Wordpress Theme Multilanguage support
Eok
Eok posted this 11 December 2015
Hi, i'm wondering how to change del logo link on different languages.. I use qtranslate x plugin. Thanks!
Support Team posted this 12 December 2015
Maybe you could also find some plug-in that will enable switching the templates for different languages and then create several templates with different logos.
Hi, Maybe you could also find some plug-in that will enable switching the templates for different languages and then create several templates with different logos. Sincerely, Hella
Eok
Eok posted this 12 December 2015
Thanks but i only need to change logo link not graphics.. cause if i set logo link to The homepage when i switch language The link bring me to The dafualt language not The selected
Support Team posted this 15 December 2015
Hello Matteo,
you may consider a workaround:
-add WP Widget Area control instead of Logo control;
-under WP admin back end add Text Widget to created area;
-set it up to output necessary image and set up link;
-set widget to be displayed for certain language only;
Add text widgets with different image links for the other languages.
Hello Matteo, you may consider a workaround: -add WP Widget Area control instead of Logo control; -under WP admin back end add Text Widget to created area; -set it up to output necessary image and set up link; -set widget to be displayed for certain language only; Add text widgets with different image links for the other languages. regards, Aileen
