Please add an option for manual theme updating
shaulhadar
shaulhadar posted this 04 December 2014
Hello Themler. It would be great if we could get a message before the theme gets updated to the newest version. Sometimes there are problems on some hostings with the updating, and if we had a window that says: "new update available, update?" and a yes , no option, I really think it would be better. for instance if you have a client that loads themler after you finished the site, and the update procedure somehow didn't work or something like this.
Thanks for your time! :)
Shaul.
Hello Themler. It would be great if we could get a message before the theme gets updated to the newest version. Sometimes there are problems on some hostings with the updating, and if we had a window that says: "new update available, update?" and a yes , no option, I really think it would be better. for instance if you have a client that loads themler after you finished the site, and the update procedure somehow didn't work or something like this. Thanks for your time! :) Shaul.
Support Team posted this 08 December 2014
Hi Shaul,
thank you for your suggestion, I'm not sure if it is technically possible but I'm adding your request to our wish list.
Hi Shaul, thank you for your suggestion, I'm not sure if it is technically possible but I'm adding your request to our wish list. Thanks, Aileen
Vitaliy WD
Vitaliy WD posted this 02 February 2015
In this case I can offer a solution like a Password protection for "Edit Template" option.
Without password - clients can't go to "Edit Template" and update theme / template.
enter image description here
In this case I can offer a solution like a [Password protection for "Edit Template"][1] option. Without password - clients can't go to "Edit Template" and update theme / template. ![enter image description here][2] [1]: https://answers.billiondigital.com/questions/6975/password-protection-for-edit-template [2]: http://s21.postimg.org/4b24blv6f/password_bt_edit.png
