Magento Custom Menu
jurjen
jurjen posted this 02 September 2015
Maybe this question is because of my lack of in-depth magento knowledge.
I would like to make a custom menu in my header. Right now I can place the default menu with login, my account, etc.
My question:
- How can I alter the contents of that menu?
- How can I create a custom menu that links to pages in the CMS of Magento.
The same applies for the footer menu, where can you alter the contents.
It is not the default footer_links and footer_links_admin static block.
There are no options in billion themler settings where you can edit this.
Is this hardcoded into the theme?
I think I could include a static block and make that block use div classes related to the themler menu classes, but it seems as a stupid way to do it. So probably it is hidden somewhere I haven't seen it?
Jurjen
Maybe this question is because of my lack of in-depth magento knowledge. I would like to make a custom menu in my header. Right now I can place the default menu with login, my account, etc. My question: - How can I alter the contents of that menu? - How can I create a custom menu that links to pages in the CMS of Magento. The same applies for the footer menu, where can you alter the contents. It is not the default footer_links and footer_links_admin static block. There are no options in billion themler settings where you can edit this. Is this hardcoded into the theme? I think I could include a static block and make that block use div classes related to the themler menu classes, but it seems as a stupid way to do it. So probably it is hidden somewhere I haven't seen it? Regards Jurjen
Support Team posted this 08 September 2015
Hi Jurjen,
For menus in Magento the following settings are available in Magento Admin >> Billion Themes >> [choose the theme] >> Settings:
1. It is possible to choose what categories to display in Horizontal and Vertical menu (all, current or none-for Vertical Menu block).
2. There is a possibility to display or hide the Home link and set the text for it.
Creating a custom menu and additional editing of existing menus is possible by manual editing theme files only (local.xml file). But please note that the file is overridden after export or save.
Hi Jurjen, For menus in Magento the following settings are available in Magento Admin >> Billion Themes >> [choose the theme] >> Settings: 1. It is possible to choose what categories to display in Horizontal and Vertical menu (all, current or none-for Vertical Menu block). 2. There is a possibility to display or hide the Home link and set the text for it. !i44.png! Creating a custom menu and additional editing of existing menus is possible by manual editing theme files only (local.xml file). But please note that the file is overridden after export or save. Sincerely, Nettie, BillionDigital Team
