How to add different images in slider for every Language?
kostianev
kostianev posted this 26 August 2015
Hello there, I am using Themler for Joomla and I need to know how to configure different images in Slider for different languages in system. For example I want to user Images with english text in en version, and images with spanish text in es version of my website?
Support Team posted this 27 August 2015
Unfortunately Themler itself does not have such feature.
I have two ideas:
  1. If you can show/hide modules for the specific languages you can replace Image in Slider with Joomla position control in Slider. Then place HTML modules with image in this position in Joomla and enable/disable modules for specific languages.
  2. If these are two different menu items you can create custom template with own slider and assign it to the Spanish page.
Hello Unfortunately Themler itself does not have such feature. I have two ideas: 1. If you can show/hide modules for the specific languages you can replace Image in Slider with Joomla position control in Slider. Then place HTML modules with image in this position in Joomla and enable/disable modules for specific languages. 2. If these are two different menu items you can create [custom template](page:10804) with own slider and assign it to the Spanish page. Thank you, Olivia
webmaster@exnet.gr
webmaster@exnet.gr posted this 11 May 2016
i have a multi language website, all the home page i have created it in themler with sections. I want to have different home pages depends on selected language, i am thinking that the solutions 2. that you give above is good, isn't it? Tell me please how can you assign a custom template to a particular language?
Hello, i have a multi language website, all the home page i have created it in themler with sections. I want to have different home pages depends on selected language, i am thinking that the solutions 2. that you give above is good, isn't it? Tell me please how can you assign a custom template to a particular language? Thank you
Support Team posted this 11 May 2016
That is possible if you have separate menu items for the home page for each language. Or if you have some plug-in that could switch templates depending on the language selected.
Hi, That is possible if you have separate menu items for the home page for each language. Or if you have some plug-in that could switch templates depending on the language selected. Sincerely, Hella
DaveOzric
DaveOzric posted this 11 May 2016
I would try to use the GTranslate plugin, it's free and translates all text on the site. So it should in theory make the slide text any language. Just a thought. It's free.
webmaster@exnet.gr
webmaster@exnet.gr posted this 18 May 2016
