Please add Touch/Swipe For Slider
shaulhadar
shaulhadar posted this 15 September 2015
Hello Themler Team.
It would be really great if we could swipe to the next slide in the mobile and tablet versions of the sites :)
Also, i checked some of bootstrap's documentation and it has this option, so it can be done relatively easy i think..
here is another cool way i think :
http://lazcreative.com/blog/adding-swipe-support-to-bootstrap-carousel-3-0/
Hope it helps in anything, and thanks for your time!!
Shaul.
Hello Themler Team. It would be really great if we could swipe to the next slide in the mobile and tablet versions of the sites :) Also, i checked some of bootstrap's documentation and it has this option, so it can be done relatively easy i think.. here is another cool way i think : [http://lazcreative.com/blog/adding-swipe-support-to-bootstrap-carousel-3-0/][1] [1]: http://lazcreative.com/blog/adding-swipe-support-to-bootstrap-carousel-3-0/ Hope it helps in anything, and thanks for your time!! Shaul.
16 Comments
Stagger Lee posted this 15 September 2015
I would like in Global Settings options for adding Bootstrap JS parts, same as Smooth Wheel and Bootstrap ScrollSpy Plugin parts. So we can chose what goodies from Bootstrap are loaded when needed.
Same as here:
http://getbootstrap.com/customize/
Of course those needed in Themler as default can be removed and not made optional to chose.
Those fields for CSS controls can be removed. it would be confusing for majority of Themler Users.
I would like in Global Settings options for adding Bootstrap JS parts, same as Smooth Wheel and Bootstrap ScrollSpy Plugin parts. So we can chose what goodies from Bootstrap are loaded when needed. Same as here: http://getbootstrap.com/customize/ Of course those needed in Themler as default can be removed and not made optional to chose. Those fields for CSS controls can be removed. it would be confusing for majority of Themler Users.
Support Team posted this 17 September 2015
Hi guys,
As I can see bootstrap does not have native swipe feature. But we've added your suggestion to our wish list.
Do you mean that you want to load native bootstrap js libraries, e.g. tooltip.js?
Hi guys, > It would be really great if we could swipe to the next slide in the mobile and tablet versions of the sites :) Also, i checked some of bootstrap's documentation and it has this option, so it can be done relatively easy i think.. As I can see bootstrap does not have native swipe feature. But we've added your suggestion to our wish list. > I would like in Global Settings options for adding Bootstrap JS parts, same as Smooth Wheel and Bootstrap ScrollSpy Plugin parts. So we can chose what goodies from Bootstrap are loaded when needed. Do you mean that you want to load native bootstrap js libraries, e.g. tooltip.js? Thank you, Olivia
Stagger Lee posted this 17 September 2015
Yes Olivia, something like this.
Difference between your Bootstrap JS and original Bootstrap with all components is about 10 kB (non compressed). Why not put them all inside, it is not so heavy cost for page load.
Or if you are worried about file sizes give us options in Settings tab what to include.
Yes Olivia, something like this. Difference between your Bootstrap JS and original Bootstrap with all components is about 10 kB (non compressed). Why not put them all inside, it is not so heavy cost for page load. Or if you are worried about file sizes give us options in Settings tab what to include.
Support Team posted this 18 September 2015
Hi Stagger,
Ok, I've added your suggestion to our wish list too.
Hi Stagger, Ok, I've added your suggestion to our wish list too. Thank you, Olivia
shaulhadar
shaulhadar posted this 03 April 2016
Olivia, please check out the swiper slider by idangerous. It is used in the framework 7 app framework, but it ic currently the smoothest performing slider i have seen for html, also it has the best swipe performance out there...
shaulhadar
http://idangero.us/swiper/#.VwChsBJRW2c
Support Team posted this 06 April 2016
Thanks for the example. Keep on voting for the feature.
Hi, Thanks for the example. Keep on voting for the feature. Sincerely, Hella
fngatia
fngatia posted this 25 November 2016
Do we really have to VOTE for this feature to be implemented. It has been a while now. Even you as support team you know that users who access websites with smart phones and other touch devices expects to swipe to scroll. Please implement this feature.
Stagger Lee posted this 25 November 2016
Seems as it is not so difficult to implement:
Seems as it is not so difficult to implement: http://lazcreative.com/blog/adding-swipe-support-to-bootstrap-carousel-3-0/
It is difficult for some reason. Trying for several hour now, nothing works.
Now I got it to work with one WP small plugin. But only with full Bootstrap JS copied over Themler bootstrap JS code.
So it is something Themler developers need to add. Difficult now to go through all code and see what is missing for Bottstrap carousel.
https://github.com/Shahab2905/Bootstrap-Carousel-Touch-Swipe-Support
Now I got it to work with one WP small plugin. But only with full Bootstrap JS copied over Themler bootstrap JS code. So it is something Themler developers need to add. Difficult now to go through all code and see what is missing for Bottstrap carousel. https://github.com/Shahab2905/Bootstrap-Carousel-Touch-Swipe-Support
Ok now. Problem with this solution is I have no clue if it will make some undesired effects with TH theme editin or theme functions in the future. Developers, please make one new option in Slider(s) to activate or not swipe option. As I can see this one should not be difficult task for you and you would make all Phone/Tablet users happy.
Code formatting here at forum is useless.
Ok now. Problem with this solution is I have no clue if it will make some undesired effects with TH theme editin or theme functions in the future. Developers, please make one new option in Slider(s) to activate or not swipe option. As I can see this one should not be difficult task for you and you would make all Phone/Tablet users happy. - Install plugin (WordPress only) from this link (there are no options in plugin) https://github.com/Shahab2905/Bootstrap-Carousel-Touch-Swipe-Support - Add this code to HTML Control on pages where you have Slider, to not to use it globally everywhere (place control under footer): http://pastebin.com/1MReYvqm - Test and give feedback if you have any problems. Code formatting here at forum is useless.
Support Team posted this 28 November 2016
Thanks for your workaround. The suggestion is in our wish list.
Thanks for your workaround. The suggestion is in our wish list. Sincerely, Hella
fngatia
fngatia posted this 30 March 2017
How far? Its been long!
Support Team posted this 30 March 2017
We do not have a lot of votes for this feature and it is not in our roadmap for now.
Hi, We do not have a lot of votes for this feature and it is not in our roadmap for now. Sincerely, Hella
pawel-ga
pawel-ga posted this 13 March 2019
It's now mobile UX standard. Is possible to add swipe to slider ?
