WooCommerce "Product New" controller text
wdigital
wdigital posted this 07 October 2015
Hi, how can I change the text inside the product controller "new" in woocommerce?
Is this controlled by the theme translation? or I can change that in themler editor?
tks!
Hi, how can I change the text inside the product controller "new" in woocommerce? Is this controlled by the theme translation? or I can change that in themler editor? tks!
Support Team posted this 08 October 2015
You can only change the mentioned New text from your WordPress localization/translation) files.
Ivan
Hi, You can only change the mentioned **New** text from your WordPress localization/translation) files. Thanks, Ivan
M2L - Comunicación Visual
M2L - Comunicación Visual posted this 24 May 2017
Necesito cambiar el texto NEW! de woocommerce y no está donde lo indicas....
Necesito cambiar el texto **NEW!** de woocommerce y **no está** donde lo indicas....
Support Team posted this 24 May 2017
Simply open translation file you're using (.po), find the New key and change the translation text. Then you need to regenerate .mo file. You can do it all in PoEdit or download corresponding WP plugin, for example, Loco Translate.
Hi, Simply open translation file you're using (.po), find the `New` key and change the translation text. Then you need to regenerate .mo file. You can do it all in PoEdit or download corresponding WP plugin, for example, Loco Translate. Thank you, Olivia
