Wordpress horizontal menu with images plugin
jurjen
jurjen posted this 10 November 2015
Hello I want to be able to replace a menu with an icon. I found this plugin https://wordpress.org/plugins/menu-icons/
it works fine with the default 2014 template, but not with Themler.
What can I do to replace a link with an image within Themler, or to get this plugin working with Themler?
Hello I want to be able to replace a menu with an icon. I found this plugin https://wordpress.org/plugins/menu-icons/ it works fine with the default 2014 template, but not with Themler. What can I do to replace a link with an image within Themler, or to get this plugin working with Themler?
9 Comments
jurjen
Some info from the plugin writer:
The icons are not showing!
Make sure that your active theme is using the default walker for displaying the nav menu. If it's using its own custom walker, make sure that the menu item titles are filterable (please consult your theme author about this).
Some info from the plugin writer: The icons are not showing! Make sure that your active theme is using the default walker for displaying the nav menu. If it's using its own custom walker, make sure that the menu item titles are filterable (please consult your theme author about this).
Support Team posted this 11 November 2015
Hello Jurjen,
we'll check the Menu Icons plugin with developers and will let you know.
Hello Jurjen, we'll check the Menu Icons plugin with developers and will let you know. regards, Aileen
Support Team posted this 16 November 2015
Hello Jurjen,
support of the Menu Icons plugin will be available in the next major Themler update. Please follow the news.
Hello Jurjen, support of the Menu Icons plugin will be available in the next major Themler update. Please follow the news. regards, Aileen
mburgener
mburgener posted this 29 November 2016
was this ever implemented?
regards
Mike
was this ever implemented? regards Mike
Support Team posted this 30 November 2016
there should not be any problem with plugin in the latest Themler versions. Just make sure that under Appearance >> Theme options the option 'Trim long menu items' is disabled.
Hello, there should not be any problem with plugin in the latest Themler versions. Just make sure that under Appearance >> Theme options the option 'Trim long menu items' is disabled. regards, Aileen
bsjelin
bsjelin posted this 19 June 2017
This plugin is still not working properly with themler, and to my knowledge themler does not offer menu icons yet as previously stated.
Support Team posted this 20 June 2017
What exactly is not working properly? We tested this plugin and it works ok if Appearance >> Theme options >> option 'Trim long menu items' is disabled.
Hi, What exactly is not working properly? We tested this plugin and it works ok if Appearance >> Theme options >> option 'Trim long menu items' is disabled. Thank you, Olivia
tti2
tti2 posted this 26 December 2018
This plugin is still not working properly with themler. Appearance >> Theme options >> option 'Trim long menu items' is disabled.. Other plugin Orbit Fox Companion is not working too.
This plugin is still not working properly with themler. **Appearance >> Theme options >> option 'Trim long menu items' is disabled.**. Other plugin Orbit Fox Companion is not working too.
Support Team posted this 27 December 2018
I've tested exactly this plugin:
it works ok if the listed option is disabled.
Please check the Theme Option again. there are a few options related to this functionality. Please disable them all just in case.
Hi, I've tested exactly this plugin: https://wordpress.org/plugins/menu-icons/ it works ok if the listed option is disabled. Please check the Theme Option again. there are a few options related to this functionality. Please disable them all just in case. Sincerely, Olivia
