Cannot put Post Header into a specific row
Nettie posted this 15 April 2014
I have added a row and I'm trying to put the Post Header in there. I have tried the following ways:
  1. To drag and drop the existing default post header into this row.
  2. To add a new one, and drag it in there.
However I fail to do this. Does anybody have a similar issue?
Hi, I have added a row and I'm trying to put the Post Header in there. I have tried the following ways: 1. To drag and drop the existing default post header into this row. 2. To add a new one, and drag it in there. However I fail to do this. Does anybody have a similar issue?
Aileen posted this 15 April 2014
In general drag and drop should work if you positioned the control properly. I mean that when you're dragging it you should see highlighted blue lines which mark the area borders.
Hi Aileen,
I have tried your suggestion but the borders are never highlighted... It looks like I fail to do this for the post header only...
post_header
Hi Aileen, I have tried your suggestion but the borders are never highlighted... It looks like I fail to do this for the post header only... ![post_header][1] [1]: http://attachments.forum.billiondigital.com/70/70/i2.png
Is Solution
Olivia posted this 16 April 2014
It looks like you can move the Post Header inside the Post control only.
Nettie posted this 18 April 2014
Thanks, I see now.
Thanks, I see now.
