Edit Pages Individually
LGWeb
LGWeb posted this 19 October 2015
In this theme I'm trying to edit the individual pages. If I make changes on one page it changes them all with exception to the Home Page. I want different layouts for each page. I want to add sections and within the sections I want it to have different column layouts.... Or If I want to import sections I don't want it changing every single page... I've tried adding just rows/columns instead of sections but it still changes every page.
I was able to do this on other themes. I've attached the Zip file.
In this theme I'm trying to edit the individual pages. If I make changes on one page it changes them all with exception to the Home Page. I want different layouts for each page. I want to add sections and within the sections I want it to have different column layouts.... Or If I want to import sections I don't want it changing every single page... I've tried adding just rows/columns instead of sections but it still changes every page. I was able to do this on other themes. I've attached the Zip file.
Support Team posted this 20 October 2015
If working not with the HTML templates, Themler does not edit content for now. You edit the design of the template that is applied to all the pages that do use that template. The content should be added from the CMS back end.
If you need to add more templates to design in Themler, then follow the instructions:
http://answers.themler.com/articles/9466/how-to-create-and-use-custom-templates
Hi, If working not with the HTML templates, Themler does not edit content for now. You edit the design of the template that is applied to all the pages that do use that template. The content should be added from the CMS back end. If you need to add more templates to design in Themler, then follow the instructions: http://answers.themler.com/articles/9466/how-to-create-and-use-custom-templates Sincerely, Hella
aaanupes
aaanupes posted this 06 February 2018
Has this been updated I'm having a similar issue. I'm in WordPress but I wanted to edit my pages in Themler so they would look better but a change to one changes them all. If I have to work in the WP editor that would make the type of customization i'm going for difficult. Can you explain how to apply a template to a page and then how to save that page without overwriting them all.
Support Team posted this 07 February 2018
You can edit the content inside Themler. Just make sure that you put your content inside the green area. Green area is the content of each page. If you add some controls within the blue area, that is the template area and those controls will appear on all the pages that are using that template.
Hi, You can edit the content inside Themler. Just make sure that you put your content inside the green area. Green area is the content of each page. If you add some controls within the blue area, that is the template area and those controls will appear on all the pages that are using that template. Sincerely, Hella
