Woocommerce categories instead of products
mitchvandongen
mitchvandongen posted this 27 August 2015
Hi Guys,
I was wondering how I can get the woocommerce product categories to show on the shop/product page instead of all products together? I activated ''show categories'' and added the controls for category name and image, but the only thing it does is show me a text ''shop'' instead of the woocommerce categories I have.. I set woocommerce to different setting to make sure that wasn't screwing things up but it seems I can't get it figured out.
Thanks in advance :)
Mitch.
Hi Guys, I was wondering how I can get the woocommerce product categories to show on the shop/product page instead of all products together? I activated ''show categories'' and added the controls for category name and image, but the only thing it does is show me a text ''shop'' instead of the woocommerce categories I have.. I set woocommerce to different setting to make sure that wasn't screwing things up but it seems I can't get it figured out. Thanks in advance :) Mitch.
Support Team posted this 28 August 2015
Could you please illustrate what you are trying to achieve in screenshot?
Thank you!
Hi, Could you please illustrate what you are trying to achieve in screenshot? Thank you!
mitchvandongen
mitchvandongen posted this 28 August 2015
No problem :) here are 2 screenshots, the first one is the page as it looks now it shows me all products, I want it to show the categories instead.
Screenshot 2 is when I have ''show categories'' and ''show subcategories'' activated, it shows me only the ''shop'' text instead of the categories I have, it doesn't make a difference if I add the controls from the categories tab to show category name and image.
No problem :) here are 2 screenshots, the first one is the page as it looks now it shows me all products, I want it to show the categories instead. Screenshot 2 is when I have ''show categories'' and ''show subcategories'' activated, it shows me only the ''shop'' text instead of the categories I have, it doesn't make a difference if I add the controls from the categories tab to show category name and image.
Support Team posted this 31 August 2015
Sorry for the delay.
I've tested this issue and it looks like there is a bug. It will be fixed in the next major Themler update.
Hello Sorry for the delay. I've tested this issue and it looks like there is a bug. It will be fixed in the next major Themler update. Thank you, Olivia
manet2000ro
manet2000ro posted this 06 October 2015
I have the same problem.. is it fixed yet? I'm on the latest v.99
Support Team posted this 07 October 2015
Yes, the issue should be fixed in the latest version. Could you please create a private topic and provide an access to your back end. Also please refer to this case so we could understand what the issue is.
Hi, Yes, the issue should be fixed in the latest version. Could you please create a private topic and provide an access to your back end. Also please refer to this case so we could understand what the issue is. Sincerely, Hella
urbanhaze
urbanhaze posted this 12 October 2015
I appear to have the same problem too here.
In the WooCommerce Settings > Products > Display
The option "Shop Page Display" is set to "Show categories & subcategories"
Using other themes this does what it's supposed to do, but using Themler, it behaves as though the option "show products" is selected.
Hi, I appear to have the same problem too here. In the WooCommerce Settings > Products > Display The option "Shop Page Display" is set to "Show categories & subcategories" Using other themes this does what it's supposed to do, but using Themler, it behaves as though the option "show products" is selected.
Support Team posted this 13 October 2015
urbanhaze,
Please make sure you have enabled showing Product Categories in Themler as well:
If the issue is still present, please open a new private topic and provide access to your website there for investigation.
**urbanhaze**, Please make sure you have enabled showing Product Categories in Themler as well: !i92.png! If the issue is still present, please open a new private topic and provide access to your website there for investigation. Sincerely, Nettie, BillionDigital Team
