Problems with the Wordpress Plugin Menu Icons
IT-Medien Design
IT-Medien Design posted this 03 December 2015
I have problems with the Wordpress Plugin Menu Icons;
https://de.wordpress.org/plugins/menu-icons/
the plugins add a icons in the menu item
but the icons aren't visible. With other themes it works fine.
have you an idea what to do?
thanks,
Thilo
Hello, I have problems with the Wordpress Plugin Menu Icons; [https://de.wordpress.org/plugins/menu-icons/][1] [1]: https://de.wordpress.org/plugins/menu-icons/ the plugins add a icons in the menu item but the icons aren't visible. With other themes it works fine. have you an idea what to do? thanks, Thilo
Stagger Lee posted this 03 December 2015
Themler Menu Walker is very different than one in WordPress default themes. Dont know reason why.
Try to give each menu item unique class and in CSS add SVG icons with :before, :after.
Themler Menu Walker is very different than one in WordPress default themes. Dont know reason why. Try to give each menu item unique class and in CSS add SVG icons with :before, :after.
Support Team posted this 07 December 2015
Hello guys,
support of the Menu Icons plugin will be available in the next major Themler update. Please follow the news.
Hello guys, support of the Menu Icons plugin will be available in the next major Themler update. Please follow the news. regards, Aileen
Katarzyna
Katarzyna posted this 14 November 2016
Hello guys,
Menu Icons still not working. I can't find information about plugin support :(
> Hello guys, > support of the Menu Icons plugin will be available in the next major Themler update. Please follow the news. > > regards, > Aileen Menu Icons still not working. I can't find information about plugin support :(
Support Team posted this 17 November 2016
please open the Theme Options under WP admin back end and make sure that this option is disabled
Then assign icons to menu items. They should appear.
Hello, please open the Theme Options under WP admin back end and make sure that this option is disabled !trim.png! Then assign icons to menu items. They should appear. regards, Aileen
engels
engels posted this 09 March 2018
...and you have additional to uncheck "Apply menu item tag filter" in the Theme Options.
Then next issue: no space between icon and text.
Solution in my case: one or two " " bevore/after menutext.
Have success.
...and you have additional to uncheck "Apply menu item tag filter" in the Theme Options. Then next issue: no space between icon and text. Solution in my case: one or two " " bevore/after menutext. Have success.
