Sorry, an error has occurred. Please clear your browser cache.
Marco
Marco posted this 10 October 2015
Okay, Now it isnt really funny.
Tried nearly 30 minutes, tried different browsers, delete cache dotzends of times...
nothing works.
WHATS WRONG HERE!??? How could something like this be!!!?
What I did:
Uploaded existing theme. Installed in latest JVersion. Tried to OPEN and EDIT Theme.
Then this error occurs...
Okay, Now it isnt really funny. Tried nearly 30 minutes, tried different browsers, delete cache dotzends of times... nothing works. WHATS WRONG HERE!??? How could something like this be!!!? What I did: Uploaded existing theme. Installed in latest JVersion. Tried to OPEN and EDIT Theme. Then this error occurs...
13 Comments
Support Team posted this 10 October 2015
Please provide an access to your site so we could see the problem. I have moved this case to private so you could post the details here.
Hi, Please provide an access to your site so we could see the problem. I have moved this case to private so you could post the details here. Sincerely, Hella
MercurioWeb WebStudio
MercurioWeb WebStudio posted this 14 December 2015
I have the same problem, when I open themler on my win 10 and I select "joomla". as the attached file
Support Team posted this 15 December 2015
Hi Salvatore,
Please feel free to create new private ticket and provide us with your zipped problem template there.
You can find it under:
C:\ProgramData\Themler\hd_data\themler_some_digits\joomla\templates
Ivan
Hi Salvatore, Please feel free to create new private ticket and provide us with your zipped problem template there. You can find it under: C:\ProgramData\Themler\hd_data\themler_some_digits\joomla\templates Thanks, Ivan
GFitch
GFitch posted this 04 February 2016
To fix the problem relating the error message" Sorry, an error has occurred. Please clear your browser cache. "
This error in my experience, was caused by a faulty Joomla template which when closed stopped Themler opening up a new
template of the same type.
To resolve this; go to the folder in which the Themler software is installed (mine is situated in the ProgramData folder
in the 'C' drive for example).
You will see a folder named 'templates'
Click on this folder to open it and there you will see the template names you have stopped within
(in my case) Joomla CMS. (I created a shortcut to thius folder to clean-up unwanted templates).
Delete the last template you were working on immediately prior to the problem occurring (do NOT delete anything else); and then exit all folders.
Now re-open Themler and select the CMS option that was causing your the problem, which in my case was a Joomla template.
Joomla CMS shopuld now open properly.
Hope this helps...
To fix the problem relating the error message" Sorry, an error has occurred. Please clear your browser cache. " This error in my experience, was caused by a faulty Joomla template which when closed stopped Themler opening up a new template of the same type. To resolve this; go to the folder in which the Themler software is installed (mine is situated in the ProgramData folder in the 'C' drive for example). You will see a folder named 'templates' Click on this folder to open it and there you will see the template names you have stopped within (in my case) Joomla CMS. (I created a shortcut to thius folder to clean-up unwanted templates). Delete the last template you were working on immediately prior to the problem occurring (do NOT delete anything else); and then exit all folders. Now re-open Themler and select the CMS option that was causing your the problem, which in my case was a Joomla template. Joomla CMS shopuld now open properly. Hope this helps...
printed
printed posted this 13 June 2016
Helps this.
1. Copy the template to another site.
2. To install a template.
3. Open it in Themler.
4. Save the template with a different name.
5. To install a template to a website where there were problems.
Helps this. 1. Copy the template to another site. 2. To install a template. 3. Open it in Themler. 4. Save the template with a different name. 5. To install a template to a website where there were problems.
Scorpion Computers & Software
Scorpion Computers & Software posted this 06 June 2017
All of these solutions do not work for me.
I have tried in several browsers
I have copied the full template folder to a different site (and server)
I have clear browser cache
But i still get the same result:
All of these solutions do not work for me. I have tried in several browsers I have copied the full template folder to a different site (and server) I have clear browser cache But i still get the same result: Sorry, an error has occurred. Please clear your browser cache.
Support Team posted this 06 June 2017
Please create a separate private topic and provide an access to your site back end so we could review the problem.
Hi, Please create a separate private topic and provide an access to your site back end so we could review the problem. Sincerely, Hella
GT-WebDesign
GT-WebDesign posted this 3 weeks ago
I have the same problem in three types of browsers. Nothing of the above helps so far.
Can you please help me?
Ger
Hi, I have the same problem in three types of browsers. Nothing of the above helps so far. Can you please help me? Regards, Ger
iMediaDesign
iMediaDesign posted this 3 weeks ago
Same here, I also have the same problem, from nowhere themler stoped working. I have tried both chrome and firefox.
Please help!!!!!!
/Thomas
Same here, I also have the same problem, from nowhere themler stoped working. I have tried both chrome and firefox. Please help!!!!!! /Thomas
The reasons for the issue can be various. Still we would recommend to try these steps first:
1) Open this URL in Chrome:
chrome://appcache-internals
2) Open this URL in Chrome:
Let us know if the issue is still present.
Hello, The reasons for the issue can be various. Still we would recommend to try these steps first: 1) Open this URL in Chrome: chrome://appcache-internals find your website and click on 'Remove Item' 2) Open this URL in Chrome: chrome://settings/clearBrowserData select 'Cached images and files ' and click on 'Clear Data' (please don't check other check-boxes). 3) Reload your Themler Editor. Let us know if the issue is still present. Sincerely, Nettie
GT-WebDesign
GT-WebDesign posted this 2 weeks ago
The issue is still present and I'm running Themler on the server, not on the pc.
Regards Ger
Hello, The issue is still present and I'm running Themler on the server, not on the pc. Regards Ger
GT-WebDesign
Please help me with this problem!!
Hello Ger,
Could you please create a new private topic and provide temporary access to your website for investigation?
Hello Ger, Could you please create a new private topic and provide temporary access to your website for investigation? Sincerely, Nettie
