Please add a map control
shaulhadar
shaulhadar posted this 10 October 2014
Hi Themeler Team. I really think it would be great if you could add a map control, so we can put fast google maps on themeler sites.
Thanks for your time,
Shaul.
Hi Themeler Team. I really think it would be great if you could add a map control, so we can put fast google maps on themeler sites. Thanks for your time, Shaul.
6 Comments
Support Team posted this 10 October 2014
As I understand, the Google map can be added as a code received from Google. In this case you can simply use the HTML control that was added for such purposes.
Hi, As I understand, the Google map can be added as a code received from Google. In this case you can simply use the HTML control that was added for such purposes. Sincerely, Hella BillionDigital Team
Stagger Lee posted this 03 April 2015
First, I know there are plenty of Gmap plugins for WordPress. Want just to ask for Themler Gmap option, as it reduce need for one extra plugin to be installed.
  • Is it difficult to make in Themler for Gmap API V3 (or is it V2 ?) code in Javascript to not use mousewheel scrolling of map ?
    Or with some CSS tweak.
As Themler works with full page width rows it gives very modern and elegant solutions for Gmaps in rows as very tipical Bootstrap Homepage.
Problem is only Gmap would need to be under footer, as you scroll with mouse wheel there is a stop on row with Gmap, you cannot scroll further.
Embed Gmap cannot so easy disable mousewheel scroll as i have seen.
First, I know there are plenty of Gmap plugins for WordPress. Want just to ask for Themler Gmap option, as it reduce need for one extra plugin to be installed. - Is it difficult to make in Themler for Gmap API V3 (or is it V2 ?) code in Javascript to not use mousewheel scrolling of map ? Or with some CSS tweak. As Themler works with full page width rows it gives very modern and elegant solutions for Gmaps in rows as very tipical Bootstrap Homepage. Problem is only Gmap would need to be under footer, as you scroll with mouse wheel there is a stop on row with Gmap, you cannot scroll further. Embed Gmap cannot so easy disable mousewheel scroll as i have seen.
Support Team posted this 06 April 2015
Sorry for the delay.
Currently Themler supports Google Map control. But in does not have the option to disable mouse wheel zooming.
I'll add your request to our wish list.
Hi, Sorry for the delay. Currently Themler supports Google Map control. But in does not have the option to disable mouse wheel zooming. I'll add your request to our wish list. Thank you, Olivia
Stagger Lee posted this 06 April 2015
Thank you. It would be good for page width Gmap in the middle of Bootstrap blocks.
But please take all this that is priority first. This with Gmap is not so important, as there are plenty of Gmap plugins.
For instance custom page templates, and copy widget/block and paste it to remain position in one px are much more important now.
Thank you. It would be good for page width Gmap in the middle of Bootstrap blocks. But please take all this that is priority first. This with Gmap is not so important, as there are plenty of Gmap plugins. For instance custom page templates, and copy widget/block and paste it to remain position in one px are much more important now.
JCMilleniuM
JCMilleniuM posted this 28 September 2016
Please make this option available, it is important to avoid installing plugins as it can make the site more vulnerable and add more maintenance tasks as the plugin has to be upgraded when there is a fault and if the maintainer updates it. Thanks.
shaulhadar
shaulhadar posted this 28 September 2016
Hi JC millennium, themler already fulfilled my wish, you have a map control, which works great....you will find it in the insert tab.....
