS from most of the WordPress plugins, thanks to standard that CSS rules targeted for one block (say for instance bd-postheader-5) have priority for browsers. Many plugins have filter to disable its CSS, or do it with Plugin Organizer plugin. Just some examples where you can completely bypass plugins styling and make your own: - Contact Form 7, other forms - Events calendars, Events listings - ALL HTML tables plugins generates - Custom fields display - Anything in plugins using H tags - Weather widgets - Go to the Posts tab - Post content -(or Widget content) - More styles. Anything listed there that exist in a plugin you can override and style beyond plugin styling. - Nex will be to try what I can do about bbPress, buddypress styling. Still black hole for me.
Support Team posted this 27 August 2015
Hello guys,
just to make things a bit clear.
The option mentioned in the 'Themler Update (18-Aug-2015)'
This control is still under development, and it is fully functional in current update. It should be ready to use in the next major (not hot-fix) update.
Hello guys, just to make things a bit clear. The option mentioned in the 'Themler Update (18-Aug-2015)' > Section control that allows to add ready to use sections in one click This control is still under development, and it is fully functional in current update. It should be ready to use in the next major (not hot-fix) update. regards, Aileen
