joomla vertical menu
dandez
dandez posted this 07 October 2014
Hello where can I add and stylize vertical menu like in artisteer?
I see the top menu, horizontal menu but cant find vmenu controller.
Dan
Hello where can I add and stylize vertical menu like in artisteer? I see the top menu, horizontal menu but cant find vmenu controller. Regards Dan
19 Comments
Aleh
Aleh posted this 07 October 2014
To change default Vertical Menu style:
- Select Default Styles view
- Find Vertical Menu
- Click to Vertical Menu
- Change Style
This style will be part of Joomla Template.
User can add Vertical Menu in Joomla and default style will be used.
To add Vertical Menu to Joomla page and change Style:
- Go to Joomla Admin Panel / Module Manager
- Add new Menu Module to the left position
- Click Advanced Tab
- Enter "vmenu" for Module Class Suffix
- Go back to Themler
- Click Refresh Content Button
- Change Vertical Menu Style
To change default Vertical Menu style: - Select Default Styles view - Find Vertical Menu - Click to Vertical Menu - Change Style This style will be part of Joomla Template. User can add Vertical Menu in Joomla and default style will be used. To add Vertical Menu to Joomla page and change Style: - Go to Joomla Admin Panel / Module Manager - Add new Menu Module to the left position - Click Advanced Tab - Enter "vmenu" for Module Class Suffix - Go back to Themler - Click Refresh Content Button - Click to Vertical Menu - Change Vertical Menu Style
dandez
dandez posted this 08 October 2014
Ok I've styled my vertical menu in default styles in Themler then installed template in Joomla.
I've created menu item, menu module and gave vmenu class to it and nothing changes it still doesn't look as the one I styled in Themler.
Ok I've styled my vertical menu in default styles in Themler then installed template in Joomla. I've created menu item, menu module and gave vmenu class to it and nothing changes it still doesn't look as the one I styled in Themler.
Support Team posted this 08 October 2014
Please make sure that you added exactly Module Class Suffix, not Menu class suffix:
Also note that to see the changes made in Themler on the live site you should click "Apply theme to CMS".
Hello Please make sure that you added exactly Module Class Suffix, not Menu class suffix: ![](http://attachments.answers.billiondigital.com/478/478/joomla-module-class-suffix.png) Also note that to see the changes made in Themler on the live site you should click "Apply theme to CMS". Thank you, Olivia
info842
info842 posted this 05 August 2015
I don't get it.
I created a vmenu in Joomla. (ofcourse set the module class suffix to vmenu). I started Themler from desktop, changed the Vmenu style and export it as zip without the "Include Themler for custumizing this theme" option.
There is nothing changed in Joomla when I install the zip file en set the theme as default template.
I don't get it. I created a vmenu in Joomla. (ofcourse set the module class suffix to vmenu). I started Themler from desktop, changed the Vmenu style and export it as zip without the "Include Themler for custumizing this theme" option. There is nothing changed in Joomla when I install the zip file en set the theme as default template.
info842
Oke I found it but i have some questions to be sure for some things:
Is it only possible for styling the vertical menu from editing the theme/template in Joomla itself? (I mean with the edit button in the installed template in Joomla)
If yes, then I must install first the template with Themler including for editing en after that saving the editted template as zip en reinstall in Joomla when I dont want that a customer is seeing the Themler Eddit button???
Why isn't it possible to style the vertical menu just like the main menu and save like zip. I want to make the complete template without using Joomla and when ready install it as a zip without the editting function.
Richard
Oke I found it but i have some questions to be sure for some things: Is it only possible for styling the vertical menu from editing the theme/template in Joomla itself? (I mean with the edit button in the installed template in Joomla) If yes, then I must install first the template with Themler including for editing en after that saving the editted template as zip en reinstall in Joomla when I dont want that a customer is seeing the Themler Eddit button??? Why isn't it possible to style the vertical menu just like the main menu and save like zip. I want to make the complete template without using Joomla and when ready install it as a zip without the editting function. Regards, Richard
Support Team posted this 06 August 2015
As was mentioned before, you can style the Vertical Menu under the Styles tab in Themler and then those styles will be applied to the vertical menu when you add it in Joomla. If you do not style it under the Styles tab, then the only option is indeed install the template, add the module from the Joomla admin and then load the editor again from the Joomla admin panel.
Hi, As was mentioned before, you can style the Vertical Menu under the Styles tab in Themler and then those styles will be applied to the vertical menu when you add it in Joomla. If you do not style it under the Styles tab, then the only option is indeed install the template, add the module from the Joomla admin and then load the editor again from the Joomla admin panel. Sincerely, Hella BillionDigital Team
faithbloom
faithbloom posted this 13 August 2015
- Change Style
These instructions are very clear. I followed them but they did not work for me at all. I am editing the theme from Joomla backend.
> To change default Vertical Menu style: > - Select Default Styles view > - Find Vertical Menu > - Click to Vertical Menu > - Change Style > This style will be part of Joomla Template. > User can add Vertical Menu in Joomla and default style will be used. > > To add Vertical Menu to Joomla page and change Style: > - Go to Joomla Admin Panel / Module Manager > - Add new Menu Module to the left position > - Click Advanced Tab > - Enter "vmenu" for Module Class Suffix > - Go back to Themler > - Click Refresh Content Button > - Click to Vertical Menu > - Change Vertical Menu Style These instructions are very clear. I followed them but they did not work for me at all. I am editing the theme from Joomla backend.
Support Team posted this 14 August 2015
Your problem is that the vertical menu added from the Joomla back end does not take the default vertical menu styles? In this case please open the template from the back end, click on the vertical menu in Themler editor and there should be the Reset to default option in the vertical menu options in the left panel.
If that does not help, please create a private ticket with the access to your back end and the detailed explanation of the issue.
Hi, Your problem is that the vertical menu added from the Joomla back end does not take the default vertical menu styles? In this case please open the template from the back end, click on the vertical menu in Themler editor and there should be the Reset to default option in the vertical menu options in the left panel. If that does not help, please create a private ticket with the access to your back end and the detailed explanation of the issue. Sincerely, Hella BillionDigital Team
faithbloom
faithbloom posted this 16 August 2015
Hello Hella,
That worked ok thanks.
Hello Hella, That worked ok thanks.
stefan.riva
stefan.riva posted this 10 December 2015
how can I set the vertical menue to open downwards, not to to the right side.
I tried all 3 posibilities, Expand, on hover and with reload.
Stefan
Hi, how can I set the vertical menue to open downwards, not to to the right side. I tried all 3 posibilities, Expand, on hover and with reload. Stefan
Support Team posted this 11 December 2015
Unfortunately Themler does not support such type of the vertical menu at this time.
Hi, > how can I set the vertical menue to open downwards, not to to the right side. I tried all 3 posibilities, Expand, on hover and with reload. Unfortunately Themler does not support such type of the vertical menu at this time. Thank you, Olivia
enyonam
enyonam posted this 21 March 2016
- Change Style
Where do i find "Default Styles view" to select it. I dont see anything with that name in the software.
> To change default Vertical Menu style: > - Select Default Styles view > - Find Vertical Menu > - Click to Vertical Menu > - Change Style > This style will be part of Joomla Template. > User can add Vertical Menu in Joomla and default style will be used. > > To add Vertical Menu to Joomla page and change Style: > - Go to Joomla Admin Panel / Module Manager > - Add new Menu Module to the left position > - Click Advanced Tab > - Enter "vmenu" for Module Class Suffix > - Go back to Themler > - Click Refresh Content Button > - Click to Vertical Menu > - Change Vertical Menu Style Where do i find "Default Styles view" to select it. I dont see anything with that name in the software.
Support Team posted this 22 March 2016
The UI has changed a bit. Now it is under the Design tab >> More styles.
Hi, The UI has changed a bit. Now it is under the Design tab >> More styles. Sincerely, Hella
uvikmedium
uvikmedium posted this 12 June 2016
what about "how can I set the vertical menue to open downwards, not to to the right side."
Support Team posted this 16 June 2016
unfortunately there's no such option for Vertical Menu. It is designed to open the subitems to the right/
Hello, unfortunately there's no such option for Vertical Menu. It is designed to open the subitems to the right/ regards, Aileen
service23
service23 posted this 24 September 2016
I Have the same problem.
I don`t find Default Styles view in Vertical Menu.
I Have the same problem. I don`t find Default Styles view in Vertical Menu.
Support Team posted this 28 September 2016
@ WebGrafik-Design ,
the default style for vertical menu
http://attachments.answers.billiondigital.com/846/19846/Vertical-Menu-Reset-default-1.JPG
@ WebGrafik-Design , the default style for vertical menu http://attachments.answers.billiondigital.com/846/19846/Vertical-Menu-Reset-default-1.JPG Regards, Aileen
Seppe
Seppe posted this 11 June 2017
1 year later
what about an update to open the vertical menu downwards ??
At this moment, we still can't use because of it shortcommings.
greetings
> Hello, > unfortunately there's no such option for Vertical Menu. It is designed to open the subitems to the right/ > > regards, > Aileen 1 year later what about an update to open the vertical menu downwards ?? At this moment, we still can't use because of it shortcommings. greetings
Support Team posted this 13 June 2017
This behavior can be partially achieved by enabling responsive mode in Desktop under the Vertical Menu tab >> Responsive >> Display on... "Desktop or Less".
Hi, > what about an update to open the vertical menu downwards ?? This behavior can be partially achieved by enabling responsive mode in Desktop under the Vertical Menu tab >> Responsive >> Display on... "Desktop or Less". Thank you, Olivia
