Backward link in paid version
Boekhoorn.nl
Boekhoorn.nl posted this 08 September 2015
Why is it that i get a backward link in a paid version to some website ?
And i can't edit it or change it to a link of my own.
This "hidden" advertisment should not be exsist in the paid version !
Why is it that i get a backward link in a paid version to some website ? And i can't edit it or change it to a link of my own. This "hidden" advertisment should not be exsist in the paid version !
Support Team posted this 08 September 2015
You mean the backward links in the bottom of the template? They can be removed easily, just delete the backward links control. To add your own links in the bottom just add a row and insert the text controls with the links and text.
Hi, You mean the backward links in the bottom of the template? They can be removed easily, just delete the backward links control. To add your own links in the bottom just add a row and insert the text controls with the links and text. Sincerely, Hella BillionDigital Team
lesergei
lesergei posted this 08 September 2015
There was the same in Artisteer, we could choose whether to display the options. In Themler, do not post this information works differently.
Hello, There was the same in Artisteer, we could choose whether to display the options. In Themler, do not post this information works differently.
michael31
michael31 posted this 25 September 2015
Sorry Hella, but you did not answer the question.
The question was not how to remove it.
I would like to know the same:
Why is it that i get a backward link to your homepage in a paid version ?
BRGDS,
Michael
Sorry Hella, but you did not answer the question. The question was not how to remove it. I would like to know the same: Why is it that i get a backward link to your homepage in a paid version ? BRGDS, Michael
Support Team posted this 28 September 2015
That is not an obligatory link, you can remove it with a single click.
In Artisteer the links were also automatically added, to disable them you should go to the options menu and uncheck several checkboxes. In Themler you need to simply delete the control.
This link exists in the trial version and in the activated one. That is a single theme and there is no option to automatically load the different theme without that control when you are logged in.
If you do not mind, that is a simple task to remove one control and that should not cause any issues.
Hi, That is not an obligatory link, you can remove it with a single click. In Artisteer the links were also automatically added, to disable them you should go to the options menu and uncheck several checkboxes. In Themler you need to simply delete the control. This link exists in the trial version and in the activated one. That is a single theme and there is no option to automatically load the different theme without that control when you are logged in. If you do not mind, that is a simple task to remove one control and that should not cause any issues. Sincerely, Hella
Nate
Nate posted this 17 November 2015
Really what would be nice is a way to set a global backward link, that would apply as the default to all sites that we import into our Themler. Especially for those of us that build more than a couple sites. If you want this to be a tool the devs use this needs to be an option. -IMHO
Support Team posted this 18 November 2015
Thanks for the suggestion.
Thanks for the suggestion. Sincerely, Hella
JohnR
JohnR posted this 27 January 2016
same here and probably everyone else.
