Magento checkout page: How can I add & capture custom field information in shipping address?
ecommerce.dev
ecommerce.dev posted this 16 September 2015
I need to add a custom field to the checkout process. I have created a text field on the front-end where a user can enter their alternate address.
The issue is that how can I capture this information in both backend & user account?
I need to add a custom field to the checkout process. I have created a text field on the front-end where a user can enter their alternate address. The issue is that how can I capture this information in both backend & user account?
Support Team posted this 17 September 2015
Hello Paul,
we'll contact developers about possible solution and will let you know.
Hello Paul, we'll contact developers about possible solution and will let you know. Regards, Aileen
Simon Walker
Simon Walker posted this 22 September 2015
I would suggest to use a ready-made tool in order to add and collect all the data inserted in the custom fields of the checkout page.
Try this extension by FME: http://www.fmeextensions.com/magento-additional-checkout-attributes-fields.html
Using this extension, you can add multiple fields to the checkout page and include them in shipping PDFs.
I would suggest to use a ready-made tool in order to add and collect all the data inserted in the custom fields of the checkout page. Try this extension by FME: [http://www.fmeextensions.com/magento-additional-checkout-attributes-fields.html][1] Using this extension, you can add multiple fields to the checkout page and include them in shipping PDFs. [1]: http://www.fmeextensions.com/magento-additional-checkout-attributes-fields.html
Support Team posted this 23 September 2015
Hello Simon,
thank you for your suggestion. But we're trying not to use commercial extensions for our themes.
Hello Simon, thank you for your suggestion. But we're trying not to use commercial extensions for our themes. regards, Aileen
Support Team posted this 28 September 2015
Hello Paul,
we'd recommend that you consider following one of existing tutorials:
https://indiestechtips.wordpress.com/2011/07/30/how-to-add-custom-field-in-the-billing-and-shipping-address-of-onepage-checkout-in-magento/
http://magentoabid.blogspot.com/2012/08/how-to-add-custom-field-in-one-page.html
Hello Paul, we'd recommend that you consider following one of existing tutorials: https://indiestechtips.wordpress.com/2011/07/30/how-to-add-custom-field-in-the-billing-and-shipping-address-of-onepage-checkout-in-magento/ http://magentoabid.blogspot.com/2012/08/how-to-add-custom-field-in-one-page.html regards, Aileen
perrywhite25
perrywhite25 posted this 17 November 2015
Though you are trying not to use commercial extensions, sometimes that might be justified. Moreover, users can install such extensions themselves on any theme.
You can look at this extension for adding custom fields https://amasty.com/order-attributes.html
However, if this is just a one-time request and only 1 field is needed, it can be added programmatically.
Though you are trying not to use commercial extensions, sometimes that might be justified. Moreover, users can install such extensions themselves on any theme. You can look at this extension for adding custom fields https://amasty.com/order-attributes.html However, if this is just a one-time request and only 1 field is needed, it can be added programmatically.
henryroger340
henryroger340 posted this 18 July 2016
You can see the following step by step tutorial on how to add custom field in Magento Checkout page.
http://www.demagento.com/tutorial-magento-add-custom-field-to-order-checkout-page/
You can see the following step by step tutorial on how to add custom field in Magento Checkout page. http://www.demagento.com/tutorial-magento-add-custom-field-to-order-checkout-page/
alexei.kovalev
alexei.kovalev posted this 26 October 2017
Hello ecommerce.dev,
one way how you can solve this problem is by intalling the Quick One Page Checkout extention for Magento by Itoris Inc: https://www.itoris.com/magento-one-page-checkout.html
> I need to add a custom field to the checkout process. I have created a text field on the front-end where a user can enter their alternate address. > The issue is that how can I capture this information in both backend & user account? Hello ecommerce.dev, one way how you can solve this problem is by intalling the Quick One Page Checkout extention for Magento by Itoris Inc: https://www.itoris.com/magento-one-page-checkout.html
