Drupal 8 RC - Release Candidat is out
Stagger Lee posted this 08 October 2015
First release candidat is out. You can start adapting Themler to Drupal 8.
https://www.drupal.org/drupal-8.0.0-rc1?utm_source=drupal-newsletter&utm_medium=email&utm_campaign=drupal-newsletter-20151008
First release candidat is out. You can start adapting Themler to Drupal 8. https://www.drupal.org/drupal-8.0.0-rc1?utm_source=drupal-newsletter&utm_medium=email&utm_campaign=drupal-newsletter-20151008
35 Comments
Support Team posted this 08 October 2015
Hi Stagger,
We're aware about it.
Our developers are working on Drupal 8 compatibility. But the export plug-in will be available after the final Drupal 8 release.
Hi Stagger, We're aware about it. Our developers are working on Drupal 8 compatibility. But the export plug-in will be available after the final Drupal 8 release. Thank you, Olivia
Yes.
I have to learn Symphony and Twig.
Yes. I have to learn Symphony and Twig.
grupoguzman
grupoguzman posted this 13 October 2015
any update?
any update?
Support Team posted this 13 October 2015
Drupal 8 is still on RC stage.
Themler themes for Drupal 8 will be available after the final Drupal 8 release.
Hi, Drupal 8 is still on RC stage. Themler themes for Drupal 8 will be available after the final Drupal 8 release. Thank you, Olivia
Stagger Lee posted this 30 October 2015
https://www.drupal.org/node/2605142
Drupal 8.0.0 will be released on November 19, 2015
https://www.drupal.org/node/2605142 **Drupal 8.0.0 will be released on November 19, 2015**
Support Team posted this 01 November 2015
Yes, we're aware about release date.
Our developers are working on Drupal 8 support.
Hi, Yes, we're aware about release date. Our developers are working on Drupal 8 support. Thank you, Olivia
Alexander Dzhuninski
Alexander Dzhuninski posted this 26 November 2015
Have some progres for drupal 8?
Support Team posted this 26 November 2015
We are actively working on Drupal 8 compatibility.
Drupal 8 is a completely new CMS. This task requires creating of new export. We need some time for this.
But we have a good progress.
Drupal 8 export is coming soon.
Hi, We are actively working on Drupal 8 compatibility. Drupal 8 is a completely new CMS. This task requires creating of new export. We need some time for this. But we have a good progress. Drupal 8 export is coming soon. Thank you, Olivia
cm
cm posted this 28 December 2015
Any news on drupal 8 export?
Also 24.12.2015 version Drupal news..?
Why so less drupal themes? Why you dont convert existing themes to Drupal?
Any news on drupal 8 export? Also 24.12.2015 version Drupal news..? Why so less drupal themes? Why you dont convert existing themes to Drupal?
Support Team posted this 06 January 2016
Sorry for the delay.
Unfortunately existing Drupal 7 themes can't be converted to Drupal 8.
Drupal 8 is a completely different non-PHP CMS. Therefore we're working on creating separate export for Drupal 8. It requires some time.
Hi, Sorry for the delay. Unfortunately existing Drupal 7 themes can't be converted to Drupal 8. Drupal 8 is a completely different non-PHP CMS. Therefore we're working on creating separate export for Drupal 8. It requires some time. Thank you, Olivia
Stagger Lee posted this 25 January 2016
On a scale from 0 % to 100% how close you are to have it finished ? We wont take you for granted, it can be just some direction.
I am waiting whole time because dont wont now to make all for Drupal 7, and again for Drupal 8.
On a scale from 0 % to 100% how close you are to have it finished ? We wont take you for granted, it can be just some direction. I am waiting whole time because dont wont now to make all for Drupal 7, and again for Drupal 8.
Renaming Drupal themes ends in error loop.
"The website encountered an unexpected error. Please try again later." on frontend too.
Seems as you did not account for when theme is renamed Themler edit screen has nothing to work with anymore. This URL in browser after renaming leads to not existing theme.
Make it so it switch with new URL with correct theme name. I see it calls old one.
Problems on frontend can depend on Themler did not made it to "Save" and whole process of adapting to new theme name is interrupted. But I just guess here.
Renaming Drupal themes ends in error loop. "The website encountered an unexpected error. Please try again later." on frontend too. Seems as you did not account for when theme is renamed Themler edit screen has nothing to work with anymore. This URL in browser after renaming leads to not existing theme. Make it so it switch with new URL with correct theme name. I see it calls old one. Problems on frontend can depend on Themler did not made it to "Save" and whole process of adapting to new theme name is interrupted. But I just guess here.
Sorry, other admin links show this error. Frontend has this one: Warning: Invalid argument supplied for foreach() in D:\EasyPHP\eds-www\theme\includes\module.inc on line 1118
Support Team posted this 27 January 2016
about 50-60
I've checked this issue on my side but renaming works just fine.
Could you please create a separate private topic so we can investigate this issue.
Hi, > On a scale from 0 % to 100% how close you are to have it finished ? about 50-60 > Renaming Drupal themes ends in error loop. I've checked this issue on my side but renaming works just fine. Could you please create a separate private topic so we can investigate this issue. Thank you, Olivia
tommy
tommy posted this 27 January 2016
need drupal 8 theme. and release date please.
Alexander Dzhuninski posted this 28 January 2016
Yes, in did whats happens with Drupal 8 support, a lot of time gone...no any results....?
Support Team posted this 28 January 2016
We are terribly sorry but the Drupal plug-in is developed by the external developer and we can not provide the date of release for sure. But we'll release it as soon as possible.
We are terribly sorry but the Drupal plug-in is developed by the external developer and we can not provide the date of release for sure. But we'll release it as soon as possible. Sincerely, Hella
Alexander Dzhuninski posted this 15 February 2016
Some news, about progress ? Some hope........?
Support Team posted this 16 February 2016
The developer responded that Drupal 8 support is ready at about 60%-70%.
Hi, The developer responded that Drupal 8 support is ready at about 60%-70%. Thank you, Olivia
