Sorry, an error has occurred. Please clear your browser cache.
Vykusa
Vykusa posted this 05 December 2014
Hello, can not log in to Themler, reports: Sorry, an error has occurred. Please clear your browser cache.
and then: Error.#Request_failed_msg.
Hello, can not log in to Themler, reports: Sorry, an error has occurred. Please clear your browser cache. and then: Error.#Request_failed_msg.
28 Comments
cookiemovies
cookiemovies posted this 05 December 2014
I´m getting the same error as well. Hope you´ll fix this soon, as I can´t work with Themler now!
Linkebel
Linkebel posted this 05 December 2014
Me too
When I edit themes since themeler it works
But since my hosting it not work, yesterday it worked
Hi, Me too When I edit themes since themeler it works But since my hosting it not work, yesterday it worked Thank you
Support Team posted this 05 December 2014
Sorry, please try again.
Linkebel
Ok
It's good for me.
Thank you.
Ok It's good for me. Thank you.
anneke
anneke posted this 09 January 2015
I've got the same problem right now, what to do?
Support Team posted this 09 January 2015
Hi anneke,
Could you please create a separate private topic and provide us with the following information:
- when does the issue happen (on theme opening, saving, etc)?
- where does the issue happen (local/hosted CMS, our Cloud)
- does the issue happen with your edited theme only or with default theme too?
Hi anneke, Could you please create a separate private topic and provide us with the following information: - when does the issue happen (on theme opening, saving, etc)? - where does the issue happen (local/hosted CMS, our Cloud) - does the issue happen with your edited theme only or with default theme too? Thank you, Olivia
cevdet fatih şen
cevdet fatih şen posted this 18 March 2015
Mm site edit theme buton then not run themler.
Browser Crome, Joomla 3.3.6
But Artisteer is very well program. Please help me asap.
Hi, Mm site edit theme buton then not run themler. Sorry, an error has occurred. Please clear your browser cache. Browser Crome, Joomla 3.3.6 But Artisteer is very well program. Please help me asap.
Support Team posted this 18 March 2015
Please try to do steps like described in following article:
http://answers.billiondigital.com/articles/8713/error-sorry-an-error-has-occurred-please-clear-your-browser-cache
Please try to do steps like described in following article: http://answers.billiondigital.com/articles/8713/error-sorry-an-error-has-occurred-please-clear-your-browser-cache
jacojashi
jacojashi posted this 18 March 2015
Or use plugin like "Cache Killer" in chrome. Set it to "on" and content is always fresh.
Stagger Lee posted this 05 April 2015
Just had this problem. Check error console in Firefox. It was for me one open script tag and not closed in Settings.
dpodesta
dpodesta posted this 10 June 2015
I've cleared all of my browser cache and still get this error
I've cleared all of my browser cache and still get this error!bdcacheCapture.JPG!
Stagger Lee posted this 10 June 2015
I was just reading this topic. Seems as something provoked by their last update. On one website did not have problem, on other have.
Here are JS console error logs:
Navigated to http://localhost/my_site/wp-admin/themes.php?page=theme_editor&theme=my_theme&ver=10
2015-06-10 23:54:57.875 themes.php:1 Document was loaded from Application Cache with manifest http://localhost/my_site/wp-admin/admin-ajax.php?ver=10&action=theme_get_manifest
2015-06-10 23:54:57.876 themes.php:1 Application Cache Checking event
2015-06-10 23:54:59.002 themes.php:1 Application Cache NoUpdate event
2015-06-10 23:55:14.715 VM840 project.php?version=1433972502:1Uncaught SyntaxError: Unexpected token <
2015-06-10 23:55:16.870 start.js?version=3333:17253 templateInfo is not defined.
ReferenceError: templateInfo is not defined
    at Object.getMaxRequestSize (http://localhost/my_site/wp-content/themes/my_theme/export/DataProvider.js?version=1433972502:218:16)
    at Object.DataProviderFacade.getMaxRequestSize (http://localhost/http://themler.com/loader/start.js?version=3333:18351:84)
    at eval (http://localhost/http://themler.com/loader/start.js?version=33333:18602:49)
    at eval (http://localhost/http://themler.com/loader/start.js?version=3333:18912:3)
    at http://cstatic.billiondigital.com/themler/9/start.js:1:4114934
Details:
    "onErrorMessage": "Uncaught ReferenceError: templateInfo is not defined
Script:http://localhost/my_site/wp-content/themes/my_theme/export/DataProvider.js?version=1433972502
Line:218
Column:16",
    "isStartupCrash": true,
    "addAdditionalInfoException": {},
    "stringifyError": "Converting circular structure to JSON"
}ErrorUtility.logError @ start.js?version=333:17253ErrorUtility.onError @ start.js?version=dad7dc2576cee07e872390823439eac77d77694a:17076
2015-06-10 23:55:16.877 start.js?version=3333:17151 Cannot read property 'request' of undefined
TypeError: Cannot read property 'request' of undefined
    at Object.ErrorUtility._sendMessage (http://localhost/http://themler.com/loader/start.js?version=3333:17148:30)
    at Object.ErrorUtility.logError (http://localhost/http://themler.com/loader/start.js?version=333:17259:26)
    at ErrorUtility.onError (http://localhost/http://themler.com/loader/start.js?version=333:17076:33)
2015-06-10 23:55:16.877 start.js?version=333:17266 Failed to execute 'write' on 'Document': It isn't possible to write into a document from an asynchronously-loaded external script unless it is explicitly opened.
2015-06-10 23:55:16.878 DataProvider.js?version=1433972502:218 Uncaught ReferenceError: templateInfo is not defined
If I in console click project.php I get this:
<br />
<b>Fatal error</b>:  Allowed memory size of 268435456 bytes exhausted (tried to allocate 65488 bytes) in <b>D:\EasyPHP\data\localweb\my_site\wp-includes\formatting.php</b> on line <b>1265</b><br />
Is it 256 MB not enough ?
I was just reading this topic. Seems as something provoked by their last update. On one website did not have problem, on other have. Here are JS console error logs: Navigated to http://localhost/my_site/wp-admin/themes.php?page=theme_editor&theme=my_theme&ver=10 2015-06-10 23:54:57.875 themes.php:1 Document was loaded from Application Cache with manifest http://localhost/my_site/wp-admin/admin-ajax.php?ver=10&action=theme_get_manifest 2015-06-10 23:54:57.876 themes.php:1 Application Cache Checking event 2015-06-10 23:54:59.002 themes.php:1 Application Cache NoUpdate event 2015-06-10 23:55:14.715 VM840 project.php?version=1433972502:1Uncaught SyntaxError: Unexpected token < 2015-06-10 23:55:16.870 start.js?version=3333:17253 templateInfo is not defined. ReferenceError: templateInfo is not defined at Object.getMaxRequestSize (http://localhost/my_site/wp-content/themes/my_theme/export/DataProvider.js?version=1433972502:218:16) at Object.DataProviderFacade.getMaxRequestSize (http://localhost/http://themler.com/loader/start.js?version=3333:18351:84) at eval (http://localhost/http://themler.com/loader/start.js?version=33333:18602:49) at eval (http://localhost/http://themler.com/loader/start.js?version=3333:18912:3) at http://cstatic.billiondigital.com/themler/9/start.js:1:4114934 Details: { "onErrorMessage": "Uncaught ReferenceError: templateInfo is not defined Script:http://localhost/my_site/wp-content/themes/my_theme/export/DataProvider.js?version=1433972502 Line:218 Column:16", "isStartupCrash": true, "addAdditionalInfoException": {}, "stringifyError": "Converting circular structure to JSON" }ErrorUtility.logError @ start.js?version=333:17253ErrorUtility.onError @ start.js?version=dad7dc2576cee07e872390823439eac77d77694a:17076 2015-06-10 23:55:16.877 start.js?version=3333:17151 Cannot read property 'request' of undefined TypeError: Cannot read property 'request' of undefined at Object.ErrorUtility._sendMessage (http://localhost/http://themler.com/loader/start.js?version=3333:17148:30) at Object.ErrorUtility.logError (http://localhost/http://themler.com/loader/start.js?version=333:17259:26) at ErrorUtility.onError (http://localhost/http://themler.com/loader/start.js?version=333:17076:33) 2015-06-10 23:55:16.877 start.js?version=333:17266 Failed to execute 'write' on 'Document': It isn't possible to write into a document from an asynchronously-loaded external script unless it is explicitly opened. 2015-06-10 23:55:16.878 DataProvider.js?version=1433972502:218 Uncaught ReferenceError: templateInfo is not defined If I in console click project.php I get this: <br /> <b>Fatal error</b>: Allowed memory size of 268435456 bytes exhausted (tried to allocate 65488 bytes) in <b>D:\EasyPHP\data\localweb\my_site\wp-includes\formatting.php</b> on line <b>1265</b><br /> Is it 256 MB not enough ?
Changed all hashes from URL to "333". Dont know if anyone can decode my Themler password from this. Better to be on safe side.
Maybe it has something to do with new "split terms" between taxonomies 4.2 WP thing to do.
They warn plugin and theme developers that from 4.3 there will be no backward compatibility.
Then, believe project.php has one unexpected ";" at the end of file.
Maybe it has something to do with new "split terms" between taxonomies 4.2 WP thing to do. They warn plugin and theme developers that from 4.3 there will be no backward compatibility. Then, believe project.php has one unexpected ";" at the end of file.
Stagger Lee posted this 11 June 2015
All my other themes are OK, just one shows this error. Cannot compare code in JSON files, it is mess to compare.
Support Team posted this 11 June 2015
Hello David and Stagger Lee,
please submit new separate private topics http://answers.billiondigital.com/Topic/Create?private=1
and provide links to your themes or access to CMS admin back end so we could test the themes.
Thank you.
Hello David and Stagger Lee, please submit new separate private topics http://answers.billiondigital.com/Topic/Create?private=1 and provide links to your themes or access to CMS admin back end so we could test the themes. Thank you. regards, Aileen
I did it already.
I did it already.
AtosApps
AtosApps posted this 14 June 2015
The whole update them, this comes several errors.
Support Team posted this 15 June 2015
Please submit new separate private topics http://answers.billiondigital.com/Topic/Create?private=1
and provide links to your themes or access to CMS admin back end so we could test the theme.
Ivan
Hi, Please submit new separate private topics http://answers.billiondigital.com/Topic/Create?private=1 and provide links to your themes or access to CMS admin back end so we could test the theme. Thanks, Ivan
lihiho
lihiho posted this 23 August 2015
I had the same problem with windows version.
in my case the reason was not-beeing logged in in Joomla.
After starting Themler I opened the link for joomla in a new window, deleted everything after the administrator/ and then logged in.
I started Themler again - and finally it works.
Greetings
Lisa
Hi, I had the same problem with windows version. in my case the reason was **not-beeing** logged in in Joomla. After starting Themler I opened the link for joomla in a new window, deleted everything after the administrator/ and then logged in. I started Themler again - and finally it works. Greetings Lisa
