Fix structured data error google, wordpress theme with themler
carpentierigiovanni
carpentierigiovanni posted this 30 November 2015
Hello!
with my theme created with themler for wordpress i have many errors with structured data...
how i can fix that?
Hello! with my theme created with themler for wordpress i have many errors with structured data... how i can fix that? Thanks
18 Comments
jacojashi
jacojashi posted this 30 November 2015
I have same problem in prestashop (lost "product name")for now i use "custom cms code" like this:
<span style="opacity: 0;" itemprop="name">{$product->name|escape:'htmlall':'UTF-8'}</span>
this is temporary solution...
https://answers.themler.com/questions/43406/rich-snippets-for-products
I have same problem in prestashop (lost "product name")for now i use "custom cms code" like this: <span style="opacity: 0;" itemprop="name">{$product->name|escape:'htmlall':'UTF-8'}</span> this is temporary solution... https://answers.themler.com/questions/43406/rich-snippets-for-products
carpentierigiovanni
carpentierigiovanni posted this 03 December 2015
&lt;span style itemprop&gt;{$product-&gt;name|escape:&#39;htmlall&#39;:&#39;UTF-8&#39;}&lt;/span&gt;
OK thanks for the info jashi.
From the team of themler? no answer?
> I have same problem in prestashop (lost "product name")for now i use "custom cms code" like this: > > &lt;span style itemprop&gt;{$product-&gt;name|escape:&#39;htmlall&#39;:&#39;UTF-8&#39;}&lt;/span&gt; > > this is temporary solution... > > https://answers.themler.com/questions/43406/rich-snippets-for-products OK thanks for the info jashi. From the team of themler? no answer?
carpentierigiovanni
carpentierigiovanni posted this 07 December 2015
Paul Linden
Paul Linden posted this 08 December 2015
Hi all,
i have the same problem to with my wordpress-theme.
it will be fine, the developer team give us a solution.
Paul
Hi all, i have the same problem to with my wordpress-theme. it will be fine, the developer team give us a solution. Thanks Paul
Support Team posted this 10 December 2015
Hello guys,
I apologize for delay in response.
Please provide links to your pages which demonstrate the reported problem and we'll investigate it.
Hello guys, I apologize for delay in response. Please provide links to your pages which demonstrate the reported problem and we'll investigate it. Regards, Aileen
Paul Linden
Paul Linden posted this 17 December 2015
Hi Aileen,
in the Attachment you finde a screenshot from google´s web-master-tools. You can look the errors (in german Fehler) for the property´s in HTML-Markup. The error message "Folgendes fehlt" means "The following is missing".
I hope, this is helpfull for you
with best Regards
Paul
Hi Aileen, in the Attachment you finde a screenshot from google´s web-master-tools. You can look the errors (in german Fehler) for the property´s in HTML-Markup. The error message "*Folgendes fehlt*" means "*The following is missing*". I hope, this is helpfull for you with best Regards Paul
Support Team posted this 22 December 2015
Hello Paul,
I'm afraid that screenshot is not enough, could you provide link to your site?
Hello Paul, I apologize for delay in response. I'm afraid that screenshot is not enough, could you provide link to your site? regards, Aileen
Paul Linden
Paul Linden posted this 29 December 2015
Hello Aileen,
I´am sorry I forgott the link to my site.
My site is: http://cdi-ac.de/
it is a site with wordpress 4.3 and a themler theme.
The site is complete in german, i hope that is not a problem for you
best regard
Paul
Hello Aileen, I´am sorry I forgott the link to my site. My site is: http://cdi-ac.de/ it is a site with wordpress 4.3 and a themler theme. The site is complete in german, i hope that is not a problem for you best regard Paul
Support Team posted this 04 January 2016
Hello Paul,
thank you. We'll check it with developers and will let you know the results.
Hello Paul, thank you. We'll check it with developers and will let you know the results. regards, Aileen
carpentierigiovanni
carpentierigiovanni posted this 04 January 2016
Hello, how i can hide the date time from google se? where i can edit for hide and not remove this field?
if i remove the field "updated" i get errors on the webmaster tool.
Thanks.
Here you will found an pic with the example:
Hello, how i can hide the date time from google se? where i can edit for hide and not remove this field? if i remove the field "updated" i get errors on the webmaster tool. Thanks. Here you will found an pic with the example: !002.png!
Jan-Willem
Jan-Willem posted this 05 March 2016
What is the status of the Google structured data error? I am having the same problem, which is very well described on the following website:
Google analytics structured data error description
I am using Yoast SEO so should work. But even Yoast is pointing to some theme settings which should be made:
Yoast knowledge base article
Jan-Willem
What is the status of the Google structured data error? I am having the same problem, which is very well described on the following website: [Google analytics structured data error description ][1] I am using Yoast SEO so should work. But even Yoast is pointing to some theme settings which should be made: [Yoast knowledge base article][2] Jan-Willem [1]: http://www.acceleratormarketing.com/trench-report/google-analytics-errors-and-structured-data/ [2]: http://kb.yoast.com/article/184-fixing-hcard-author-error
Support Team posted this 09 March 2016
Hello Jan-Willem,
Number if issues in Themler theme has been resolved and the changes will be included into one of Themler updates. However we're continue working on reported problem to fix the rest.
Hello Jan-Willem, I apologize for delay in response. Number if issues in Themler theme has been resolved and the changes will be included into one of Themler updates. However we're continue working on reported problem to fix the rest. regards, Aileen
Jan-Willem
Jan-Willem posted this 13 November 2016
Since the last time I posted (9 March) nothing has changed. Google Search Console still lists the structured data errors as before. I am using the latest version of WordPress v4.6.1 and Themler v349.
Missing: author
Missing: entry-title
Missing: updated
For example for the pages:
http://www.pitztalholiday.eu/
http://www.pitztalholiday.eu/en/archive-hikingtrail/
http://www.pitztalholiday.eu/traillocation/tirol/
I see in the page sources for example no 'class="entry-title" ' at H1 / H2 titles.
Tried to find a way in themler to add them, but no success.
Can you please fix this item in Themler or tell me how to add these in Themler for site title, page titles and post titles?
Note there are more users with this problem, for example:
Themler for Wordpress + Google Structered Data
Jan-Willem Kruse
Since the last time I posted (9 March) nothing has changed. Google Search Console still lists the structured data errors as before. I am using the latest version of WordPress v4.6.1 and Themler v349. Missing: author Missing: entry-title Missing: updated For example for the pages: http://www.pitztalholiday.eu/ http://www.pitztalholiday.eu/en/archive-hikingtrail/ http://www.pitztalholiday.eu/traillocation/tirol/ I see in the page sources for example no 'class="entry-title" ' at H1 / H2 titles. Tried to find a way in themler to add them, but no success. Can you please fix this item in Themler or tell me how to add these in Themler for site title, page titles and post titles? Note there are more users with this problem, for example: [Themler for Wordpress + Google Structered Data][1] Regards, Jan-Willem Kruse [1]: https://answers.themler.com/questions/79798/themler-for-wordpress-google-structered-data
Support Team posted this 17 November 2016
Hello Jan-Willem,
the corresponding changes were made in Themler.
In case you encounter such issue again please submit new private topic and provide access to your WP admin back end.
Hello Jan-Willem, the corresponding changes were made in Themler. In case you encounter such issue again please submit new private topic and provide access to your WP admin back end. Regards, Aileen
deunsdenis
deunsdenis posted this 20 November 2016
I have this problem too. Have you found a solution?
Deuns26
Hi I have this problem too. Have you found a solution? Deuns26
Support Team posted this 22 November 2016
Hello Deuns26,
I've answered in the topic http://answers.themler.com/questions/109083/structured-data-error-google
Hello Deuns26, I've answered in the topic http://answers.themler.com/questions/109083/structured-data-error-google regards, Aileen
MrGreen
MrGreen posted this 05 October 2017
Hello, the link is break.
Where is the solution ? i've the same issue....
Hello, the link is break. Where is the solution ? i've the same issue.... Regards
Support Team posted this 05 October 2017
Try to open this link:
http://answers.themler.io/questions/109083/structured-data-error-google
Does it work?
Hi, Try to open this link: http://answers.themler.io/questions/109083/structured-data-error-google Does it work? Sincerely, Hella
