Themler v.130 Hotfix Update (20-November-2015)
Support Team posted this 20 November 2015
Hi guys!
The today's Themler HotFix update includes the following fixes:
  • Joomla: fixed issue with missing microdata.
  • joomla: fixed issues with front end editor (Images and Links, popups).
  • Joomla: fixed a few issue with Artisteer theme conversion.
  • Joomla: fixed issue with "Out of Stock" control on product Details.
  • HTML: fixed issue with missing favicon on child pages.
  • Magento: fixed issue with pagination on Products page.
  • Fixed issue with removing floating of Image control when you add hyperlink.
  • Fixed issue with opening menu subitems in Safari and Chrome on iOS.
  • Fixed issue with "Paste Style" option (added extra styles).
  • Fixed issue with not clickable Vertical parent menu items.
  • Fixed a few issues with Row with Columns control (with collapse spacing and vertical align when flexbox auto height is used).
  • Fixed other minor bugs and various crashes.
Themler Team
[post:45862]
17 Comments
Josh
Josh posted this 20 November 2015
Glad to see a new update to themler. Was hoping that this update would have fixed the issue with WooCommerce checkout page. I am still getting 3 checkout buttons and errors in the dashboard about out of date issues. Is there a way to get these fixed?
Support Team posted this 21 November 2015
Hello Josh,
I suppose that you mean the issue reported in topic
http://answers.themler.com/questions/11700/woocommerce-problems
in fact it should be resolved in this update.
In case the issue persists on your end please submit new private topic and provide access to your WP admin back end.
Hello Josh, I suppose that you mean the issue reported in topic http://answers.themler.com/questions/11700/woocommerce-problems in fact it should be resolved in this update. In case the issue persists on your end please submit new private topic and provide access to your WP admin back end. Regards, Aileen
Josh
Josh posted this 21 November 2015
Will do! Thanks!!
Will do! Thanks!!
phil03
phil03 posted this 23 November 2015
this update change my forms and eliminate much of my icons contained in the old Themler boostrap.css
Fortunately I had copied and renowned the Icomoon Joomla library.I also used and still work.
After checking a new file media.css appeared on this version, and the template as soon as the call is upset my site.
The width of the input by default are now forced to 206px?
So I put my backup and I have not applied this update.
What should I do to keep things running normally?
Philippe.
Hello, this update change my forms and eliminate much of my icons contained in the old Themler boostrap.css Fortunately I had copied and renowned the Icomoon Joomla library.I also used and still work. After checking a new file media.css appeared on this version, and the template as soon as the call is upset my site. The width of the input by default are now forced to 206px? So I put my backup and I have not applied this update. What should I do to keep things running normally? Regards Philippe.
Support Team posted this 24 November 2015
Hello Philippe,
please submit a new private topic where provide access to your CMS admin back end and list the pages which demonstrate the issues with icons and input fields.
Hello Philippe, please submit a new private topic where provide access to your CMS admin back end and list the pages which demonstrate the issues with icons and input fields. regards, Aileen
phil03
phil03 posted this 24 November 2015
Sorry,
I removed Themler v130 on the operational site.
This version is installed on local, non-accessible site.
I put a copy of the documents of two versions appear or anomalies with the same html code.
Surrounded by red, the icons that appear more properly, as well as changes that affect all of my forms.
Also the code of media.css file that apparently modifies these icons by calling the wrong library.
Philippe
Hello, Sorry, I removed Themler v130 on the operational site. This version is installed on local, non-accessible site. I put a copy of the documents of two versions appear or anomalies with the same html code. Surrounded by red, the icons that appear more properly, as well as changes that affect all of my forms. Also the code of media.css file that apparently modifies these icons by calling the wrong library. regards, Philippe
me321
me321 posted this 25 November 2015
WARNING! Latest update breaks Drupal functionality!
To everyone using Drupal, be careful. In my case there are serious issues with this update. If you apply this update to a single Drupal theme, Themler will completely stop working.
Here are the three bug reports I filed:
https://answers.themler.com/questions/46486/can-t-create-new-theme-we-are-sorry-only-themler-s-themes-are-supported
https://answers.themler.com/questions/46488/can-t-open-themes-anymore-themler-always-loads-the-same-theme
http://answers.themler.com/questions/46489/after-latest-update-themler-doesn-t-work-anymore-for-drupal
**WARNING! Latest update breaks Drupal functionality!** To everyone using Drupal, be careful. In my case there are serious issues with this update. If you apply this update to a single Drupal theme, Themler will completely stop working. Here are the three bug reports I filed: https://answers.themler.com/questions/46486/can-t-create-new-theme-we-are-sorry-only-themler-s-themes-are-supported https://answers.themler.com/questions/46488/can-t-open-themes-anymore-themler-always-loads-the-same-theme http://answers.themler.com/questions/46489/after-latest-update-themler-doesn-t-work-anymore-for-drupal
me321
To those of you who are facing the same situation and are looking for a disaster recovery procedure after having applied this update. These are the steps I followed to regain access to my Drupal themes and continue to work with Themler by using a previous version.
  1. Copy C:\ProgramData\Themler\hd_data\themler_[numbers]\drupal\sites\all\themes\ to your hard drive to make a backup.
  2. Download and Install the Themler desktop software with "Remove CMS Content" option enabled (I downloaded this today from the Themler website, luckily it's not the most recent version yet. In case that changes I can upload the old version somewhere.
  3. Launch Themler Desktop and start Drupal
  4. Upload backups of the themes to C:\ProgramData\Themler\hd_data\themler_[numbers]\drupal\sites\all\themes\
  5. open the following URL in browser and clear cache:
    http://127.0.0.1:12080/themler_[numbers]/drupal/admin/config/development/performance
    Please note that you should replace themler_[numbers] with real directory name.
  6. Login with username admin and password admin
  7. Clear caches
  8. Restart themler.
  9. Ignore the update notification and keep using the previous version until the issues are resolved.
To those of you who are facing the same situation and are looking for a disaster recovery procedure after having applied this update. These are the steps I followed to regain access to my Drupal themes and continue to work with Themler by using a previous version. 1. Copy C:\ProgramData\Themler\hd_data\themler_[numbers]\drupal\sites\all\themes\ to your hard drive to make a backup. 2. Download and Install the Themler desktop software with "Remove CMS Content" option enabled (I downloaded this today from the Themler website, luckily it's not the most recent version yet. In case that changes I can upload the old version somewhere. 3. Launch Themler Desktop and start Drupal 4. Upload backups of the themes to C:\ProgramData\Themler\hd_data\themler_[numbers]\drupal\sites\all\themes\ 5. open the following URL in browser and clear cache: http://127.0.0.1:12080/themler_[numbers]/drupal/admin/config/development/performance Please note that you should replace themler_[numbers] with real directory name. 6. Login with username **admin** and password **admin** 7. Clear caches 8. Restart themler. 9. Ignore the update notification and keep using the previous version until the issues are resolved.
bob52
bob52 posted this 25 November 2015
Same with wordpress..
Your sulution works Great!!!!!
Only i didnt need to clear the cache.
Same with wordpress.. Your sulution works Great!!!!! Only i didnt need to clear the cache.
Stagger Lee posted this 25 November 2015
Some estimated time when new major upgrade with new GUI comes ?
me321
me321 posted this 26 November 2015
@bob52 happy it worked for you!
Hope we'll get a fix soon, it looks like the latest version of Themler has critical issues.
@bob52 happy it worked for you! Hope we'll get a fix soon, it looks like the latest version of Themler has critical issues.
Support Team posted this 26 November 2015
me123,
We have answered in another support ticket, 46486.
Stagger Lee,
For now there is no exact time frame, we expect the major update within the period of next 2-3 weeks.
bob52,
If the issue with Themler Desktop and Wordpress is still actual, please create a new private ticket and provide the log like it is described here:
http://answers.themler.com/articles/13879/themler-desktop-troubleshooting#installation
**me123,** We have answered in another support ticket, 46486. **Stagger Lee,** For now there is no exact time frame, we expect the major update within the period of next 2-3 weeks. **bob52,** If the issue with Themler Desktop and Wordpress is still actual, please create a new private ticket and provide the log like it is described here: http://answers.themler.com/articles/13879/themler-desktop-troubleshooting#installation Thank you, Nettie, BillionDigital Team
phil03
phil03 posted this 01 December 2015
Hello BillionDigital Team,
For the problem that I pointed out.
There is a conflict between your file bootstrap.css and media.css
Indeed you use 2 times the same file returns, for icons that are unique in your policy and are not found in Icomoon.
Attached is the offending code
bootstrap.css
     @font-face {
  font-family: 'Billion Web Font';
  src: url("BillionWebFonts.woff") format('woff'), url("BillionWebFonts.ttf") format('truetype');
  font-weight: normal;
  font-style: normal;
[class^="icon-"]:before,
[class*=" icon-"]:before {
  font-style: normal;
  text-decoration: inherit;
  text-align: center;
  text-transform: none;
  width: 1em;
[class^="icon-"],
[class*=" icon-"] {
  display: inline-block;
  speak: none;
And
media.css
@font-face {
  font-family: 'IcoMoon';
  src: url('../../../media/jui/fonts/IcoMoon.eot');
  src: url('../../../media/jui/fonts/IcoMoon.eot?#iefix') format('embedded-opentype'), url('../../../media/jui/fonts/IcoMoon.woff') format('woff'), url('../../../media/jui/fonts/IcoMoon.ttf') format('truetype'), url('../../../media/jui/fonts/IcoMoon.svg#IcoMoon') format('svg');
  font-style: normal;
[data-icon]:before {
  content: attr(data-icon);
  speak: none;
[class^="icon-"],
[class*=" icon-"] {
  width: 14px;
  height: 14px;
  *margin-right: .3em;
  line-height: 14px;
  font-style: normal;
  speak: none;
Philippe
Hello BillionDigital Team, For the problem that I pointed out. There is a conflict between your file bootstrap.css and media.css Indeed you use 2 times the same file returns, for icons that are unique in your policy and are not found in Icomoon. Attached is the offending code **bootstrap.css** @font-face { font-family: 'Billion Web Font'; src: url("BillionWebFonts.woff") format('woff'), url("BillionWebFonts.ttf") format('truetype'); font-weight: normal; font-style: normal; } [class^="icon-"]:before, [class*=" icon-"]:before { font-family: 'Billion Web Font'; font-style: normal; font-weight: normal; text-decoration: inherit; text-align: center; text-transform: none; width: 1em; } [class^="icon-"], [class*=" icon-"] { text-decoration: inherit; display: inline-block; speak: none; } And **media.css** @font-face { font-family: 'IcoMoon'; src: url('../../../media/jui/fonts/IcoMoon.eot'); src: url('../../../media/jui/fonts/IcoMoon.eot?#iefix') format('embedded-opentype'), url('../../../media/jui/fonts/IcoMoon.woff') format('woff'), url('../../../media/jui/fonts/IcoMoon.ttf') format('truetype'), url('../../../media/jui/fonts/IcoMoon.svg#IcoMoon') format('svg'); font-weight: normal; font-style: normal; } [data-icon]:before { font-family: 'IcoMoon'; content: attr(data-icon); speak: none; } [class^="icon-"], [class*=" icon-"] { display: inline-block; width: 14px; height: 14px; *margin-right: .3em; line-height: 14px; } [class^="icon-"]:before, [class*=" icon-"]:before { font-family: 'IcoMoon'; font-style: normal; speak: none; } regards, Philippe
Support Team posted this 05 December 2015
Hello Philippe,
in general there may be a kind of conflict between bootstrap .css file and other css style used on the page. I mean that they may specify the same settings.
Please submit a new topic for this issue and provide the link to the page which demonstrates the issue.
Hello Philippe, in general there may be a kind of conflict between bootstrap .css file and other css style used on the page. I mean that they may specify the same settings. Please submit a new topic for this issue and provide the link to the page which demonstrates the issue. Regards, Aileen
Stagger Lee posted this 09 December 2015
I have one question.
Net update will be. Standard update ? Or major upgrade ?
Can we get some short list what new will be ?
I have one question. Net update will be. Standard update ? Or major upgrade ? Can we get some short list what new will be ?
Alexander Dzhuninski
Alexander Dzhuninski posted this 10 December 2015
Me also :)
> I have one question. > > Net update will be. Standard update ? Or major upgrade ? > > Can we get some short list what new will be ? Me also :)
Support Team posted this 11 December 2015
Hello guys,
the new update is almost ready
http://answers.themler.com/articles/49176/the-new-themler-major-update-is-almost-here
Hello guys, the new update is almost ready http://answers.themler.com/articles/49176/the-new-themler-major-update-is-almost-here regards, Aileen
