Server Permission/Insufficient permissions error!?
cpetersen
cpetersen posted this 12 November 2015
Has anyone out there ran into this server permissions error using a WINDOWS server? All I had found in the forums was this http://answers.themler.com/questions/3242/insufficient-permissions. This uses the Linux system. Admin here has changed all persmissions, writes, etc... and still not able to use Themler through Wordpress. Any other options to get it to save working through Wordpress? thanks
Has anyone out there ran into this server permissions error using a **WINDOWS** server? All I had found in the forums was this http://answers.themler.com/questions/3242/insufficient-permissions. This uses the Linux system. Admin here has changed all persmissions, writes, etc... and still not able to use Themler through Wordpress. Any other options to get it to save working through Wordpress? thanks
9 Comments
Support Team posted this 13 November 2015
Could you please provide us with a screenshot of your error message.
We need some more details about your issue in order to help you.
Ivan
Hi, Could you please provide us with a screenshot of your error message. We need some more details about your issue in order to help you. Thanks, Ivan
cpetersen
cpetersen posted this 13 November 2015
See attached permissions error.jpg.
cpetersen
cpetersen posted this 15 November 2015
Support team, is there an answer to my prior question? Please reply if there is a way to have Themler work through Wordpress using a Windows server. Thanks
Support Team posted this 17 November 2015
Could you please attach your broken WP theme to this ticket for investigation.
It is stored inside the following folder:
C:\ProgramData\Themler\hd_data\themler_somedigits\wordpress\wp-content\themes
Ivan
Hi, Could you please attach your broken WP theme to this ticket for investigation. It is stored inside the following folder: C:\ProgramData\Themler\hd_data\themler_somedigits\wordpress\wp-content\themes Thanks, Ivan
cpetersen
cpetersen posted this 17 November 2015
Attached is the .zip theme you are requesting. Also attached is the properties image message I get. I don't understand why you are requesting the theme folder as my original question was "Has anyone out there ran into this server permissions error using a WINDOWS server? " We are using a WINDOWS server. Let me know what the answer is. thanks
cpetersen
cpetersen posted this 24 November 2015
Have you come up with any yes or no answer for me on the error I am getting? Please reply. thanks
Support Team posted this 26 November 2015
Sorry for the delay.
As for your original question, unfortunately we don't know how to set up correct permission on Windows server.
I'll make your ticket public again so our user can try to help you.
Ivan
Hi, Sorry for the delay. As for your original question, unfortunately we don't know how to set up correct permission on Windows server. I'll make your ticket public again so our user can try to help you. Thanks, Ivan
vas-al
vas-al posted this 12 January 2016
It had the same problem. When the uninstall antivirus McaFee then Themler worked.
Most likely the problem was in the
Exclude the following services from your Firewall / Anti-virus:
ThemlerApache C: \ Program Files (x86) \ Themler \ bin \ apache \ bin
\ hthemlerd.exe ThemlerMySql C: \ Program Files (x86) \ Themler \ bin
\ mysql \ bin \ mythemlerd.exe
http://answers.themler.com/articles/13879/themler-desktop-troubleshooting#installation
free version did not allow to make an exception
It had the same problem. When the uninstall antivirus McaFee then Themler worked. Most likely the problem was in the > Exclude the following services from your Firewall / Anti-virus: > ThemlerApache C: \ Program Files (x86) \ Themler \ bin \ apache \ bin > \ hthemlerd.exe ThemlerMySql C: \ Program Files (x86) \ Themler \ bin > \ mysql \ bin \ mythemlerd.exe *http://answers.themler.com/articles/13879/themler-desktop-troubleshooting#installation* free version did not allow to make an exception
Support Team posted this 13 January 2016
As soon as free McAfee version doesn't allow to make an exception the only possible solution for you is to disable your antivirus completely while working with Themler.
Ivan
Hi, As soon as free McAfee version doesn't allow to make an exception the only possible solution for you is to disable your antivirus completely while working with Themler. Please let us know if you have any further questions. Thanks, Ivan
