Responsive submenus do not open on click in joomla
rick43
rick43 posted this 15 October 2015
I have the latest version on Themler and responsive menus do not open the submenu on click. The menus work fine on other devices.
Changing the submenu to expanded works, but this creates a very sloppy menu if the menu is large.
I have read that this was fixed, but is appears to still not work
I have the latest version on Themler and responsive menus do not open the submenu on click. The menus work fine on other devices. Changing the submenu to expanded works, but this creates a very sloppy menu if the menu is large. I have read that this was fixed, but is appears to still not work
Support Team posted this 16 October 2015
I can not reproduce the problem on my end. When you use On Click option it may require double click for the menu item to open. Let us know if it works on the second click.
Hi, I can not reproduce the problem on my end. When you use On Click option it may require double click for the menu item to open. Let us know if it works on the second click. Sincerely, Hella
rick43
rick43 posted this 16 October 2015
It looks like the menu is actually behind the content so it does not work. I reverted back to the previous version and it works
contact130
contact130 posted this 16 October 2015
I have the same problem too and I wasted one hour on it. Almost glad I m not alone ;-(
see it here:
http://www.ericfreget.fr/evenementiel
Please solve it soon as it completly ruin my website on any smartphone
I have the same problem too and I wasted one hour on it. Almost glad I m not alone ;-( see it here: http://www.ericfreget.fr/evenementiel Please solve it soon as it completly ruin my website on any smartphone
Support Team posted this 19 October 2015
@rick43
Nice to hear that you solved the issue. Feel free to contact us in any other occasion.
@contact130
Please create a private topic with the login details to access your theme so we could look into settings.
Hi, @rick43 Nice to hear that you solved the issue. Feel free to contact us in any other occasion. @contact130 Please create a private topic with the login details to access your theme so we could look into settings. Sincerely, Hella
andrewatya
andrewatya posted this 23 October 2017
I have this issue too. Try to set a higher Z-index or any to the menu and it will open over the content.
> It looks like the menu is actually behind the content so it does not work. I reverted back to the previous version and it works I have this issue too. Try to set a higher Z-index or any to the menu and it will open over the content.
