Server error - server unavailable
picturesque
picturesque posted this 05 December 2015
I can't edit a theme from within Magento. Error message themler "server error - server unavailable"
26 Comments
pablomartinez
pablomartinez posted this 06 December 2015
I have the same problem with theme for wordpress from Themler on Wordpress and trying to edit the menu.
picturesque
picturesque posted this 08 December 2015
This appears to have magically fixed itself? No response from support. Nope. It's still there. Just happened again. Hello!
Support Team posted this 09 December 2015
Hi guys,
I'm terribly sorry for the delay.
Please feel free to create new private tickets and provide us with a temp access to your back-end for the investigation.
We're waiting for your feedback.
Ivan
Hi guys, I'm terribly sorry for the delay. Please feel free to create new private tickets and provide us with a temp access to your back-end for the investigation. We're waiting for your feedback. Thanks, Ivan
picturesque
picturesque posted this 09 December 2015
Private ticket created.
Marco
Marco posted this 10 December 2015
Got the same problem, when trying to change anything on the existing layout.
Steps to reproduce:
  1. Logged in
  2. clicked on "Headers"
  3. tried to change the header Layout
  4. Error appears...
edit//
tried in latest FF and Chrome
Got the same problem, when trying to change anything on the existing layout. Steps to reproduce: 1. Logged in 2. clicked on "Headers" 3. tried to change the header Layout 4. Error appears... edit// tried in latest FF and Chrome
Marco
Update: Tried with 2 different websites - the same...
Support Team posted this 10 December 2015
Hi Marco,
Please create a private ticket as well and provide us with an access to your back-end there.
Ivan
Hi Marco, Please create a private ticket as well and provide us with an access to your back-end there. Thanks, Ivan
esmaeili_masood
esmaeili_masood posted this 11 December 2015
I have the same problem with theme for wordpress from Themler on Wordpress and trying to edit a page.
Do you have any answer for this Problem?
I have the same problem with theme for wordpress from Themler on Wordpress and trying to edit a page. Do you have any answer for this Problem?
esmaeili_masood
Hi Marco,
do you have any Answer?
Masood
Hi Marco, do you have any Answer? Thanks, Masood
Support Team posted this 11 December 2015
Hi Masood,
With such an issues we would recommend you to directly create new private ticket and provide us with a temp access to your WP back-end.
Then we'll be able to investigate your problem and try to help you.
Ivan
Hi Masood, With such an issues we would recommend you to directly create new private ticket and provide us with a temp access to your WP back-end. Then we'll be able to investigate your problem and try to help you. Thanks, Ivan
Marco
Marco posted this 11 December 2015
Dear Themler Support.
If so many people have this problem you should have a look at your developers...
Ill open ticket...
@Masood: Not yet, but we will see -- keep you updated...
regards Marco
Dear Themler Support. If so many people have this problem you should have a look at your developers... Ill open ticket... @Masood: Not yet, but we will see -- keep you updated... regards Marco
Marco
Ticket is opened - I´m curious...
Marco
Marco posted this 12 December 2015
found out now - by myself - that this happens only to websites which are secured with SSL.
So if i use https:// it will NOT work and I got this server error.
If I use just http:// all went fine...
found out now - by myself - that this happens only to websites which are secured with SSL. So if i use https:// it will NOT work and I got this server error. If I use just http:// all went fine...
BornData
BornData posted this 14 December 2015
Yes, without SSL works, but with SSL does not.
Please fix it asap, It's very annoying to turn off SSL when using themler, and then turn back on SSL in etc. Joomla.
Yes, without SSL works, but with SSL does not. Please fix it asap, It's very annoying to turn off SSL when using themler, and then turn back on SSL in etc. Joomla.
picturesque
picturesque posted this 14 December 2015
I did get the standard "we'll forward it to our developers" answer. Thank you both for posting the solution. I've been editing the template in the Themler site, then downloading and uploading. A bit more tedious for minor tweaks, but perhaps that's better than editing a live site when there's issues like this.
Marco
Marco posted this 15 December 2015
They should need to fix this SSL Error instantly!
Could not be...
They should need to fix this SSL Error instantly! Could not be...
Webonique
Webonique posted this 16 December 2015
I have the same issue, still no reply from themler...
Turning off SSL isn't working for me either..... Still error
> Yes, without SSL works, but with SSL does not. > > Please fix it asap, It's very annoying to turn off SSL when using themler, and then turn back on SSL in etc. Joomla. I have the same issue, still no reply from themler... Turning off SSL isn't working for me either..... Still error
Support Team posted this 16 December 2015
Hi guys,
Sorry for the delay.
We investigated this issue properly.
Now everything should work fine.
Could you please try to reproduce the issue and let us know the result.
Ivan
Hi guys, Sorry for the delay. We investigated this issue properly. Now everything should work fine. Could you please try to reproduce the issue and let us know the result. We're waiting for your feedback. Thanks, Ivan
Marco
Marco posted this 16 December 2015
tried on two sites - seems to be really solved now.
Thanks.
tried on two sites - seems to be really solved now. Thanks.
picturesque
picturesque posted this 16 December 2015
Fixed for me as well.
