Since update no copy function for slider ?
troncom
troncom posted this 17 September 2015
Hi, I can not use the copy button since the last update the copy button is grayed out ...
I use Joomla latest version.
Does anyone have similar problems ?
regards
Hi, I can not use the copy button since the last update the copy button is grayed out ... I use Joomla latest version. Does anyone have similar problems ? regards
Support Team posted this 18 September 2015
The "Copy" option is active for the Slider for me in Joomla:
Is the issue present in a specific Theme only?
Hello, The "Copy" option is active for the Slider for me in Joomla: !i64.png! Is the issue present in a specific Theme only? Sincerely, Nettie, BillionDigital Team
radwaalielashry
radwaalielashry posted this 28 January 2019
i wanna to add and copy the first and second slider >> how i do it in last version ..!!
Support Team posted this 28 January 2019
In the latest version it can be done in the Slider tab >> Slides >> select the slide number >> Add >> Duplicate Slide.
To copy the currently selected slide you may alternatively right-click on the slider and select Duplicate slide.
To copy the whole Slider control right-click the slider and click >> Copy. Then right-click any other control or container and click Paste.
Hello, In the latest version it can be done in the Slider tab >> Slides >> select the slide number >> Add >> Duplicate Slide. To copy the currently selected slide you may alternatively right-click on the slider and select Duplicate slide. To copy the whole Slider control right-click the slider and click >> Copy. Then right-click any other control or container and click Paste. Sincerely, Nettie
