Unite Revolution Slider doesn't work with Themler
dg24
dg24 posted this 15 September 2015
Dear Themler Team,
I am currently running into trouble concerning the usage of Unite Revolution Slider in combination with my Themler theme. The problem is that it always only shows the first slide but hides the images of all other slides. The page in question can be found here:
http://www.lpsv-albfils.de
I have already tried the possibilities of the slider (move jQuery into body/head; no conflict mode) but the problem is always the same. I also tried it with a non-Themler template - just to be sure - and there it worls fine.
Any suggestions what I can do? Thanks already a lot for reading this and your support,
Best regards, Dan
Dear Themler Team, I am currently running into trouble concerning the usage of Unite Revolution Slider in combination with my Themler theme. The problem is that it always only shows the first slide but hides the images of all other slides. The page in question can be found here: http://www.lpsv-albfils.de I have already tried the possibilities of the slider (move jQuery into body/head; no conflict mode) but the problem is always the same. I also tried it with a non-Themler template - just to be sure - and there it worls fine. Any suggestions what I can do? Thanks already a lot for reading this and your support, Best regards, Dan
6 Comments
Support Team posted this 15 September 2015
There is quite simple and nice workaround:
http://answers.themler.com/articles/15575/themler-themes-troubleshooting
Ivan
Hi, There is quite simple and nice workaround: http://answers.themler.com/articles/15575/themler-themes-troubleshooting Please let us know if you have any further questions. Thanks, Ivan
dg24
Works like a charm, thanks a lot :) Is it possible to add this somewhere into Themler as a standard so I don't have to remember that in 5-6 months when the next project is being worked on.
Support Team posted this 16 September 2015
Actually it is not convenient to include the additional code in all the templates that is used to fix the conflict with some plug-in. So in case you have such issue once again, please feel free to contact us and we'll point to the solution once again.
By the way, the problem is also related to some incompatibility with the Bootstrap from the Revolution Slider side.
Hi, Actually it is not convenient to include the additional code in all the templates that is used to fix the conflict with some plug-in. So in case you have such issue once again, please feel free to contact us and we'll point to the solution once again. By the way, the problem is also related to some incompatibility with the Bootstrap from the Revolution Slider side. Sincerely, Hella
MTed
MTed posted this 16 November 2015
I have the same problem but the CSS fix shown at the link didn't correct the issue:
#rev_slider_1_1 li{
    position:absolute;
This is happening with installations of Revolution Slider 4 and 5, regardless of the .dot release. Is there another option that I can try?
I have the same problem but the CSS fix shown at the link didn't correct the issue: #rev_slider_1_1 li{ position:absolute; } This is happening with installations of Revolution Slider 4 and 5, regardless of the .dot release. Is there another option that I can try?
Support Team posted this 17 November 2015
Hi Mark,
Sorry for the issue.
Could you please create a new private ticket and provide us with your WP theme there for investigation.
Ivan
Hi Mark, Sorry for the issue. Could you please create a new private ticket and provide us with your WP theme there for investigation. Thanks, Ivan
MTed
MTed posted this 17 November 2015
We'll do. Thank you Ivan.
