Themler v.99 Hotfix Update (29-September-2015)
Support Team posted this 28 September 2015
Hi guys!
The new Themler HotFix update includes the following features and fixes:
New
  • Added Section ID field. Usually used for One Page Designs.
  • SVG icons can now be used in Themler as cliparts:
New Sections
and more...
Fixes:
  • Fixed issue with Outline drag&drop in FireFox.
  • Fixed issue with Section add timeout.
  • Fixed crash on picture add.
  • Fixed issue with PHP versions lower than 5.4.
  • Fixed issue with Live Preview in IE.
  • Fixed display issue of the Sidebars control with "Expand to Bottom" extension in IE.
  • Fixed Footer issue in IE.
  • Fixed issue with height of absolute and fixed controls with "Fix on Scroll" extension.
  • Fixed issue with changing Breadcrumbs separator.
  • Fixed issue with Social Icons control fill.
  • Fixed issue with Horizontal Menu center alignment in Phone responsive mode.
  • Fixed crash when exporting Section as ZIP.
  • HTML: fixed issue with inserting Section.
  • HTML: fixed issue with "Smooth Scrolling" extension.
  • HTML: fixed issue with wrong navigation from pages and posts after adding new page.
  • PrestaShop: fixed issue with BlockLayered filters.
  • PrestaShop: fixed issue with Product Pagination.
  • Joomla: fixed crash on copying Joomla position control.
  • joomla: fixed issue with redirecting Home template to Default.
  • Joomla: fixed issues with conversion of Artisteer templates.
  • Joomla: added translation for Search Button value.
  • Joomla: fixed issue with Notice in the search box.
  • Magento: fixed issue with adding Related Products to Shopping Cart.
  • Fixed other minor issues and bugs.
Themler Team
[post:30240]
35 Comments
jurjen
jurjen posted this 29 September 2015
Hi Guys,
The hot-fix created a new error with (at least) magento. I will post this separately.
Jurjen
Hi Guys, The hot-fix created a new error with (at least) magento. I will post this separately. Regards Jurjen
Stagger Lee posted this 29 September 2015
Thank you. Just checked SVG Icons, nice addition.
Can you reconsider how they are made in Themler. One (not main) of the reasons they exist is reduced HTTP requests.
If we make say for example total 20-30 SVG Icons on one page (20-30 separate HTTP requests) can you make them in one SVG file, as Themler default icons ? Or merge them in existing Themler SVG Icons file ?
How to change color of icons ? As they are SVG Icons it should go very smooth, no need for recoloring as Themler does for images, or as PhotoShop does.
Missing Text, Paragraphs, Font options, as SVG Icons are easy manipulated with them.
Thank you. Just checked SVG Icons, nice addition. Can you reconsider how they are made in Themler. One (not main) of the reasons they exist is reduced HTTP requests. If we make say for example total 20-30 SVG Icons on one page (20-30 separate HTTP requests) can you make them in one SVG file, as Themler default icons ? Or merge them in existing Themler SVG Icons file ? How to change color of icons ? As they are SVG Icons it should go very smooth, no need for recoloring as Themler does for images, or as PhotoShop does. Missing Text, Paragraphs, Font options, as SVG Icons are easy manipulated with them.
Michal Witt
Michal Witt posted this 30 September 2015
Thank You!
Now Horizontal Menu center alignment in Phone mode works very well.
Michal
Thank You! Now Horizontal Menu center alignment in Phone mode works very well. Regards Michal
Marco
Marco posted this 30 September 2015
Guys...
nice update but: why you come with new features, but not fixing bugs, which were reported (not only from me)?
-> STYLES -> ALERTS -> STILL NOT WORKING (no edit options!)
-> Adding VMenu in Footer 1, will not fetch in inside Themler, so I´m not able to style the Nav-Module in this Position
Also in new Version, speed is horrible.
Also in new Version, Firefox crashed 5 times within 10mins...
So, when will you fix this Bugs (Styles Area is very! important!)
regards, Marco
Guys... nice update but: why you come with new features, but not fixing bugs, which were reported (not only from me)? -> STYLES -> ALERTS -> STILL NOT WORKING (no edit options!) -> Adding VMenu in Footer 1, will not fetch in inside Themler, so I´m not able to style the Nav-Module in this Position Also in new Version, speed is horrible. Also in new Version, Firefox crashed 5 times within 10mins... So, when will you fix this Bugs (Styles Area is very! important!) regards, Marco
Marco
Also there should be an option for adding backlinks.
But not for Themler (in a PRO Version there should be an Option for that!) but for ME as agency.
Also there should be an option for adding backlinks. But not for Themler (in a PRO Version there should be an Option for that!) but for ME as agency.
shaulhadar
shaulhadar posted this 30 September 2015
Hi Marco, actually to add backlinks all you need to do is just delete the themler backlinks, and add a container with a text control, than just write what you need, and edit a link inside the text to whatever site you want to..
I did it lots of times, its really easy... if you don't understand my instructions let me know and i will try to explain better..
Hi Marco, actually to add backlinks all you need to do is just delete the themler backlinks, and add a container with a text control, than just write what you need, and edit a link inside the text to whatever site you want to.. I did it lots of times, its really easy... if you don't understand my instructions let me know and i will try to explain better..
lesergei
lesergei posted this 30 September 2015
Marco
shaulhader
And as I have written elsewhere, if you use the optional section, you can export it and use it on another site, with simple adjustment if necessary.
And now for the support team. See my picture. :)
thank you
Marco ***Also there should be an option for adding backlinks.*** shaulhader ***add a container with a text control, than just write what you need, and edit a link inside the text to whatever site you want to..*** Hello, And as I have written elsewhere, if you use the optional section, you can export it and use it on another site, with simple adjustment if necessary. And now for the support team. See my picture. :) !repeat.jpg! thank you
Support Team posted this 30 September 2015
Marco,
We're aware about the issue with FF 41 and our developers are working on it.
In the meantime you can use Chrome for Themler.
These issues will be fixed in the next hot-fix update.
Serge,
Here blue box is the zone to repeat image.
Repeat Vertically - css repeat-y
Repeat Horizontally - css repeat-x
**Marco,** > Also in new Version, Firefox crashed 5 times within 10mins... We're aware about the issue with FF 41 and our developers are working on it. In the meantime you can use Chrome for Themler. > So, when will you fix this Bugs (Styles Area is very! important!) These issues will be fixed in the next hot-fix update. **Serge,** Here blue box is the zone to repeat image. Repeat Vertically - css repeat-y Repeat Horizontally - css repeat-x Thank you, Olivia
lesergei
Hi Olivia,
I see now, I must admit not having understood your iconography. I saw the gray cube as being the object that was repeated to the left (horizontal) or down (vertical).
Sorry for taking your time for this message without much importance.
Hi Olivia, I see now, I must admit not having understood your iconography. I saw the gray cube as being the object that was repeated to the left (horizontal) or down (vertical). Sorry for taking your time for this message without much importance. Thank you
eviltwin
eviltwin posted this 30 September 2015
when is the issue of the horizontal menu not being responsive going to be fixed?
And now it won't let me access my themes.
when is the issue of the horizontal menu not being responsive going to be fixed? And now it won't let me access my themes.
philippe.pphantom
philippe.pphantom posted this 01 October 2015
rather than add new functions it's will be better to correct the countless bugs still present
Marco
Marco posted this 01 October 2015
When the next update will come? Why not fixed in THIS update, even you know about this bug?!
bR Marco
> These issues will be fixed in the next hot-fix update When the next update will come? Why not fixed in THIS update, even you know about this bug?! bR Marco
Support Team posted this 01 October 2015
Serge,
Thank you for your comments.
May,
Do you mean the issue when the menu with center alignment is not responsive in Phone mode?
We've already fixed this issue is the recent Hotfix update.
If the issue continues on your side please create a new Private topic and provide the link to the problem theme so we can see the issue.
Marco,
We've fixed these issues before the latest update but have not included the fix due to some testing problems.
The next hot-fix update will be released in the near future. We're awaiting for a few more fixes from our developers.
We apologize for any inconvenience.
**Serge,** Thank you for your comments. **May,** Do you mean the issue when the menu with center alignment is not responsive in Phone mode? We've already fixed this issue is the recent Hotfix update. If the issue continues on your side please create a new Private topic and provide the link to the problem theme so we can see the issue. **Marco,** We've fixed these issues before the latest update but have not included the fix due to some testing problems. The next hot-fix update will be released in the near future. We're awaiting for a few more fixes from our developers. We apologize for any inconvenience. Thank you, Olivia
manet2000ro
manet2000ro posted this 01 October 2015
I just installed this update last night and now whatever I add to the homepage it shows up on ALL the other pages too!!
I don't want that, how do I fix this?
Here's the site: http://reallyorganics.com
Rob
I just installed this update last night and now whatever I add to the homepage it shows up on ALL the other pages too!! I don't want that, how do I fix this? Here's the site: http://reallyorganics.com Thanks, Rob
Support Team posted this 02 October 2015
Hi Robert,
Do you mean the block with mushrooms?
You added it inside the Header area. This area is used to share controls between templates. If you want this block to appear on the Home template only please add it outside Header(with orange borders).
Hi Robert, Do you mean the block with mushrooms? You added it inside the Header area. This area is used to share controls between templates. If you want this block to appear on the Home template only please add it outside Header(with orange borders). Thank you, Olivia
rene-meyer
rene-meyer posted this 07 October 2015
Hallo,
wieso kann ich das Update nirgends downloaden?
Grüße...
Hallo, wieso kann ich das Update nirgends downloaden? Grüße...
Support Team posted this 07 October 2015
You can download the latest version from the themler.com site. Here is the link:
http://downloads.themler.com/Themler.1.0.93.95c52.exe
Hi, You can download the latest version from the themler.com site. Here is the link: http://downloads.themler.com/Themler.1.0.93.95c52.exe Sincerely, Hella
Stagger Lee posted this 07 October 2015
Some news to follow:
https://make.wordpress.org/core/2015/10/07/single-post_type-post_name-php-new-theme-template-in-wordpress-4-4/
Some news to follow: https://make.wordpress.org/core/2015/10/07/single-post_type-post_name-php-new-theme-template-in-wordpress-4-4/
rene-meyer
rene-meyer posted this 08 October 2015
Ok danke... Ich dachte 1.0.99... ist die letzte Version....
> Hi, > > You can download the latest version from the themler.com site. Here is the link: > http://downloads.themler.com/Themler.1.0.93.95c52.exe > > Sincerely, > Hella Ok danke... Ich dachte 1.0.99... ist die letzte Version....
Vitaliy WD
Vitaliy WD posted this 13 October 2015
Hello.
When will be avalaible new update and when will be available editor with shortcodes for Joomla (CMS Content Editing)?
Hello. When will be avalaible new update and when will be available editor with shortcodes for Joomla (CMS Content Editing)?
